JK Tires - JeepForum.com
post #1 of 42 Old 04-28-2012, 06:12 AM Thread Starter
Bengal4X4
JK Tires
So I don't know where people get information about tires but everything I have read says not to try 35's without a lift. Well I have a 2012 Unlimited and I just got 35's put on and the only thing that rubbed was the plastic piece under the front bumper, which with a little triming does not rub any more. So for anyone out there I have proof 35's will fit with NO lift. I do plan on a lift but just got the tires first. I have Nitto Trail Grapplers.
Bengal4X4 is offline
post #2 of 42 Old 04-28-2012, 06:17 AM
Tanimal
http://www.jeepforum.com/forum/f96/no-lift-37s-1347221/
37s fit with no lift too....
Aren't you rubbing at full turn though? And aren't speed bumps just owning you?
Learning as I go and it's worth every penny!
Tanimal is offline
post #3 of 42 Old 04-28-2012, 06:41 AM
jrmars07
2010 JK Wrangler
rub on the highway or rub on the trails??? Also what BS wheeel did you use?
2010 2dr Wrangler
2.5" ProComp Lift, Front Adj Trackbar, JKS Disco's
Fox Shocks
Tera Front Lower Controls Arms, Rear Upper Control Arms, Synergy HD Balljoints
Tom Woods 1310 Driveshafts
33" KM2's on ProComp 7069 16x8's
Superchips Flashpaq
AEV Premium Front Bumper, IPF 900XSD Lights, Warn 9.5ti w/ Synthetic Line
AEV Rear Bumper, Tuffy Security Deck
D30 Front Sleeved and Gusseted, RCV's, ARB Locked
4.88 G2 Gears
D44 Rear ARB Locked, Chromoly Shafts
jrmars07 is offline
post #4 of 42 Old 04-28-2012, 06:58 AM
yellowjp79
Bengal can you put some pics up please. I have a buddy that wants my rubi rims and tires and I'm gonna upgrade soon. I might pull the trigger today and place the order.
2008 JK 2 DR Steel Blue Rubicon: 3.5" Suspension lift, Adjustable front and rear track bars, Smittybilt SRC Rock Sliders, 325/65/18 ProComp Xtreme AT 18x9" KMC Monsters, Warn Elite Series Front Bumper w/ Smittybilt X2O 8000 Winch
yellowjp79 is offline
post #5 of 42 Old 04-28-2012, 08:23 AM
carlson
carlson's Avatar
Here's my JKU running 35's and no lift (yet). I also have bushwacker flat fenders. I also cut down the rubi rails and cut the pinch seam.
2012 Black Rubicon Unlimited
2.5 Max Travel Rock Krawler Lift
Bushwacker Flat Fenders
35" Goodyear Duratracs
carlson is offline
post #6 of 42 Old 04-28-2012, 11:24 AM
MKWrangler
Go offroad and flex the suspension. I bet something will rub.
MKWrangler is offline
post #7 of 42 Old 04-28-2012, 11:27 AM
Godholio
That'll probably hit going over railroad tracks or a speed bump above 5mph.
Godholio is offline
post #8 of 42 Old 04-28-2012, 11:50 AM
Brian_in_MT
This has to be a troll post from the jk-forum crowd. No one is this stupid.
OP, if you are really that stupid, please go out and flex your suspension a couple of times, then post pics of what your Jeep looks like with the fenders ripped off of it.
Brian_in_MT is offline
post #9 of 42 Old 04-28-2012, 01:13 PM
WXman
As soon as he flexes, those rear flares are gone.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #10 of 42 Old 04-28-2012, 01:34 PM
SubAtomicGenius
2011 JK Wrangler
Yup, loosen off your swaybar connections on the front and give it to her! You'll be alright....
...RRRRIIIIIIPPPPP!!!!...
Also, there is a big difference between running "no lift 35's" and "flat flares and trimmed pinch seams with 35's" - though I wouldn't do either.
SubAtomicGenius is offline
post #11 of 42 Old 04-28-2012, 04:09 PM
carlson
carlson's Avatar
No doubt 35's with no lift will rub flexed but they can be run for street use (even speed bumps and railroad tracks) until a lift is bought. I don't think anyone here plans on running 35's without lift for very long...just long enough to afford the perfect lift
carlson is offline
post #12 of 42 Old 04-28-2012, 06:56 PM
crush127
Trust me Carlson I have 35's on with a 2.5 inch lift and when im on the highway and I have people in the back seat while rolling over a small dip or unevenness surface in the roadway.... Grrrrsh ... Tires scrape underside of my fender.
crush127 is offline
post #13 of 42 Old 04-29-2012, 06:20 AM
carlson
carlson's Avatar
Interesting...From all my research on here I figured the best way to run 35" was with a 2.5" lift and flat fenders (keeping a low COG) I planned on the 2.5 RK max travel lift. Is this not enough?
carlson is offline
post #14 of 42 Old 04-29-2012, 06:50 AM
Perkalater79
Running 295/70 17 (~33.4x12) Nitto Terra Grapplers. Bushwacker flat fenders. Hanson front and rear bumpers and a 9000 lbs Warn winch. Got 1.5" spring spacer on the front the level it out. 3/4" is all you need stock, but to accommodate the added weight from the bumper and winch I needed a little extra.
I took these flex shots a while ago... sitting on the bump stop on the rear, I had maybe 1/4" before my rear tires rubbed the fender flares in the inside of the wheel well.
I know a friend running 35s and no lift. No rub whatsoever. He has some kind of fender, but I'm not sure what. He also cut the pitch seem.
here's mine...
Perkalater79 is offline
post #15 of 42 Old 04-29-2012, 06:52 AM
ncb
2.5" of lift is enough if the bump stops are the correct length.
ncb is offline
2004 Rubicon, questions about 2" lift, 32" tires, safe? no uneven tires? what kind? awalp TJ Wrangler Technical Forum 113 06-09-2011 06:09 PM
Help me with a logical solution for wheels/tires for my JK (want bigger tires) jcole JK Wrangler Technical Forum 8 01-27-2010 06:47 PM
TIRES PAST FENDER FLARES 15.5 in wide TIRES!!!! johnjr602 TJ Wrangler Technical Forum 57 10-14-2009 05:50 PM
What tires size tires are you running on a 3 inch lift afaletto YJ Wrangler Technical Forum 8 07-01-2009 01:04 PM
31" Tires and Stock Tires on New Wheels arcteryx23 TJ Wrangler Technical Forum 9 01-18-2006 09:26 PM
