JK going haywire - JeepForum.com
post #1 of 9 Old 07-21-2013, 08:08 PM Thread Starter
craiglow2010jk
2010 JK Wrangler
JK going haywire
I got stuck in rain storm 2 days ago. I had about 3" of water on floor and dash was soaked. It will start but my dash lights don't work, the wipers won't shut off and it will not go in to gear. It's a 4 speed auto. If I pull battery wire and re hook it everything works correctly. As soon as I shut it off and restart it everything goes haywire again. Any suggestions on how to fix it?
craiglow2010jk is offline
post #2 of 9 Old 07-21-2013, 08:30 PM
Butterjeep
2015 WK
Let it sit in some hot sun and dry out completely. That's all I can think of.
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #3 of 9 Old 07-21-2013, 08:36 PM
MoparMech
1995 XJ Cherokee
Sounds like you have a Communications bus problem. Anytime the bus goes down it automatically turns the headlamps and wipers on. I would check under the dash and start disconnecting connectors. See if any water drains out of them. Pull the floor plugs to let all the water drain out and dry her out really good. Wouldn't be a bad idea to get some electrical contact spray to dry out all the connectors and pack them with a little dielectric grease in case this ever happens again.
MoparMech is offline
post #4 of 9 Old 07-21-2013, 08:36 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
I'm with that guy ^^^
Maybe pull the dash apart and sit a fan inside. It takes very little to piss the canbus off...a finicky ground or an intermittent short from the water. Good luck.
Mol is offline
post #5 of 9 Old 07-24-2013, 10:37 AM
VICTIM_OF_PAIN
VICTIM_OF_PAIN's Avatar
Just adding to what the first couple of guys said. I usually use a dehumidifier inside, and close all the windows. Usually dry by morning, and when I say dry I mean really dry.
Ex - 2001 Wrangler, 2" BB, 32" BGF AT's. JKS Quicker Disconnects, Oil Pan Skid, Steering Box Skid. Hard Top, Soft Top, Safari Top, Olympic Mountaineer Rack.
Current - 2008 Unlimited Wrangler Rubicon. Rock Krawler Stock Mod 2.5" lift, 35x12.50x15 Cooper STT's on Pro-Comp D-Windows, Husky Floor Liners, Mastercraft Grab Handles, Weathertech Side Window Deflectors, Hitch mounted D-Ring, Rancho Oil Pan Skid, Rugged Ridge E-Disco Skid, and a Skid Row Evap Canister Skid plate.
It is better to keep one's mouth shut and be thought a fool.... than to open it and remove all doubt.
VICTIM_OF_PAIN is offline
post #6 of 9 Old 07-24-2013, 11:10 AM
JIMBOX
Wrong post-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #7 of 9 Old 07-24-2013, 10:27 PM
HighandLow
HighandLow's Avatar
2010 JK Wrangler
Same thing happened to me. Except after I reset the battery it went away. I took mine to the carwash and thoroughly vacuumed it out then left it to dry for a day in the Houston heat.
There have been others with the same issue after rain.
http://www.jeepforum.com/forum/f96/e...dness-1548481/
2010 Rubicon, Auto, Stone White, 3.5"Synergy Coils, DL and TR, MetalCloak TB's and CA's Fr/Rr, 37"Coopers 18" Ions , Adams 1310's, G2 5.13 gears, Synergy Sleeves and Gussets, ORF, PSC, JCR, PIAA,Rancho equipped...
HighandLow is offline
post #8 of 9 Old 07-25-2013, 05:21 AM Thread Starter
craiglow2010jk
2010 JK Wrangler
I checked all plugs on inside, cleaned and lubed them and still not fixed. every thing on inside is dry.
post #9 of 9 Old 07-25-2013, 07:48 AM
nwbronco
2014 JK Wrangler
Doubting it. Either put a drying agent in it and button it up, or open it up if it is hot. And disconnect the battery through the process. The missus runs through every mudhole she can. And it takes MONTHS to dry it completely out.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
Kid's '08 Yellow JKU
'13 Black 10A Rubicon JKU
nwbronco is offline
