Quantcast JK or TJ Rubicon - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > JK or TJ Rubicon
Old 11-27-2008, 12:52 AM   #46
Xtremjeepn
Originally Posted by JeeperSC View Post
With comparable modifications a JK could perform just as well, mabey better then a TJ.
Maybe? Now thats funny. The JK was designed to out perform the TJ. What good would it do to redesign a vehicle to perform worse than it's predesessor on it's number one selling feature?
Cole Ford
Xtremjeepn is offline   Reply With Quote
Old 11-27-2008, 04:04 AM   #47
JeeperSC
Ok, then what about it makes a JK out peform the TJ off road? Is a stock 2009 Ruby going to hands down run circles around a 2006 Ruby?
btw, automakers have redesigned vehicles to perform worse then the previous models and it not hurt sales. in 1992 ford stopped making the 5.0L foxbody mustangs. By 2006, the mustang had a heavier body and a 4.6L modular motor which made the poor muscle car a complete turd. That didnt hurt mustang sales, infact mustang still out sold the camaro and firebird which were the two other cars in the mustangs class.
2008 Wrangler Unlimited-X 4x4
Steel Blue Metallic
JeeperSC is offline   Reply With Quote
Old 11-27-2008, 04:05 AM   #48
JeeperSC
Steel Blue Metallic
Old 11-27-2008, 04:05 AM   #49
JeeperSC
Steel Blue Metallic
Old 11-27-2008, 04:05 AM   #50
JeeperSC
Steel Blue Metallic
Old 11-27-2008, 04:06 AM   #51
JeeperSC
Steel Blue Metallic
Old 11-27-2008, 04:06 AM   #52
JeeperSC
Steel Blue Metallic
Old 11-27-2008, 04:07 AM   #53
JeeperSC
Steel Blue Metallic
Old 11-27-2008, 09:46 AM   #54
Xtremjeepn
Engine performance and vehicle weight have plauged all of the auto industry with tighter emmisions and safety standards. Those are what hurt the Mustang.
A stock 2007+ Rub should hands down perform better off road than a stock 2006 Rubi in 99% of situations and here is why......
-Scroll up and look at the pictures again and you will see.
-Better approach & departure angles
-More under chassis ground clearance
-Longer wheelbase, but shorter total chassis.
-Wider track width. (which is the first thing 99% of Jeepers do by adding offset wheels on older Jeeps
-Things you can't see in the picture.
-Bigger stronger axles(total redesign that only share the name and cover.
-High pinion front, not only stronger but keeps the front drive shaft out of the rocks
-More 50/50 weight distribution
-Larger tires stock
-Bigger fender openings stock
-Larger rim size stock will side hill better
-Bigger stock driveshafts
-Longer control arms equal more flex stock
-Auto sway bar stock (since disconnecting would be considered a mod on a TJ if we are comparing stock)
-Stronger frame
-Computer controlled throttle and engine management in 4 low to prevent bounce
The only situation where I see the TJ having any advantage would be trying to fit through a body width rock squeeze. In the real world I have yet to find one that is exactly the width of a TJ. My TJ had rockers with rail/steps on them that would end up being wider than my JK is now in total.
Once you start changing things the JK should be easier to get to a higher level of performance. If you toss enough money at anything you can make it great off road. But things as simple as removing the stock JK bumpers and flares make it drasticly differnent than a stock TJ with the same items removed. (almost a buggy profile on the JK right out of the box with the semi comp cut rear and narrowed front. )
Cole Ford
Old 11-27-2008, 09:58 AM   #55
N2rock
N2rock's Avatar
Here's some good reading on the subject
http://www.jpmagazine.com/roadtests/154_0611_2007_wrangler_jk_pros_and_cons/index.html
for details and info on our JK's, check out http://n2rock.com
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline   Reply With Quote
Old 11-27-2008, 10:21 AM   #56
Xtremjeepn
Good stuff.
Cole Ford
Old 11-27-2008, 04:23 PM   #57
odwaud
stock for stock you can debate that a JK is better offroad than a TJ, but most of us here don't have stock jeeps. if you are going to build a rock crawler you are going to start with a TJ not a JK, why? because JK's cost more to upgrade and are harder to work on.
4.0L 5 Speed 2000 TJ.
4.5 in lift composed of RE, JKS, and Skyjacker suspension parts. Currie HD steering
Smittybuilt SRC bumper. AtoZ Rockers. 33" MT Baja Claws
odwaud is offline   Reply With Quote
Old 11-27-2008, 05:07 PM   #58
N2rock
N2rock's Avatar
I say its because the stock JK just plain costs more to buy, than an old TJ... But I know 2 guys that are in the process of building rock crawler JK's.
Old 11-27-2008, 06:46 PM   #59
terrahawk
A. If I am going to build a dedicated rock crawler, I'm not going to use a Jeep at all. I'll build a tube chassis and go from there.
B. Other than bumpers, which aren't necessaay anyway, modding a JK isn't really more expensive than modding a TJ.
C. Define harder to work on.... My wrenches work the same on my JK as they did my TJ.
Speed has never killed anyone - suddenly becoming stationary, that's what gets you!
terrahawk is offline   Reply With Quote
Old 11-27-2008, 06:56 PM   #60
CDNBEAR2009JEEP
Crikey, . I got the point the 1st time you posted, but 7 times in total is really make a point, .
CDNBEAR2009JEEP is offline   Reply With Quote
Glock Forum
