JK quirk - JeepForum.com
post #1 of 17 Old 12-18-2006, 08:12 PM Thread Starter
JK_Jeep
JK_Jeep's Avatar
JK quirk
Well I took delivery of my 2007 JK on Friday December 15th.
I am an amateur radio operator (ham).
I usually set my radio up in a new vehicle temporarily to make sure everything works in place.
Here is the quirk I found.
I set the radio on top of the dash above the radio.
When showing off the Jeep to my friends I showed them the digital compass at the speedometer. Well no matter what direction I was the compass was showing South East. I though GREAT 1 day old and it has a problem!
Then I thought hmmmmmmmmm maybe the compass sensor is under the platform I have my amateur radio mounted and the magnet from the radio's speaker may be interfering with it.
Removed the radio and the compass worked fine.
If I find anything else I will pass it on
JK_Jeep is offline
post #2 of 17 Old 12-18-2006, 08:24 PM
tolh13
yes the compass sensor is right under the top piece.you can pull up and the back part(by the windshield) and tilt froward and you will see.
2007 4 dr 6 sp Sahara
magna flow exhaust,airaid intake
2006 Saab 9-3 turbo
1996 Harley (bad boy)
1973 WV thing
mark
tolh13 is offline
post #3 of 17 Old 12-18-2006, 09:36 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
I think the compass sensor is under the top cover just above the radio the precise location you placed the ham radio. I take it the built in speaker of the ham radio is at the bottom chassis?
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #4 of 17 Old 12-18-2006, 09:45 PM Thread Starter
JK_Jeep
JK_Jeep's Avatar
You are correct.
One neat thing I did want to mention is I connected a cable to the output external speaker jack of the ham radio to the AUX input of the Jeep radio and was able to listen to my ham radio with the 7 speaker system
JK_Jeep is offline
post #5 of 17 Old 12-18-2006, 09:54 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Originally Posted by JK_Jeep
You are correct.
I considered doing that a while back, but it was generally agreed this is a bad idea because of the impedance mismatch of the powered speaker output and the line-level aux-input. You may eventually blow the input on your radio... though I don't see any reason you couldn't use a line-level converter like you might use to hook an amplifier with line-level inputs to a radio with no aux output...
I'll be Savvy someday!
neZZr is offline
post #6 of 17 Old 12-18-2006, 10:08 PM Thread Starter
JK_Jeep
JK_Jeep's Avatar
Just an FYI, my ham radio has a switch for either an external speaker or headphones and it does just that, changes the impedance. I switched it to headphones for that exact reason.
here is my radio the second link will show you the speaker/headphone switch on the removable faceplate on the bottom picture on bottom left.
http://www.universal-radio.com/catalog/hamhf/1857.html
http://www.universal-radio.com/catal.../1857frtr.html
JK_Jeep is offline
post #7 of 17 Old 12-18-2006, 10:18 PM Thread Starter
JK_Jeep
JK_Jeep's Avatar
SP/PH Jack
This 3.5-mm, 2-pin jack provides variable audio output for an external
speaker (4 Ω ~ 16 Ω impedance) or earphones. The audio level varies
according to the setting of the front panel’s AF knob.
Important Note: When you insert an earphone plug into this jack, the SP-PH slide
switch (located on the back side of front panel) MUST BE set to the “PH” position, to
prevent the possibility of injury to your ears.
JK_Jeep is offline
post #8 of 17 Old 12-18-2006, 11:16 PM
neZZr
neZZr's Avatar
Cool... but hopefully anyone else that reads the thread will realize they'll need to take that extra step with their radio unless they have that feature, and I don't think I've ever seen that on a CB radio.
neZZr is offline
post #9 of 17 Old 12-19-2006, 02:22 AM
bigwrm
I feel like an idiot, but there is a compass on them? Sweet. Its in the dash? I dont suppose there is an inside/outside temp gauge as well?
bigwrm is offline
post #10 of 17 Old 12-19-2006, 02:32 AM
infosponge
infosponge's Avatar
If you push the trip computer button it cycles through temperature + compass, MPG, DTE, etc. Might only be on the Sahara and Rubicon, I'm not sure.
infosponge is offline
post #11 of 17 Old 12-19-2006, 07:51 AM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
umm. this would appear to be more of an operator quirk than a jk quirk...
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
USN Hull number 54
Poor Boy is offline
post #12 of 17 Old 12-19-2006, 08:32 AM
DShizzle
My daughter is SAXON
DShizzle's Avatar
I have found that on my vehicles most of the "operator quirks" are due to a nut loose behind the steering wheel
"Political Correctness is a Doctrine, fostered by a delusional,
illogical, liberal minority and rabidly promoted by an unscrupulous
mainstream media, which holds forth the proposition that it is entirely
possible to pick up a turd by the clean end".
DShizzle is offline
post #13 of 17 Old 12-19-2006, 11:06 AM
Killian
Killian's Avatar
Also available on the "S" package X unlimited
It is hard enough to remember my opinions, without also remembering my reasons for them!
Friedrich Nietzsche
Killian is offline
post #14 of 17 Old 12-19-2006, 05:12 PM
cliffmelanie1
I must have done the same thing when I mounted my CB up there. The compass was messed up for a day or 2 but seems to be working fine now
05 Rubicon 31/2" RE lift, 305 70 16 Duratracs
cliffmelanie1 is offline
post #15 of 17 Old 12-21-2006, 05:55 AM
bigwrm
That is awesome. I saw a pic somewhere of the little display with the temp and direction. Nothing special, but im waiting for my 4 door ruby and always wanted that. Now I can see with my eyes that the weather is TOO COLD.
bigwrm is offline
Transmission quirk... Apex TJ Wrangler Technical Forum 10 05-20-2009 06:36 PM
Autozone ball joint quirk bigdaddyh YJ Wrangler Technical Forum 6 01-12-2009 06:34 AM
99' TJ starting prob with interesting quirk...help Q-01 TJ Wrangler Technical Forum 2 09-20-2007 07:39 PM
Interesting new quirk with my air/heat YCP4x4 TJ Wrangler Technical Forum 5 04-12-2006 11:26 PM
