JK Maintenance - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > JK Maintenance
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 12-06-2009, 11:20 PM   #1
waterboarder
JK Maintenance
In case anyone cares....
waterboarder is offline   Reply With Quote
Unread 12-07-2009, 02:22 AM   #2
alaskanthunder
Thanks T-dog
2007 JK 2-dr X | Steel Blue | 4.10 Auto D44
alaskanthunder is offline   Reply With Quote
Unread 12-07-2009, 02:55 AM   #3
waterboarder
Local Jiffy Lube place is still charging the better part of $100 for an oil change with 6 qts of synthetic - and, I assume, a really crappy filter. So I'm saving about $60 each time I do it myself.
Chart also shows a $140 difference between changing the diff fluids myself, rather than having the dealer do it.
Chart also shows the cost of changing the t-case fluid is practically nothing, so why not do it when changing diff fluids every 15K miles, rather than the every 60K miles the owner's manual calls for? It asks you to inspect every 15K miles, but frankly, if you're going to go through the trouble of taking the skid plate off and removing the plug so you can check out the fluid, you might as well just replace it for $8-9 while you're there.
In case anyone is wondering - I'm guessing that what I was referring to as "Next Due at 50,000 miles" with the tires I put on at 13,157 miles is the life expectancy of the tires - but frankly, I'm just guessing. I'm not entirely sure why I put that value in there (:
M1 = Mobile 1 Oil. I get the 5 QT container of 5w20 from Walmart for $22 (doesn't seem to be available anywhere else). I got the diff fluid from a local Mobile 1 distributor, at a slight cost savings, plus additional cost savings from buying a case (and splitting with someone else). I think I have enough diff fluid on hand for 3 or 4 more changes (:
K&N HP-1002 oil filters have gone up. Used to be able to get them locally for $10. Now that place has them for $18. I got the one today from Napa for $14 (and they had just one). I'm going to start buying them on-line for $12 from (Amazon.com: K&N HP-1002 Oil Filter: Automotive) Amazon I guess. I need to order 4-5 next time I order something from Amazon.
I guess that's about it for notations (:
Unread 12-07-2009, 08:00 AM   #4
MattJK09
2009 JK Wrangler
nice write up. I think I'm going to follow suit and start documenting my service as well. I guess I don't ned to rotate my tires at every 3k oil change though. I think I will do every other at 6k like you are doing....
09 X 23S Flame Red 2door, tinted, Black Rock 997's, BFG 32" MT's, grab handles, RR XHD front bumper,BW trail armor,4door springs up front, KC's
MattJK09 is offline   Reply With Quote
Unread 12-07-2009, 08:44 AM   #5
PanthersFan
Not old, just older
PanthersFan's Avatar
Do you only put 5 quarts in? Or do you buy an extra quart to get to the 6 quarts specified in the manual?
THE Conventions of a number of the States, having at the time of their adopting the Constitution, expressed a desire, in order to prevent misconstruction or abuse of its powers, that further declaratory and restrictive clauses should be added: And as extending the ground of public confidence in the Government, will best ensure the beneficent ends of its institution.
PanthersFan is offline   Reply With Quote
Unread 12-07-2009, 08:50 AM   #6
ctown67
i am sure that is misleading. did you need new tires at 13k or just upgrade? Price looks steep too.
List of stock parts that have been eviscerated.
power steering pump, tie rod, front left knuckle, horn, weld on rear track bar, rear track bar bracket, both rear fenders, front passenger fender, punctured spare tire, rear bar pins, steering stabilizer shock, front drivers side shock, spare tire carrier.
ctown67 is offline   Reply With Quote
Unread 12-07-2009, 09:09 AM   #7
McKBrew
JK Wrangler
That's the price of living in Alaska.
McKBrew is offline   Reply With Quote
Unread 12-07-2009, 09:36 AM   #8
08rubinewb
It's the price of staying with 18 inch tires too. Nice write up btw I really need to get on top of some maintence. Just rolled over 15k.
08rubinewb is offline   Reply With Quote
Unread 12-07-2009, 09:46 AM   #9
ctown67
i can get 4 35" tires on 18s for 1,200.00 M&B.
No doubt t-dog/waterboarder just ticked off the shop owner----if you can believe that!
Unread 12-07-2009, 11:10 AM   #10
BadHammers
Now its $26 at Walmart.
They've really been jacking up prices lately.
BadHammers is offline   Reply With Quote
Unread 12-07-2009, 11:15 AM   #11
MattJK09
2009 JK Wrangler
Uh oh! I didn't know it went up. Oh well........Gotta have earl (oil).
Unread 12-07-2009, 11:19 AM   #12
wTheOnew
He got 5, so it works out the same.
Georgia Institute
of
Technology
GA Trail Riders
wTheOnew is offline   Reply With Quote
Unread 12-07-2009, 11:20 AM   #13
08rubinewb
You could but he bought 5
Unread 12-07-2009, 11:21 AM   #14
JeffinWesternWA
2010 JK Wrangler
Wish the synthetic 5w-20 or even better the 0W-20 was sold in jugs here in westernwa, only the 5w and 10w 30in M1 and Penzoil at wal-mart that way.....much cheaper via 5qt jugs
JeffinWesternWA
JeffinWesternWA is offline   Reply With Quote
Unread 12-07-2009, 12:55 PM   #15
waterboarder
Of course I put 6 quarts in (:
I buy the 5 qt containers and measure out a 6th quart - a lot cheaper than buying a 1 qt bottle (:
On the tires - I upgraded (didn't wear out the stockers), and yes, they were pricey.
