Quantcast JK Rubicon Axle & 37" Tire Question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > JK Rubicon Axle & 37" Tire Question
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 04-22-2009, 09:41 PM   #1
ruby red
I have a ’07 JK Rubicon, 2 door. I lifted it with 3” Full Traction Ultimate Lift, Superior 4.88 gears, Tom Wood front & rear driveshafts and 35” Goodyear MT/R. I want to change to 37” tires to try to correct my RPMs that are running too high. My concern was clearance in the wheel well. A friend has a ’97 TJ and admits to knowing little about the newer jeep and since I only wanted an opinion on wheel clearance, I asked him for his opinion. He has not yet looked at the jeep, but this is what he told me in an email.
"What few people understand is that the parts on a Dana 30 that fail/have accelerated wear rates with 37" or larger tires are the exact (!) same parts that are used on a front Rubicon Dana 44 axle. The Rubicon's front Dana 44 uses the exact same axle tubes, u-joints, knuckles, ball joints, inner-C's, outer-C's, and outer axle stub shaft as a Dana 30. And it is those parts that aren't up to 37" or larger tires. The only parts that are different between a Rubicon front Dana 44 and TJ Dana 30 are the ring & pinion gears, center pumpkin (D44 housing), and inner axle shaft. Everything else is the exact same thing as a Dana 30.” Is this correct? I thought the JK had “beefier” axles than the TJ.
"I used to be 'with it', but then they changed what 'it' was. Now what I'm with isn't 'it', and what's 'it' seems weird and scary." ~ Abe Simpson ~
ruby red is offline   Reply With Quote
Old 04-22-2009, 09:47 PM   #2
s1edneck700
rpms too high? i hear 4.88 is spot on for a manual and 35's. most auto owners opt for 5.13's with a 35" tire....what are you spinning at 65mph?
s1edneck700 is offline   Reply With Quote
Old 04-22-2009, 10:01 PM   #3
ruby red
Close to 3000 rpms. I did some research and close to factory would be 4.88 with 38" tires. 38" are more pricey and harder to find, so I was looking at 37".
http://www.4wheelerssupply.com/jkbuildup/2006/11/
Old 04-22-2009, 11:08 PM   #4
Warlord2
Guess it depends on what you call factory. My X came with 29" tires and 4.10 gears, wich is close to 5.13's and 37"s.
I have that same lift and am not sure that 37's would fit without atleast adjusting bump stops. Mines very close to rubbing at full flex with just 35's and last time I was out the rear did have some very small rubbing a friend said. I think a 1" spacer or body lift would give clearance for 37's. Your friend is right about the axles. There has been some small problems running 37's but for $250 plus some welding they can be fixed. Many people are running 37"s without any problems.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline   Reply With Quote
Glock Forum
