JK Rubi springs to JKU Rubi prings - JeepForum.com
post #1 of 7 Old 07-24-2010, 08:21 PM Thread Starter
Vin
Sorry guys, I thought I saved the thread, but I didn't. I searched via the Search feature and just went through the last 15 pages and I can't find the thread.
Someone posted the steps taken to swap springs. It was very quick and to the point. Could someone break it down for me?
Vin is offline
post #2 of 7 Old 07-25-2010, 12:47 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
This thread should answer your questions. http://www.jeepforum.com/forum/f96/w...t+installation
It's a farely easy project. Just take your time and pay attention to the brake lines and wires when you lower the axles. Removing the lower track-bar bolt the sway-bar links and the and the lower shock bolts makes it very easy to lower the axle enough to swap the springs.
Check out that thread and if you have any more questions feel free to ask them here.
Good luck.
Jim
JLC08JK is offline
post #3 of 7 Old 07-25-2010, 01:01 PM Thread Starter
Vin
Good luck.
Thank you, Brother. I never thought of "Swapping Springs" in the search box.
Vin is offline
post #4 of 7 Old 07-25-2010, 01:14 PM
ncb
Make sure you torque all the fasteners to spec with a quality torque wrench. Improperly tightened track bar bolts will lead to death wobble.
ncb is offline
post #5 of 7 Old 07-25-2010, 01:21 PM Thread Starter
Vin
Thanks
Here's a question/afterthought: Will my Rubi Shocks be ok, or should I look for JKU Rubi shocks?
Vin is offline
post #6 of 7 Old 07-25-2010, 04:07 PM
ncb
I think the shocks are identical.
ncb is offline
post #7 of 7 Old 07-25-2010, 06:14 PM Thread Starter
Vin
Awesome. I kept going back and forth in my head why they would or wouldn't be the same.
Vin is offline
coil springs , JK Wrangler , spring installation , spring swap , wrangler
Rubi shocks when changing to rubi springs? DocJake JK Wrangler Technical Forum 1 10-13-2009 08:36 PM
Rubi springs VS stock Sport springs seekrtruth TJ Wrangler Technical Forum 12 08-22-2009 08:58 AM
Rear Rubi locker in front Rubi axle. NotURMailman TJ Wrangler Technical Forum 4 05-08-2009 10:56 PM
Replace Stock Springs with Rubi Springs NewBinCO TJ Wrangler Technical Forum 9 09-01-2006 11:33 PM
rubi springs jeepthing2000 TJ Wrangler Technical Forum 1 10-27-2003 04:49 PM
