Jk trackbar bolt upgrade. DO IT!!! - JeepForum.com
post #1 of 20 Old 09-24-2013, 08:25 PM Thread Starter
Nsiavosh90
So for 13$ I went to our local hardware store and picked up x2 9/16 18unf x 3.0 grade 8 shouldered bolts with washers and x2 9/16 18unf stover top lock nuts and I am amazed I haven't done this sooner. Shortly after my 2.5 rubicon express lift and new joints all the way around ( ball joints, drag links, tie rod ends and a rubicon express steering stabilizer) I was still getting massive shakes (and one occurrence of DW) in the steering wheel over bumps. Only a days worth of driving with new trackbar bolts in but what a difference in the feel over bumps. Just wanted to back everyone who has said to do this upgrade on the forum and encourage every jk owner to swap out those 14mm bolts with threads all the way to the head of the bolt.
Nsiavosh90 is offline
post #2 of 20 Old 09-24-2013, 08:55 PM
Mfrancis
2014 JK Wrangler
Check this out:
http://www.synergymfg.com/Synergy-Su...t-p-30501.html
Definitely the way I'm heading, and I don't even have a lift on yet. I called 4wd parts when I got home, as it is listed as a vendor of this product, and the guy I spoke to had never even heard of this phenomenon. He's looking into it so he can stock it in the local shop here.
Black 2014 JKU Sport S, 6 speed manual, 3.73 rear end, 2.5" AEV Dualsport XT w/ Bilstein 5100s, 255/75/17 Goodyear Wrangler A/T, Rubicon rock rails, front grill mesh mod, Jeep door sill guards, matte black Jeep grill emblem, matte black exhaust, Synrgy upper and lower bolt swap(highly recommend), tires pending...
Mfrancis is offline
post #3 of 20 Old 09-24-2013, 10:19 PM
TRAUMAhead
2010 JK Wrangler
Rebel and Northridge also have a kit.
TRAUMAhead is offline
post #4 of 20 Old 09-24-2013, 11:15 PM
brianjw
Don't forget all of the control arm bolts that are also threaded instead of shouldered. Also don't forget the cam bolt eliminator washers since you have round bolts in square holes on the lower control arms.
brianjw is offline
post #5 of 20 Old 09-25-2013, 11:58 AM
HighandLow
HighandLow's Avatar
2010 JK Wrangler
On the frame side or axle side?
2010 Rubicon, Auto, Stone White, 3.5"Synergy Coils, DL and TR, MetalCloak TB's and CA's Fr/Rr, 37"Coopers 18" Ions , Adams 1310's, G2 5.13 gears, Synergy Sleeves and Gussets, ORF, PSC, JCR, PIAA,Rancho equipped...
HighandLow is offline
post #6 of 20 Old 09-25-2013, 05:05 PM
brianjw
The axle side on the front lower control arm has a square cut out, so you could punch out a larger opening and use a cam washer. Without a proper sized washed the bolt can move around in there (of course torque helps keep it there). Either my synergy bolt kit or aev lift came with the proper sized washer, there are also specific washers for them from other sources.
brianjw is offline
post #7 of 20 Old 09-25-2013, 06:09 PM
SoK66
2009 JK Wrangler
This ^^^^ . I replaced all of the factory 14mm threaded bolts with 9/16" shoulered grade 8s, sourced from the local Ace Hardware. However, the Synergy kit is cheaper and a one-stop shop. Whatever, do it and do get the cam bolt eliminators from Synergy, Teraflex, etc.
SoK66 is offline
post #8 of 20 Old 09-25-2013, 08:37 PM
HighandLow
HighandLow's Avatar
2010 JK Wrangler
Thank you, I'll check that out. My geo correction kit came with sleeves for the frame side bolts and my Northridge upgrade bolt kit did not come with instructions. So obviously I have bolts left over. Replaced track bar bolts on both sides after SS relocation and geo correction. It drives straight and true but I feel a little "click" here and there.
post #9 of 20 Old 09-25-2013, 08:52 PM
SubAtomicGenius
2011 JK Wrangler
If you're buying the whole kit, you're better off going with Synergy's complete kit.
SubAtomicGenius is offline
post #10 of 20 Old 09-29-2013, 01:32 PM
Notchman
I went with the Northridge 4X4 Jeep JK Grade 8 Hardware Kit and have been very pleased with it. Also, since I live a mile away from them I had them do the install also
Notchman is offline
post #11 of 20 Old 09-30-2013, 09:06 AM
Maertz
2009 JK Wrangler
these are all a good idea, i have slowly swapped all of them to grade 8 standard. (No more metric) Also dont think grade 5 will work anywhere....it wont. Except on your swaybar...
Maertz is offline
post #12 of 20 Old 09-30-2013, 09:12 AM
73azbronco
I'm curious, is this an all year jeep issues as in JK included? So did jeep make the holes for English thread but buy metric or what ?
73azbronco is offline
post #13 of 20 Old 10-01-2013, 10:31 AM
SoK66
2009 JK Wrangler
Yes, apples to all since '07. Jeep uses 14mm standard bolts (non-shouldered) but the holes are 9/16". Factory torque spec is 125 ft lbs, but in my experience the actual is more like 150 ft lbs or more. Bolts are not only undersize, but thier threads act lika a rat tail file on the bracket holes.
SoK66 is offline
post #14 of 20 Old 10-01-2013, 02:48 PM
bluerockymtn
Would this be noticeable for street driven jeeps as well?
bluerockymtn is offline
post #15 of 20 Old 10-01-2013, 03:03 PM
Maertz
2009 JK Wrangler
Yes sir there's always lots of force and pressure on that. Try and drive without the front track bar once and see for yourself self. Even just taking it out and steering its pretty crazy how much the front moves.
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
