JK Rubicon rear axle shafts - JeepForum.com
View Poll Results: Alloy USA or Superior
Alloy USA 0 0%
Superior 3 100.00%
Bacon 0 0%
Voters: 3. You may not vote on this poll
post #1 of 2 Old 04-15-2011, 12:43 AM Thread Starter
jeeperjk
2009 JK Wrangler
Which ones are better? The Alloy USA look a little cheaper (i.e. $400ish vs $500ish).
jeeperjk is offline
post #2 of 2 Old 04-15-2011, 01:45 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
I like bacon though I think Superior makes better axles.
If you go to their site on the weekend they usually lower the prices by as much as 20%
When I got my rear 35 spline axles they were around $550 on friday and $450 on saturday.
I'm not sure if this is still the case but it's worth a try!
edit;
let's see, here they are for $545.01 on friday > http://www.superioraxlegear.com/ev52...y-p-13811.html
Jim
JLC08JK is offline
Rear axle shafts won't spin to tighten backing plates? thirdeye TJ Wrangler Technical Forum 6 12-22-2010 06:32 AM
Which dana 44 rear axle shafts should i buy? slafferty TJ Wrangler Technical Forum 7 02-22-2010 08:30 PM
Do the rear axle shafts easily pull out like the front shafts? jclark50 TJ Wrangler Technical Forum 2 04-13-2008 10:10 PM
rear axle help can't remove shafts spork40 YJ Wrangler Technical Forum 5 09-11-2005 05:49 PM
How Do I Pull The Axle Shafts On A Ford 8.8 Rear? samsammy23 TJ Wrangler Technical Forum 1 04-03-2004 05:57 PM
