Jk key remote with remote start? - JeepForum.com
post #1 of 14 Old 09-03-2015, 07:19 PM Thread Starter
vfrpilot
Hey all..
I've been DIY programming my own key fobs / Chipped keys for years.
When I got my 08' JK; the PO only had one key
I wanna pick up a couple chipped keys so I can have spares stored throughout my regular spots (vaca house, bro house, work, etc).
Problem is; I haven't been able to find a 4 button Key remote?!?
I've found the regular Panic/Lock/Unlock.. But I need the 4 button to assign the remote start too..
Any help, links will be appreciated
08' JKU 3.8 Lifted
AEV, EMU, LED, 33" NITTO GRAPPLERS
93' YJ
01' TJ
vfrpilot is offline
post #2 of 14 Old 09-04-2015, 10:09 AM
79cj7amc304auto
Check because I think the remote start function can be programmed by hitting the "lock" button like two or three times. U shouldn't need a dedicated key button for remote start.
79cj7amc304auto is offline
post #3 of 14 Old 09-06-2015, 08:36 PM
rich6700
The guy above is correct. You hit the lock button 3 times for remote start.
rich6700 is offline
post #4 of 14 Old 09-06-2015, 09:13 PM
Neo1130
2015 JK Wrangler
So I take it there is no way for a Jeep without remote start to program it to have it or are there other parts needed?
Neo1130 is offline
post #5 of 14 Old 09-06-2015, 09:22 PM
79cj7amc304auto
I ordered an aftermarket remote start module and spliced it in under the steering wheel. Got it on eBay but can't recall which brand I got. Works perfect. A Google search should pull up the best makers and go from there. It's an easy 20 min upgrade and u keep ur factory key fob.
post #6 of 14 Old 09-06-2015, 09:24 PM
79cj7amc304auto
Another bonus: this upgrade will activate ur factory security alarm light on the dashboard. When u lock ur jeep with the fob, the dash security light will blink like there is a full blown alarm system installed. Cool!!!!
post #7 of 14 Old 09-06-2015, 09:27 PM
79cj7amc304auto
One more thing... The eBay module says its plug and play. That's mostly true but not quite accurate. Actually there is one yellow wire in the module harness which must be spliced into ur factory harness. Choose wisely!!!
post #8 of 14 Old 09-06-2015, 09:58 PM Thread Starter
vfrpilot
Neo: No bud, you can't program "remote start" unless your rig is equipped with it.
Rich/79cj,
Right now, the fob I have HAS 4 buttons - so one is dedicated to the remote start.. I'm thinking it came that way from the factory - So when I get my new replacement DIY program FOBs, I don't think (or even remember) an option to dual program the Lock button to also activate my ignition sequence to start my jeep.
I can see it now;, being in a Home Depot, pointing the remote through the entrance-way to lock er up and instead (unbeknownst to me) Start it up
08' JKU 3.8 Lifted
93' YJ
01' TJ
vfrpilot is offline
post #9 of 14 Old 09-06-2015, 10:02 PM
Matt The Hammer
My 2013 factory key has 4.
Sent from my rotary phone using JeepForum
2013 JKU
1995 YJ
Matt The Hammer is offline
post #10 of 14 Old 09-07-2015, 06:18 AM Thread Starter
vfrpilot
Can you post a pic of your fob?
08' JKU 3.8 Lifted
93' YJ
01' TJ
vfrpilot is offline
post #11 of 14 Old 09-07-2015, 09:12 AM
79cj7amc304auto
Originally Posted by vfrpilot
Neo: No bud, you can't program "remote start" unless your rig is equipped with it. Rich/79cj, Right now, the fob I have HAS 4 buttons - so one is dedicated to the remote start.. I'm thinking it came that way from the factory - So when I get my new replacement DIY program FOBs, I don't think (or even remember) an option to dual program the Lock button to also activate my ignition sequence to start my jeep. I can see it now;, being in a Home Depot, pointing the remote through the entrance-way to lock er up and instead (unbeknownst to me) Start it up
No programming per se should be needed on 3 button fobs. The lock button has to be hit three times. If ya mess up and accidentally start it, it will auto shut-off after ten minutes of idle. Doors remain locked and cannot be driven unless the actual key is inserted. Not sure ya need a 4 button fob but hey whatever. I installed aftermarket module and it didn't come with new fob keys. I reused my factory fobs. No programming needed to get the remote start function to work. It's all in the module brains.
post #12 of 14 Old 09-07-2015, 09:53 AM Thread Starter
vfrpilot
Well, that's good news.. Here's where my 4th is
08' JKU 3.8 Lifted
93' YJ
01' TJ
vfrpilot is offline
post #13 of 14 Old 09-07-2015, 10:40 AM
79cj7amc304auto
Interesting... Well either way u should be able to use whatever u can get. Seems 3 and 4 button fobs will do essentially the same thing. I wouldn't pay an exhorbanent (spelling?) amount for a 4 button fob though.
post #14 of 14 Old 09-07-2015, 10:42 AM Thread Starter
vfrpilot
Oh, yea!
Stealer ship co$t makes even Home Depot's $60 look cheap.
08' JKU 3.8 Lifted
93' YJ
01' TJ
vfrpilot is offline
