JK oil and oil filter preferences - JeepForum.com
post #1 of 58 Old 04-09-2010, 05:04 PM Thread Starter
tx99wj
2010 JK Wrangler
If this forum is anything like another car forum that I am a member of, this question probably gets asked all the time. I aplogize in advance, I can't seem to get the search to work though, so maybe somone can comment here, or provide a link.
My wife's WJ died a few weeks ago, and we got a brand new 2010 JK. Really, really nice! I'm sure it's got conventional oil in it, just like the WJ always had. I'm thinking about doing the oil changes myself, and switching to fully synthetic. I read a lot of good things about Mobil 1, but never used it, because all my other vehicles are older, and I am afraid seals will start leaking because of better detergents in synthetic.
So, question is, do you guys run synthetic in your JK's, if so, what do you prefer? Viscosity? I'm in a warm climate in TX...
Also, Mobil 1 or other? How long/how many miles between oil changes? I'd really like to limit it to one oil change per year, based on 10.000 miles a year
And what's a good oil filter for the JK? I like the Purolators...
Thanks!
tx99wj is offline
post #2 of 58 Old 04-09-2010, 07:24 PM
HungryHeart
Hey tx, I use regular motor oil, so I won't comment on that, however I do use Fram ToughGuard TG3614 oil filters exclusively because of severe drain back issues I had with most of the other oil filters. Never again had the issue with the Toughguard. Not sure if this helps, but it my 2 cents.
Cheers
-Joe
HungryHeart is offline
post #3 of 58 Old 04-10-2010, 07:02 AM
krutj
2009 JK Wrangler
My JK has a fill cap on the valve cover that states- 5w-20
I know it's thin, but you have to consider your warranty.
I also feel that after 16k, the 3.8l runs kinda dirty. I change oil more frequently than needed, but that's me.
I use Mobil 1 and fram TG filters too.
-- Joel --
krutj is offline
post #4 of 58 Old 04-10-2010, 07:46 AM
mandalayjim
I use Castrol full synthetic in my JK and wife's car. Previous XJ also had synthetic and it had 126K when I sold it.
mandalayjim is offline
post #5 of 58 Old 04-10-2010, 08:10 AM
Tireguy
2009 JK Wrangler
Big fan of Mobil 1. I'm running the 0w-20 Advanced Fuel Economy stuff right now (through the winter). Change it every 6000 miles. Is it used up? Not really, But the oil still gets dirty. I stick with the OE Mopar filters.
Tireguy is offline
post #6 of 58 Old 04-10-2010, 08:17 AM
krutj
2009 JK Wrangler
I've been curious about the new 0w stuff, you liking it?
Thought I saw it was a recommended oil?
-- Joel --
krutj is offline
post #7 of 58 Old 04-10-2010, 08:35 AM
owtdorz
2009 JK Wrangler
Mobil 1 5w20 and Mopar (Wix) filter
Every 3000 miles.
Contrary what you may hear synthetic oil does NOT change your oil change intervals.
If you do wait past 6000 miles per oil change, that will have adverse affects on your warranty.
If something should happen to your engine you will be asked to provide proof of your oil changes.
'09 Detonator Yellow 4dr Rubi, Bestop Element doors, Rugged Ridge XHD w/stinger, Warn 9.5ti, 3.5 Rock Krawler, Woods driveshafts, Hella 500 aux lights, 35x12.5x17 BFG KM2<< THEY SUCK
owtdorz is offline
post #8 of 58 Old 04-10-2010, 08:40 AM
Jiblet
Some folks report low oil pressure on start up due to filters draining back. It seems some filters have anti-drainback valves that aren't up to task. I had been using either mopar (stock) or Mobil1 filters. I got the "knock" with a recent mobil filter and went back to OEM mopar.
As for 10k mile drain interval; if you drive normally then I highly doubt you can get 10k miles out of any oil. Especially in the Texas heat.
The JKs have an oil life monitor system that runs an algorithm based on parameters such as temperature, number of cold starts, revolutions, etc. etc. etc. (it does not actually taste-test the oil, just runs the numbers).
