JK Stock Curb Height Measurements - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > JK Stock Curb Height Measurements
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 02-24-2014, 09:13 PM   #1
ronjenx
ronjenx's Avatar
I have seen some questions regarding stock ride height.
The vehicle suspension height should be measured before performing wheel alignment procedure. Also when front suspension components have been replaced. This measure must be performed with the vehicle supporting it's own weight and taken on both sides of the vehicle.
Front and rear curb heights are not adjustable. The spring selections determine curb height for acceptable appearance of the vehicle.
Curb height dimensions assume full fluids (including fuel) and zero passengers.
Refer to the pictures below for front and rear curb height dimensions.
Vehicle curb height audits should be performed utilizing the following procedure:
NOTE: Make sure the vehicle is in 2WD when checking curb height.
1. Bounce the front of the vehicle five times.
2. Measure and record the dimensions
Front – On each side of the vehicle, measure the distance from the bottom of the jounce bumper cup to the top lip of the inner spring seat on axle.
Rear – On each side of the vehicle, measure the distance from the bottom of the jounce bumper cup to the top of the rear axle.
ronjenx is offline   Reply With Quote Quick reply to this message
Unread 02-25-2014, 08:55 AM   #2
222Doc
222Doc's Avatar
Thanks i was wonder how my lift settled in after about 3 years. my 3.5 lift is still at 4+ front. at 8" from jounce bumper cup to the top lip of the inner spring seat. with a 50/50 ratio of 5 up and 5 down.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 09-13-2014, 10:35 AM   #3
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
So if I get this straight - at the front/rear, heights are (lwb) - 2.48/4.01, 3.66/5.19 or 3.81/5.35. Three different factory heights.
First I've seen of any written data - but I was always told the Rubi is already lifted from the factory.
Now if only I could remember which forum member it was who soundly "corrected" me when I repeated my anecdotal knowledge of this by stating there are three stock heights and the Rubi comes in at the tallest.... and refuted me saying there are no different "lift heights" for trim levels - only different spring rates to yield the same height on different weighted vehicles.
So the question I asked two years ago (what height is the base for lift) has finally been answered. When planning where you will end up - use the 4X2 as the base and add lift kit advertised lift - then subtract model height. Of course a PUCK lift will raise the thickness of the puck period.
IE:
Rubi/ 2.5 lift
Front - 2.48+2.5= 4.98, 4.98-3.81= 1.17" above stock on a Rubi.
Rear - 4.01+2.5= 6.5, 6.5-5.35= 1.15 above on Unlimited Rubi, 1.25 on two door.
The range is +.98 to -.47 (a 1.5 inch spread) so NEW it should see all of 2 all around and "settle" over the years (or with the addition of weight) to the above 1.15ish area.
Just measured mine and its right in that ballpark. +.75 for the spacers I am running as a test for desired install height, -.25 for bumpers/winch and I am dead on and in the upper of the range where I expect new springs to be...
J Wm Bishop EA, ASADE
Classy Chassis Customs. Because the only thing that matters is what's UNDER the dress ...
jwmbishop is online now   Reply With Quote Quick reply to this message
Unread 09-13-2014, 11:40 AM   #4
JIMBOX
heh Heh, it was me partner and it wasn't a correction-
Now if only I could remember which forum member it was who soundly "corrected" me when I repeated my anecdotal knowledge of this - and stated there are three stock heights and the Rubi comes in at the tallest.... and refuted me saying there are no different "lift heights" for trim levels - only different spring rates to yield the same height on different weighted vehicles.
It was a statement of variable stock heights and I asked if you concurred !
I wouldn't attempt to correct you or RJ-
I just sometimes(?) look at things differently !
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote Quick reply to this message
Unread 09-13-2014, 11:56 AM   #5
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
JIMBO
No it wasn't you Jim, it was the second post I ever made on the forum over two years ago when trying to figure out how much lift I needed for a target ride height. I think you are thinking of todays exchange between you and slade in the other thread? I was always told 2wd no lift, 4wd 1 inch, Rubi 1.5 so thats what I asked about WAYYYYYY back then - which height does a 2.5 lift add to since lifts do not differentiate for model? And I got TROUNCED for "there are not three factory lift levels by model". I figured I had it wrong until today....
Unread 09-13-2014, 12:09 PM   #6
JIMBOX
RIGHT-and SLADE expanded on the stock height variance-
I still wouldn't wanna try to correct you/RJ/SLADE/222doc and a few others-
I just get mislead when I see advice from TJ/YJ owners, not that they are necessarily wrong, just playing in a different league-
Whatever-
JIMBO
Yellow Jeep No. 683
Unread 04-14-2015, 01:35 PM   #7
OpenTrackRacer
Just the information I was looking for! Super useful!
Thanks!
OpenTrackRacer is offline   Reply With Quote Quick reply to this message
Unread 04-14-2015, 07:52 PM   #8
73azbronco
Something's not right, my back measures right, I get right at 3.2 lift with new Metalcloak 2.5 inch lift rear springs with an empty jeep. The front however shows a lift of only 1/4 inch which is way off. I guess I have non standard jounce tubes even though they look stock?
73azbronco is offline   Reply With Quote Quick reply to this message
