JK Sahara Unlimited w/WK2 Overland Wheels! - JeepForum.com
post #1 of 7 Old 08-03-2011, 10:49 PM Thread Starter
RideDirty
2011 JK Wrangler
MALL CRAWLER ALERT!
I'm gonna get hell for this, I know, but I don't mind a little heckling as long somebody can answer my question. I wanna put the WK2 Overland 20" wheels on my black Sahara Unlimited JK and keep the tire size the same. Here's what I've found in my research:
Stock Sahara wheels are:
18"x7.5"
5"x5" (5"x127mm) Lug Pattern
45mm Offset
6" Backspacing
32" Tires
2011 GC Overland Wheels are:
20"x8"
56mm Offset
6.5" Backspacing
Are those numbers correct? Will it fit? I'm hoping they can just mount right on with no adjustments. I read somewhere that the 18" Sahara wheels mount right on to the WK2, but I want it to be the other way around. I can't post a pic of my idea in the thread because I'm a noob so I uploaded a poorly photoshopped pic of my idea as my profile pic. C'mon, does it really look that bad? I think it looks pretty BAD-A! Thanks in advance for the help! BTW, I have a '99 TJ for off-road. This is my daily driver.
RideDirty is offline
post #2 of 7 Old 08-03-2011, 11:17 PM
Rescue13
Im not exactly sure. But as you posted, the BS is not as large on the WK2 wheels. So it may rub. If it does. Just buy spacers and fix the .5 inch bs difference
Rescue13 is offline
post #3 of 7 Old 08-03-2011, 11:37 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
If those numbers are correct you will need spacers.
A set of 1-1/2" spacers will give the needed clearance and a better look with the tires out at the edge of the flares.
Jim
JLC08JK is offline
post #4 of 7 Old 08-04-2011, 11:46 AM
OregonVette
let's see pictures when you're done. Sounds cool.
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline
post #5 of 7 Old 08-04-2011, 09:14 PM Thread Starter
RideDirty
2011 JK Wrangler
No haters yet? I'm shocked! Thanks fellas! I will definitely post pics when I'm finished.
post #6 of 7 Old 08-05-2011, 08:09 AM
chango
2014 JK Wrangler
Don't forget lots of chrome and a lowering kit too.
Thank you for not posting pictures, BTW. It will keep the hate down.
chango is offline
post #7 of 7 Old 03-03-2013, 01:01 PM
pelzdog
2011 WK
unlimited rims to wk2 overland hemi
HI, The goodyear fortera's on my 2011 GC Overland Hemi are terrible in the snow to the point of them being a safety hazard. I currently run OEM 20's and have located a set of 18's off an Unlimited with good rubber. Hoping to run them in the winter months. Can anyone advise me if they will fit on my Jeep? As I understand, I've got the HD brakes with oversize calipers obviously. Any direction would be appreciated.
pelzdog is offline
$8k off Unlimited Sahara? Where? Shark01 JK Wrangler Technical Forum 39 11-21-2008 05:50 AM
Doing Up A Unlimited Sahara-NEED HELP! 2vpblaze JK Wrangler Technical Forum 12 10-26-2008 07:25 PM
bigger wheels/tires for my sahara unlimited joebabyny JK Wrangler Technical Forum 5 06-05-2007 08:24 PM
Unlimited Rubi vs Unlimited Sahara radrob34 JK Wrangler Technical Forum 3 02-04-2007 08:45 AM
Just got the Unlimited Sahara Cipro JK Wrangler Technical Forum 23 01-12-2007 06:05 AM