Some folks think the monitors light up "too early" (2500-3000 miles) but many never see the light and just do 5-6000 mile drains. I believe those that think the light comes on too early are just not realistic about their driving habits and that it is not too early at all.
If you get a JK, just follow the OLM but , as recommended by the manual, don't exceed a 6000 mile drain interval.
The manuals suggest 5w-20 but you could very well use 5w-30 during the hot weather down there.
I recomend using a quality brand oil (regular or synthetic)(I like synthetic), a good filter that works for you (I get OEM mopar for $5), and change it at about 5000 miles or when the OLM tells you to change.
Also, it is a good practice to drain oil by six months REGARDLESS of mileage.
Jiblet is offline
post #9 of 58 Old 04-10-2010, 09:14 AM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Mobil-1 5W-30 & Purorator Pure One filter from Advance Auto.
Edit: Valvoline synthethic when on sale.
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #10 of 58 Old 04-10-2010, 10:06 AM
Tireguy
2009 JK Wrangler
Seems to work just fine. No percieved benefits on the 'fuel economy' just yet, Time will tell.
Tireguy is offline
post #11 of 58 Old 04-10-2010, 10:10 AM
rirrgang
5w-20 Mobil 1 and Wix extended length filter. 10k change intervals. Syn is designed to go those distances.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #12 of 58 Old 04-10-2010, 11:13 AM
MAJTodd
I have some Amsoil 0w-20 and Amsoil filter waiting for my next change.
First Jeep the govt. hasn't owned.
Others: C6 Vette and Ducati bike.
MAJTodd is offline
post #13 of 58 Old 04-10-2010, 06:24 PM
Jiblet
There is a lot more to oil life than distance driven. Engine hours, revolutions, cold starts, operating time at/below/above operating temperature, ambient temperatures, etc.
Synthetic oil is designed for low temp pour characteristics and resistance to thermal breakdown. Purity is another benefit. But it isn't really the oil that breaks down, it is the additives. And the accumulation of acids from condensation is another problem.
Don't have to believe me, send your oil for an analysis (Blackstone labs, etc.) and see how much life is left in it at 10,000 miles.
I can not think of a reputable source that suggests going more than 6 months without an oil change.
Its not the miles (or months) per se, it is the operating conditions or actual use of the engine.
Consider this rough example (lifted from a BITOG post, link below)
Mileage has little to do with how oil is monitored, here is the idea:
Car 1:
If you drive 90% of the time on the highway lets say 1500 rpm an hour.
you engine sees 90,000 revolutions in that hour and you drive 60 miles.
Car 2:
If you drive around town, profiling with 90% of your driving in 1st, 2nd, and 3rd gear, taking 4,000 rpm on average. That's 240,000 revolutions of the engine in 1 hour and you only drive 30 miles.
Taking this out to 3 months , 90 days:
Car#1 3,600,000 rpms and 5400 miles
Car#2 21,600,000 rpms and 2700 miles
This represents 1 hour of driving a day for 90 days.
Car #2 sees 6 times the engine duty of car #1 and Only half the mileage
http://www.bobistheoilguy.com/forums...1735142&page=1
Jiblet is offline
post #14 of 58 Old 04-10-2010, 11:05 PM Thread Starter
tx99wj
2010 JK Wrangler
thanks, appreciate y'all sharing experiences. I think i'll go with Mobil 1 5W30, maybe a little lighter for winter, Purolator filter, and change every 6K miiles.....
tx99wj is offline
post #15 of 58 Old 04-11-2010, 02:07 AM
badgerking
I run the Mobil 1 synthetic with Mobil 1 filters. I run the same in my wife's 06 GC and we've never had any problems.
badgerking is offline
Steering Preferences? Yellow TJ TJ Wrangler Technical Forum 20 11-19-2009 01:30 PM
Oil preferences - '03 Wrangler Kingsblue TJ Wrangler Technical Forum 15 10-17-2007 10:44 AM
Lift Kit Preferences madrcer TJ Wrangler Technical Forum 11 10-02-2006 08:39 AM
Tire Preferences Jay Schrader TJ Wrangler Technical Forum 2 07-22-2006 07:49 AM
Oil preferences for a 4.0 nodoor94 YJ Wrangler Technical Forum 1 04-24-2006 09:40 AM
