Jk tow capacity? - JeepForum.com
post #1 of 11 Old 06-16-2010, 12:26 PM Thread Starter
ItsaFinRubicon
Jk tow capacity?
I know the TJ's can tow 2k lbs / 3.5k lbs unlimited.
What are the JK's Tow capacity regular and unlimited?
thanks
mike
|R.C. 4"|PSC|Smittybilt|35" KM1|QTec|R.C.|
Originally Posted by Dtowngoalie View Post
rausch frock rauschhhhhhhhhhhh
Originally Posted by ajamison View Post
trails frock trailssssss!
ItsaFinRubicon is offline
post #2 of 11 Old 06-16-2010, 12:28 PM
N2rock
N2rock's Avatar
2dr = 2000lb
4dr = 3500lb
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #3 of 11 Old 06-16-2010, 12:37 PM
jimkonow
if you think you can tow it, do so safely. if you question it, you probably shouldnt tow it. thats my rule
Originally Posted by Xerxes View Post
I need $$$$$$$ for O|||||||O
jimkonow is offline
post #4 of 11 Old 06-16-2010, 01:06 PM
Grinner
2010 JK Wrangler
The JK 2-door can tow more than 2k pounds. Can it stop more than that? I dunno I tow a 17ft fiberglass boat that's around there and it feels fine, both power-wise and brake-wise. But I wouldn't want to tow much more. Maybe an 18ft fiberglass boat with a 4 cyl engine is about it...
Grinner is offline
post #5 of 11 Old 06-16-2010, 01:30 PM Thread Starter
ItsaFinRubicon
thanks alot!!
post #6 of 11 Old 06-16-2010, 04:42 PM
texasflusher
2010 JK Wrangler
When we bought our 2-dr JK, we thought it had a 2000lb towing capacity. Afterward, we found out due to our low 3.21 gear ratio it only tows 1000lbs and were quite shocked. Fortunately, we have been towing our dual jet skis at around 1500lbs without any problems. Check your gear ratio.
texasflusher is offline
post #7 of 11 Old 06-16-2010, 04:56 PM
ronjenx
ronjenx's Avatar
Originally Posted by N2rock View Post
2dr = 2000lb
4dr = 3500lb
Not that simple.
As stated above, 3.21 gears limits the listed capacity to 1000 lbs on both 2dr and 4dr.
ronjenx is offline
post #8 of 11 Old 06-16-2010, 04:57 PM
MacK
2015 JK Wrangler
Yea, if it's 3.21 your max tow is 1000lbs. Which is crappy for hills... if you plan on towing, go for 3.73+ ratio. Short wheel base doesn't help.
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline
post #9 of 11 Old 06-16-2010, 07:02 PM
BeerMonkeY
i towed my camper a few times with my 2 door which is around 2500 dry, and it did fine, camper has electric brakes, jeep was a 6spd rubi. ive since went to a 4 door rubi though
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
BeerMonkeY is offline
post #10 of 11 Old 06-16-2010, 07:28 PM
Grinner
2010 JK Wrangler
Sorry. I should have mentioned I'm 2 door, **towing package**, 6sp, 3.73. Trailer has a single axle and no brakes. Relying 100% on my Jeep's brakes for stopping. Totally comfortable towing a small runabout.
Grinner is offline
post #11 of 11 Old 06-17-2010, 11:24 AM
CDavisJK
2009 JK Wrangler
The 3.21s don't matter that much. If youre stick just stay in 4th or 5th and if youre auto turn over drive off or even manually shift it in slow/steep spots.
CDavisJK is offline
oil capacity 4.0 snofrog TJ Wrangler Technical Forum 10 05-13-2016 12:15 PM
D44 Capacity ribbitt617 TJ Wrangler Technical Forum 2 01-03-2007 01:12 PM
Oil Capacity 4.0 billy boy TJ Wrangler Technical Forum 3 12-01-2006 11:12 AM
Oil capacity of 8.8 sequel YJ Wrangler Technical Forum 6 10-15-2006 07:58 PM
4.0 oil capacity? ian-X TJ Wrangler Technical Forum 2 10-04-2003 12:15 PM
