JK handling issues above 55mph - Page 4 - JeepForum.com
post #46 of 46 Old 08-01-2013, 06:34 PM Thread Starter
dawgfan77
quick question for the guys running synergy
Will the pitman arm need to be reamed or drilled for the insert in order to use their draglink or is it the same taper already?(1.5"/ft)
And as for the pitman arm side TRE, is it the same Synergy TRE as the knuckle end and the tie rod ends (the "one spare advantage" that I keep reading)??
thanks
dawgfan77 is offline
