JK Monstaliner write up - JeepForum.com
post #1 of 16 Old 09-20-2010, 07:52 PM Thread Starter
wdryan85
Ok so i just finished monstalinering my JK.
prep work pics
DSCF0797.jpg   IMG00118-20100917-2022.jpg   DSCF0800.jpg   DSCF0795.jpg   DSCF0799.jpg
wdryan85 is offline
post #2 of 16 Old 09-20-2010, 08:10 PM Thread Starter
wdryan85
Lined pics
IMG00124-20100918-1731.jpg   IMG00125-20100918-1732.jpg   IMG00126-20100918-1732.jpg   IMG00133-20100919-1719.jpg   IMG00134-20100919-1719.jpg
wdryan85 is offline
post #3 of 16 Old 09-20-2010, 08:14 PM Thread Starter
wdryan85
I also have never seen anyone liner the bottom if the tailgate to protect it. Here are some of the pics of that>>>>
wdryan85 is offline
post #4 of 16 Old 09-20-2010, 08:20 PM
Vin
very nice. Did you know you could unclip the wire to the tailgate to get it out of the way?
Vin is offline
post #5 of 16 Old 09-20-2010, 09:39 PM
VeniceCA
2010 JK Wrangler
Nice work. What's the dry time like on that liner? How many coats?
VeniceCA is offline
post #6 of 16 Old 09-20-2010, 10:56 PM
aztec_doc
I have my set up at home. Did you use the one gallon or two. How many coats as listed above. Where did you find u had to use the paint brush the most to get into the small areas? Good looking job. How long from beginning to end?
aztec_doc is offline
post #7 of 16 Old 09-20-2010, 11:18 PM
JKWilly
2010 JK Wrangler
Bad ars job brother!!!! I wish i had some extra time off work to attack some projects like that. OH WAIT, no i don't, then i wouldnt be able to afford the jeep itself!
JKWilly is offline
post #8 of 16 Old 09-21-2010, 03:04 AM
1222
RIP John
1222's Avatar
Nice job and one heck of a project. Are you happy with the results?
(2011-2016)
1222 is offline
post #9 of 16 Old 09-21-2010, 04:07 AM
Warlord2
nice job!
It looks like you took off the sound dampening crap, was wondering how hard that was to take off and what you used. Looks much better without it.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #10 of 16 Old 09-21-2010, 02:38 PM
Slenny
I LR this.
Slenny is offline
post #11 of 16 Old 09-24-2010, 05:05 PM Thread Starter
wdryan85
The project took the 2 coats recommended. So far happy with the results. I started on a friday night with the teardown and some scuffing. Spent saturday finishing the scuffing, tapping off, and rolling it. It says to let the coats dry 4-5 hrs between coats. It only took around 3hrs to get dry, so then I started the second. Let it dry till the next day. It seemed to be dry enough to put it back together. It still does smell inside and its been about a week.
As far as the dampening crap... I only removed the stuff in the back area. Figured I'd leave it up front because I'm leaving floor mats in. I used a wire wheel and a drill. Although I have read some post that a hammer and chisel work. Took me an hr or 2 to clear out. Not sure if you can see but I removed the trunk brackets and welded the holes shut, also added an area to weld a custom trunk in later. I plan on doing it eventually. Just dont have the time right now..... Thanks to all....
Anymore questions let me know....
wdryan85 is offline
post #12 of 16 Old 09-24-2010, 05:10 PM
tjwillis
That looks good. Been wanting to do it to my TJ.
"my biggest fear is that someday I will die and my wife will sell all my stuff for what I told her I paid for it"
tjwillis is offline
post #13 of 16 Old 09-24-2010, 06:58 PM
burlyq
Ran it in my bronco, it is good stuff! it is hard as a rock, stylish, and totally utilitarian.
burlyq is offline
post #14 of 16 Old 09-26-2010, 08:49 AM
aztec_doc
Good job on the truck. Anyone else done this on their JK.
post #15 of 16 Old 09-26-2010, 02:18 PM
mhizzle1341
what's the difference between monstaliner and herculiner...I herculined the inside of my old YJ and it came out pretty good
mhizzle1341 is offline
Monstaliner: A Full Install Write-Up LuckRider TJ Wrangler Technical Forum 520 04-22-2017 01:40 PM
Monstaliner Project (write up)...finally!! aerojeeptj TJ Wrangler Technical Forum 32 10-29-2010 11:18 PM
Monstaliner Write Up - 2006 LJ WILLY348 TJ Wrangler Technical Forum 53 10-19-2010 08:52 PM
Monstaliner???? JERSEYJK JK Wrangler Technical Forum 1 05-28-2010 07:48 AM
POR 15 or Monstaliner Jbecker TJ Wrangler Technical Forum 12 04-06-2010 04:25 AM
