JK rubicon lockers? - JeepForum.com
post #1 of 13 Old 06-02-2006, 09:49 AM Thread Starter
greggradwohl
JK rubicon lockers?
Anyone know who makes the lockers (or have any other relevent info) for the new rubi?
greggradwohl is offline
post #2 of 13 Old 06-02-2006, 10:04 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I'd like to know too.
They sound like Eaton E-Lockers by the way they function and operate, but I haven't seen anything to confirm this.
Wheelin98TJ is offline
post #3 of 13 Old 06-08-2006, 12:49 PM
benthood22
what are the lockers for again?
benthood22 is offline
post #4 of 13 Old 06-08-2006, 01:04 PM
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
LOL (i need a longer post so i'm just waisting room so i can post "LOL ")
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Jakemd98 is offline
post #5 of 13 Old 06-08-2006, 02:09 PM
scottyc
I think you put your gym clothes in them.
scottyc is offline
post #6 of 13 Old 06-08-2006, 03:41 PM
Karamba
Actually, with a new brake actuated limited slip technology (a-la Toyota's ATRAC) you will need lockers much, much less.
Even the base JK will have this technology - and that will allow it to be much more capable then any open diff TJ.
Interesting question is whether Jeep engineers are better then Toyota's and allowed this traction control to work the front axis simulataneously with a rear locker engaged. That's the best combination - as traction control allows for much easier handling then a front locker.
Karamba is offline
post #7 of 13 Old 06-08-2006, 04:50 PM
scottyc
Seriously, though, benthood22, here's some info on lockers.
http://www.4x4abc.com/4WD101/diff_locks.html
http://auto.howstuffworks.com/differential10.htm
Basically, when one wheel is off the ground, it would normally get all the power and would just spin, the other wheel wouldn't move, so neither will the vehicle. A locker locks the two halves of the axle so they spin together, so the wheel on the ground will get some power and your vehicle will go.
As Karamba said, Electronic Traction Control can also help get power to the wheel with traction.
scottyc is offline
post #8 of 13 Old 06-08-2006, 10:47 PM
Karamba
Right. The drawback of ABS based traction control - it will only provide half the possible torque, and it lags - reacts only when a wheel is already slipping - so starting uphill, or crawling up a step is harder. Its advantage over a locker is it preserves steering, and you can just keep it on, without anticipating when you need it. Two quite complimentary traction methods.
Karamba is offline
post #9 of 13 Old 06-18-2006, 10:13 PM
Jakemd98
Jakemd98's Avatar
why do they have to complicate things with electronic crap!!?? I say that the jeep should have 2 axles (mechanicaly locked) 4 tires and 1 motor (plus some more necesary components), and let the driver controll them, not some computer.
Jake Davis
97 Jeep Wrangler
1998 GMC Yukon
Jakemd98 is offline
post #10 of 13 Old 06-19-2006, 07:52 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
The WK has the computer controlled traction control system on it and last weekend in Moab it worked flawlessly going up things that people with lockers were slipping on...
Hells Gate @ Hells Revenge:
I was impressed with the system...worked great.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #11 of 13 Old 06-19-2006, 08:42 AM
fisher836
fisher836's Avatar
That's a bad @ss looking Jeep right there.
Definition of Rubicon:
A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment.
fisher836 is offline
post #12 of 13 Old 06-19-2006, 09:35 AM
kenskis
Actually the WK has more then just traction control, it has Eaton EGerodisc differentials. They work so well when I talked to the guys at AEV about building that Jeep they said they left the differentials alone, becasue they are better then ARB's. The PBS show "Motorweek" once did a test of just the differential (in a GC), and it was incrediable. I can't find the video, but they tested it off road, and on pavement with strategically placed rollers, so different wheels would have traction. The Jeep climbed uphill over any combination of rollers without even slipping a tire. It was all instantaneous.
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
Red 03 TJ sport l OME lift l ARB's front & rear l 4.11 gears l 32X11.50" MTR's l Nth Degree Tummy Tucker l SYE & CV l Nth Degree Dana 44 slider l Nth Degree Oil Pan Skid l JKS adjustable front track bar l KC slimlights l Rock Rails l IPF H4 headlights l Dynamat
kenskis is offline
post #13 of 13 Old 06-19-2006, 10:01 AM
Karamba
Can you read? Those are two different systems, usable in different conditions, each with its own advantages. Once you got ABS sensors in place, making traction control is a matter of some clever code. As you are not capable of braking just one wheel just in time - computer does a much better job at that. And, yeah, it has the off switch.
Luddite.
Karamba is offline
Rubicon Air Lockers vs ARB Lockers MLA 97TJ TJ Wrangler Technical Forum 17 07-09-2012 04:37 PM
How?: Lockers and 4H/4L, etc. with Rubicon 4DR? boltsnnuts JK Wrangler Technical Forum 24 12-30-2009 08:48 AM
Rubicon Lockers billy mo TJ Wrangler Technical Forum 12 05-02-2007 08:05 AM
Rubicon Lockers brt TJ Wrangler Technical Forum 3 02-24-2006 08:39 PM
05 rubicon lockers munzaruby TJ Wrangler Technical Forum 11 02-11-2006 07:03 PM
