jk front tcase yoke question - JeepForum.com
post #1 of 7 Old 06-28-2014, 08:49 PM Thread Starter
Prickett10
Twenty Two
Prickett10's Avatar
I'm a wj guy and am trying something new. If anyone can tell me what tcase is in the jk and the spline count and inner bore depth is on the front tcase yoke. THANKS GUYS!
Better to be mute than dispute with the ignorant.
Perversion or self exploration isn't the point in this case.In fact there will be no case, no trial by a jury of our peers just fear in the hearts of those we choose. Doing this for the knowledge of our victory, that is how we are different.
Prickett10 is offline
post #2 of 7 Old 06-29-2014, 06:21 AM Thread Starter
Prickett10
Twenty Two
Prickett10's Avatar
Anybody?
post #3 of 7 Old 06-29-2014, 02:19 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Which JK do you have? Rubi or Sport? Your info is not sufficient to answer which t case you have.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #4 of 7 Old 06-29-2014, 03:10 PM Thread Starter
Prickett10
Twenty Two
Prickett10's Avatar
I don't have a jk. I am curious how many splines are on the front tcase yoke. Either tcase that comes in the jk
post #5 of 7 Old 06-29-2014, 03:42 PM
RockyClymer
RedRock4Wheeler
OK, I will try. The Sport came with a NVG (New Venture Gear) 231J - 23 spline input shaft, no options for different input shaft. The Rubi came with a NVG 241OR same spline count and they are interchangeable. You could Google them and find the exact specs as I did.
NRA Life member
post #6 of 7 Old 06-29-2014, 04:11 PM Thread Starter
Prickett10
Twenty Two
Prickett10's Avatar
OK, I will try. The Sport came with a NVG (New Venture Gear) 231J - 23 spline input shaft, no options for different input shaft. The Rubi came with a NVG 242OR same spline count and they are interchangeable. You could Google them and find the exact specs as I did.
I found conflicting info when I googled it. Thank you.
post #7 of 7 Old 06-29-2014, 08:44 PM
RockyClymer
RedRock4Wheeler
I swapped out my NVG 231J with the NVG241OR. I know the input shaft is the same...make sure you distinguish the JK tcase from the earlier (with the same designation) TJ tcase....they have similar numbering but are not the same. There was a typo in my post..it should read 241, not 242.
NRA Life member
