Is Jk TC same in Rubi? - Page 2 - JeepForum.com
post #16 of 21 Old 08-01-2010, 09:58 AM
tavic
2010 JK Wrangler
Swapping cases is easier, but it is far cheaper to buy the guts than a whole assembly.
tavic is offline
post #17 of 21 Old 08-01-2010, 10:06 AM
MilitaryJK4455
2010 JK Wrangler
Where would you get just the guts?
MilitaryJK4455 is offline
post #18 of 21 Old 08-01-2010, 10:17 AM
tavic
2010 JK Wrangler
The only major differences I see is that 241OR chain is longer and the drive and driven sprockets are larger.
tavic is offline
post #19 of 21 Old 08-01-2010, 10:27 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Doing a little research on this - help me out or add some corrections. The 241-J tcase seems to come from the TJ rubi and I did not find any reference to a newer one. The JK info I found indicates the 241 Command Trac was in the non-rubis and the 241 OR was in the rubis...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #20 of 21 Old 08-04-2010, 05:03 PM
tavic
2010 JK Wrangler
Ok, I'm still digging up data on this one fellas.
But this what I've come up with so far...
The NV241OR is completely different beast from the NV241J...however there is NV241 HD that has the 4:1 Ratio (The data plate indicates NV241J). At this time I'm checking on seeing if those two are basically the same, plus the NV241J HD might replacing the NV241OR, but I'm waiting on a confirmation.
tavic is offline
post #21 of 21 Old 08-04-2010, 05:20 PM Thread Starter
bobthetj03
Did you get my PM. Did that Mopar part # help?
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
difference , interchangable , JK Wrangler , rubicon , swap , transfer case , wrangler
Rubi shocks when changing to rubi springs? DocJake JK Wrangler Technical Forum 1 10-13-2009 09:36 PM
Rubi D44 thick gear in a non Rubi D44? mobyjeep TJ Wrangler Technical Forum 11 07-05-2009 06:00 PM
Rear Rubi locker in front Rubi axle. NotURMailman TJ Wrangler Technical Forum 4 05-08-2009 11:56 PM
Need to know Stock 05 Rubi Shock Lengths (Rancho 2.5" shocks on stock Rubi) jtice TJ Wrangler Technical Forum 2 09-24-2008 11:45 AM
getting rubi lockers to work in a non-rubi got_4_lo TJ Wrangler Technical Forum 1 06-10-2006 06:25 AM
