JK suspensions - JeepForum.com
post #1 of 4 Old 09-11-2009, 04:40 PM Thread Starter
Blu-Jacket
2009 JK Wrangler
JK suspensions
Hey Guys,
What are the differences between the normal and the performance suspensions that are listed for the JK. I've been looking at a loaded 09 X and the Rubicon. Dealer wasn't able to answer the question.
Blu-Jacket is offline
post #2 of 4 Old 09-11-2009, 04:47 PM
IHLXJ
Idk if you meant the axles and stuff when you said suspension, but I think the only difference the Rubicon has from the X is basically that it has D44's front and rear, lockers, 4:1 transfer case, swaybar disconnects, and 4:10 gears.
Idk i could be missing sruff
IHLXJ is offline
post #3 of 4 Old 09-11-2009, 04:56 PM
USAntigoon
Retired from Forum
All these different springs are there for a reason. I just looked into the parts catalog and noticed close to 20 different part numbers... Why.. May be it is related to wheelbase, vehicle weight load per axle... I am sure they all have different spring rates and free length.. This combined with axle load will define spring frequency..
I wonder why...might it be to control DW...
USAntigoon is offline
post #4 of 4 Old 09-12-2009, 02:17 PM
dparkhill
the difference is shocks, gears, skid plates.and tires i think. should give alittle bit more ground clearence for off road
07 jk unlimited, 4" rough country, 315/75/16 mt atz
dparkhill is offline
BDS suspensions Tim70 TJ Wrangler Technical Forum 27 10-06-2008 12:23 PM
YJ suspensions Obcean2 YJ Wrangler Technical Forum 25 01-08-2008 09:29 PM
Bds Suspensions & Wtf To Buy jbpdog TJ Wrangler Technical Forum 10 04-14-2006 01:35 PM
BDS Suspensions matty133 TJ Wrangler Technical Forum 4 03-08-2006 12:53 AM
RCD Suspensions Six Shooter YJ Wrangler Technical Forum 1 12-05-2003 07:22 AM
