JK?? Front end SHAKING - JeepForum.com
post #1 of 23 Old 12-17-2011, 10:22 PM Thread Starter
bluejunior
bluejunior's Avatar
So I have a friend back home (i'm away at school) who is giving me frustratingly little information on a problem, and I can't figure it out from the phone, maybe just because I only know XJ's. She's got a 4-door that she's not sure if is a 2006 or 07, i think it's an 07, and when she hits more than a minor bump at highways speed, it sometimes starts shaking REALLY badly, she says "it feels like the front end of the car is going to fall apart" and doesn't stop this until she comes to a stop and lets it sit for a minute and then takes off again. It's a certified preowned whatever and she's had it back to the dealer to be looked at multiple times about this, and they can't find anything that looks loose, worn or damaged. She said she'd heard of other people having a similar problem so I was hoping I could draw on the knowledge of Jeep Forum and see if I could find an explanation for her.
Sorry for the uncertainty on the year model, but I think its a JK, I'm not really sure when one wrangler ends and the other begins, my jeeps have both been cherokees, as have the other three jeeps i've actually laid hands on.
Thanks and Gig'Em!
bluejunior is online now
post #2 of 23 Old 12-17-2011, 10:27 PM
Airborne4X4
Airborne4X4's Avatar
1948 CJ2A
It's called death wobble. Have them balance and rotate the tires.. If parts arent worn, then it's the tires.
1948 CJ2a
Airborne4X4 is offline
post #3 of 23 Old 12-17-2011, 10:44 PM
MacK
2015 JK Wrangler
Yes, it's death wobble. Common amongst all jeeps. Usually a imbalance in your tires/front end. In my case I had a '07 2dr that did it on minor bumps, and it fixed it by getting new tires. I would rotate the tires, get a full alignment, balance, and so on. If it don't fix it, then it's something worn out. In that case, dealer needs to start replacing parts.
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline
post #4 of 23 Old 12-17-2011, 10:47 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Here is the most comprehensive thread we have on the subject > http://www.jeepforum.com/forum/f96/d...bbles-1052221/
The most common cause is a loose track-bar. It may not be evident in a visual inspection, removal and inspection of the mounting bracket holes is the best way to check it out.
Good luck to her!
Jim
JLC08JK is offline
post #5 of 23 Old 12-17-2011, 10:50 PM
jstrubberg
2009 JK Wrangler
Death Wobble has nothing to do with unbalanced tires. 95% of the time, the bolts on the trackbar have become loose.
Someone who knows their way around a torque wrench needs to get under her Jeep and tighten everything back up before she gets hurt or suspension parts start failing.
jstrubberg is offline
post #6 of 23 Old 12-17-2011, 10:54 PM
Airborne4X4
1948 CJ2A
Where did you get your statistics?
1948 CJ2a
post #7 of 23 Old 12-17-2011, 11:26 PM
neverhide34
2011 JK Wrangler
95% of the time, every time.
Keep Calm, Chive On
neverhide34 is offline
post #8 of 23 Old 12-18-2011, 10:50 AM
guarnibl
2009 JK Wrangler
Thanks and Gig'Em!
I had an issue when my steering stabilizer went out that matches exactly what you are describing (front end felt like it was coming apart). So have that checked and balance the tires (again if you haven't done it in a while).
2009 Jeep Wrangler Rubicon (6mt) (in progress)
- 42x14.50 MTR's, Custom Cage, FF D60's F/R w/ ARB's and 5.38's, 4 Link Rear, 3 Link Front, 14" RR King 2.5's, 18" RR Fox 2.5's, Fox Air Bumps
- 108" wheel base
guarnibl is offline
post #9 of 23 Old 12-18-2011, 10:51 AM
guarnibl
2009 JK Wrangler
Please stop spreading false information. It only hurts other people and makes you look like an idiot. Not saying you're an idiot.
I do agree though with tightening everything.
- 108" wheel base
guarnibl is offline
post #10 of 23 Old 12-18-2011, 11:52 AM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
He isn't spreading false information. DW is caused by a loose track bar, or loose control arms, not unbalanced tires. Tires can induce a DW if suspension components are already loose, but are not causal.
Read planman's thread posted above.
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #11 of 23 Old 12-18-2011, 12:07 PM
zjilla
It can be caused by xx number of things. No one is going to be able to tell you exactly what it is over this forum unless they are under that jeep. Read that comprehensive link on DW (that was previously posted in this thread) and narrow it down. If u have trouble narrowing it down then I'm sure "%95" of our forum users will be more than willing to help once u start eliminating different culprits. I can assure you that it's not the steering stabilizer. If that was a bad part then it would only help the death wobble make itself more prominent but is not the cause
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #12 of 23 Old 12-18-2011, 02:15 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
guarnibl - when someone with actual experience and research says it DW is usually not caused by out of balance tires, a bad steering stabilizer, worn shocks or such and that it is usually caused by a loose trackbar or control arms....this has been the actual experience of many, many DW cases and cures by those on this and other forums...so, not spreading bad info, just trying to prevent the actual spreading of false info by those with no actual experience with DW on a jeep....just my 2 cents. as has been said...a consensus...Planman has undoubtedly the best writeup on this issue...you would be well advised to read/research his findings and recommendations.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #13 of 23 Old 12-18-2011, 03:00 PM Thread Starter
bluejunior
bluejunior's Avatar
Thanks, after someone mentioned it I found Planman's thread on it. I'm three hours away from the jeep I'm just the only jeeper she knew to ask. As I said she's had it back to the dealer three times already to make sure everything's tightened and properly torqued, so I'll have her check alignment and tire/wheel balance next, if not that, maybe she just needs an independent mechanic to look it over. Dealers are prone to rushing cars out and missing little details.
Thanks again for all the input, I didn't mean to start any debates clearly there's a lot of different causes and therefore a lot of different views on the problem, and I really appreciate everyone's input.
post #14 of 23 Old 12-18-2011, 03:03 PM
MacK
2015 JK Wrangler
My 2007 Wrangler had the death wobble. Replacing the tires fixed it, so either extremely worn tires, imbalance, or something is loose.
MacK is offline
post #15 of 23 Old 12-18-2011, 04:18 PM
Metallheadd
I had it happen. It was induced by a warped rotor that shook bad (very bad on a long decent)then caused the axle to have death wobble. The only thing I came up with it it was due to the 12mm bolts in the 9/16ths holes as stated in the above posted link. I checked, all is tight, but I will say it has the smallest steering stabilizer that I have ever seen.
Metallheadd is offline
front end shaking npv3136 JK Wrangler Technical Forum 5 10-05-2011 07:36 PM
Front end shaking please help. mudbug98 TJ Wrangler Technical Forum 0 08-23-2011 03:05 PM
Front end shaking help! kappie70 TJ Wrangler Technical Forum 2 10-23-2010 04:39 PM
88 YJ Front Shaking Neversober YJ Wrangler Technical Forum 8 07-11-2007 04:55 PM
front end shaking dsrtdog5 TJ Wrangler Technical Forum 13 04-26-2006 01:34 PM
