JK hitch wiring harness - JeepForum.com
post #1 of 6 Old 06-07-2010, 07:57 AM Thread Starter
Baotchi
Baotchi's Avatar
2010 JK Wrangler
I am getting a hitch installed this week by a local hitch shop and I don't know which harness to buy. Do I need the 7 way round connector from mopar (part 82210214AB) and then get an adapter to connect a flat trailer connector? Which trailers have those round plugs anyway? Can I just get a harness that goes straight to flat 4 way connector?
Thanks
Black 2010 Sport JK
Black 2003 Sport TJ Gone!
Baotchi is offline
post #2 of 6 Old 06-07-2010, 08:01 AM
WaldenL
2009 JK Wrangler
The 7-pin will give you more options, but you'll need to run wires to the front of the Jeep to support it. The 4-wire can hook right into the tail light. You can can a 7-pin to 4-pin adapter in case you need to plug in a 4-pin trailer, so the 7 pin is more versatile. Having said that, I went w/the 4-pin as I mostly use the hitch for bike and cargo racks. I'd really suggest just doing the hookup yourself, it's trivial.
I'm Too Lazy to Search For a Red Rock Crystal Pearl Jeep Club Club - Member #1
WaldenL is offline
post #3 of 6 Old 06-07-2010, 08:04 AM Thread Starter
Baotchi
Baotchi's Avatar
2010 JK Wrangler
Okay thanks for the info. Do you have a part number for the 4 pin harness? Also, I said I was getting a hitch installed but in fact I am buying it and I will install it myself I know it's only like 4 bolts trough the frame.
Thanks
Black 2010 Sport JK
Baotchi is offline
post #4 of 6 Old 06-07-2010, 07:35 PM Thread Starter
Baotchi
Baotchi's Avatar
2010 JK Wrangler
Baotchi is offline
post #5 of 6 Old 06-07-2010, 07:56 PM
JKIslander
2010 JK Wrangler
I asked the service dept how long they would charge for a hitch and 4-pin harness install. They said 3 hours. I got the parts and put them on myself. It took 20 minutes, which included getting out the tools
JKIslander is offline
post #6 of 6 Old 06-07-2010, 10:55 PM
WaldenL
2009 JK Wrangler
Hitch and harness I used are in http://www.jeepforum.com/forum/f96/h...-hitch-840630/
WaldenL is offline
Mopar hitch wiring harness Baotchi JK Wrangler Technical Forum 3 04-03-2010 10:32 AM
hitch wiring harness lenteoculto YJ Wrangler Technical Forum 3 10-01-2009 02:49 PM
New hitch and wiring harness DLEB JK Wrangler Technical Forum 2 11-23-2008 09:28 AM
Wiring Harness for Trailer Hitch fiasko915 JK Wrangler Technical Forum 21 04-22-2007 08:24 AM
hitch wiring harness location nytro TJ Wrangler Technical Forum 18 05-11-2005 09:14 PM
