JK Questions - JeepForum.com
post #1 of 6 Old 09-04-2012, 07:17 PM Thread Starter
JT29
JK Questions
I currently have an YJ, and thinking about buying a JK, but I have some questions? I would purchase a 4 door hardtop with the I6 and it will be a daily driver.
1. I would like to run 35" tires. Would I need to re-gear it?
2. What size lift would I need for 35" tires?
3. What kind of gas mileage would I get?
4. Can you flat tow a JK?
5. What is the base weight of a JK?
6. Any driveline/axle issues to deal with, with lift and tires?
7. How much (LBS) can a JK tow?
8. Compared to the YJ is the JK quieter sound wise with a hardtop on the road, and more car like?
JT29 is offline
post #2 of 6 Old 09-04-2012, 09:39 PM
janders82
2010 JK Wrangler
I have a 94 YJ and just bought a JKU with hardtop. The JK is a completely different beast and you're gonna love it!
1 & 2. I currently run 33s with no lift. If you're going to hit the trail with 35s a 2.5" should work great. Regear depends on manual or auto and what the JK currently has. I'll be going with 5.13s once I move up, but I'm going with 37s next time around,
3. Gas mileage varies
8. My JK is much quieter with 100% improvement when it comes to road manners than the YJ!!! There's really no comparison
You'll find a lot of your answers in the FAQ section in the JK Tech Forum
2010 JKU Automatic w/ 5.13 Gears
2.5" TeraFlex w/ Rancho XL9000s
17" XD Addicts
295/70/17 Nitto Trail Grapplers
janders82 is offline
post #3 of 6 Old 09-04-2012, 11:34 PM
COLOUXJ
2010 JK Wrangler
First there is no I6 in any JK.
1) Depends on if you get 4.10's or 3.73 gearing
2)2.5 is what is recommended for 35" from what I have seen.
3)16? depends on a lot of different things.
4)Yes
5)JK-4k? JKU-4300ish
6)Have not heard of too much other than death wobble with the stock track bar on some JK's
7)3500
8) Its quieter than my grandpas 06 toyota camry even with MTR's
COLOUXJ is offline
post #4 of 6 Old 09-05-2012, 08:04 AM
JIMBOX
I have an '08 JKUR-modified-
1)-With auto--YUP
2)-Not required if flat fenders used--but 2.5 is suggested
3)-better/w regear-abysmal without
4)-YUP
5)-A JKU is about 4350lbs, mine is 5200lbs
6)-not for a while if driven easily, but uni's and steering will degrade much faster
7)-3500lbs-JKU
8)-Not carlike-ever- but a little quieter, but hardtop insulation is required for the ultimate quiet, for freeway/music/wife advice and backseat driving/easy cell phone use/easy CB use !!!
If you getta 2012/2013-forget items-1/3/6/
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #5 of 6 Old 09-05-2012, 04:33 PM
HappyTrails
JIMBOX pretty well covered it.
I'd add to #6: sleeve and gussets on the front axle if going to 35's and above, especially if going off-road.
Anything over 3" lift, you're looking at new driveshafts, due to the boot getting torn off.
Overall, the JK is the closest Wrangler Jeep has created that resembles a car-like experience. By no means is it a car, it still feels much like a Wranger, but more stable and better handling than previous generations.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #6 of 6 Old 09-05-2012, 04:40 PM
HOKIES2010
2011 JK Wrangler
If you sleeve it go ahead and do gears at the same time, it saves labor.
The drive shaft boot is really only an issue with autos. Upgrade those when it brakes. Id personally spend the cash on axle shafts instead. I got drive shafts and I still have the stock front in at the moment and it's doing fine with a 3.5 lift and 37s.
My Build
Couldn't have done it without
HOKIES2010 is offline
More SYE Questions tjcj TJ Wrangler Technical Forum 5 10-04-2011 06:14 AM
Lift Questions? Tire Questions john304 JK Wrangler Technical Forum 8 01-20-2011 07:31 PM
New Jeep Owner! Questions questions TP3P YJ Wrangler Technical Forum 7 11-01-2010 12:09 PM
2 lug nut questions- Mickey Mouse kind of questions kaybone TJ Wrangler Technical Forum 2 05-04-2005 04:34 PM
questions on my TJ JeeperAbe TJ Wrangler Technical Forum 9 04-16-2005 01:10 PM
