JK front axle LS? - JeepForum.com
post #1 of 10 Old 03-07-2007, 12:57 PM Thread Starter
greggradwohl
JK front axle LS?
I am getting a JK unlimited - probably an X.
Going to get lift/tires/gears. While I am screwing with the gears (4.56) I am thinking about adding an LS - probably trutrac - up front (assuming a D30 27 spline).
Would an LS up front screw up the ESP or any other computer related stuff?
greggradwohl is offline
post #2 of 10 Old 03-07-2007, 04:49 PM
redrom01
JCOB-4-LIFE
redrom01's Avatar
I beleive that new D30 has a bigger spline than 27. 30 spline or 32 spline I'm not sure.
-Jeep History-
1992 XJ - '00 till '04 - RIP (thanks alot dave)
1995 XJ - '03 till '07 - Sold to the HUB
______o00o
/__l_l_,\____\,__
l_---l_l__l----[ ]llllll[ ]
._(o)_)__(o)_)--o-)_)__
-Current Jeep-
2007 JK Rubi (Steel Blue)
Searching for an MJ
|¯¯l,[___],
l---L--OlllllllO¬
=~~~==oo==
()_) ()_)--<>-)_)
redrom01 is offline
post #3 of 10 Old 03-07-2007, 05:14 PM
igofshn
Locked @ both ends
igofshn's Avatar
Carrier is the same, it is still 27 spline, the outers are 32 spline. I talked with the Detroit rep at TDS, he said the diffs are the same, you might need to drill out the bolt holes because he said they were 7/16 instead of 3/8.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #4 of 10 Old 03-07-2007, 05:23 PM
Karamba
Why would you want LSD up front, when you already have a perfectly functional electronic limited slip - which handles much better then a mechanical LSD off and on road.
Karamba is offline
post #5 of 10 Old 03-07-2007, 05:33 PM
Bamoman
Bamoman's Avatar
he said he alrdy had one? where did he say that?
Bamo
Bamoman is offline
post #6 of 10 Old 03-07-2007, 05:49 PM
redrom01
JCOB-4-LIFE
redrom01's Avatar
Not sure but I was under the assumption that the traction control system with electronic limited slip was only in the rear axle. Again I'm not sure about that.
-Jeep History-
______o00o
/__l_l_,\____\,__
-Current Jeep-
Searching for an MJ
|¯¯l,[___],
l---L--OlllllllO¬
=~~~==oo==
()_) ()_)--<>-)_)
redrom01 is offline
post #7 of 10 Old 03-08-2007, 02:40 PM
Karamba
Electronic limited slip (part of the traction control) runs both axels AFAIK. And it apparently works quite well. I would think that this makes the mechanical limited slip in front to be somewhat redundant. Electronic stuff should have none of the handling drawbacks as well.
Karamba is offline
post #8 of 10 Old 03-08-2007, 02:41 PM
Karamba
Bamo
It comes with it from the factory - all trims have traction control, that includes the brake activated electronic limited slip functionality.
Karamba is offline
post #9 of 10 Old 03-08-2007, 10:29 PM
SecondTJ
SecondTJ's Avatar
If they make one that will work in the new JK, go for it It'll be an improvement over the esp
A truetrac has no bad on-road characteristics. It is invisible, you can't tell its there. There are no drawbacks.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #10 of 10 Old 03-09-2007, 11:52 AM
Karamba
Indeed - with electronics taking care of it it will never be activated.
(Seriously though, I do not know how they will interact - who will run first, but after observing how the brake actuated stuff works, I would not care about mechanical limited slip at all. When brake actuated is not enough, you already can make use of a a full locker..)
Karamba is offline
Leaking Axle seal on the front. Should I upgrade the axle to a dana 44? MWguy101 YJ Wrangler Technical Forum 21 03-01-2012 11:08 AM
front outer axle seals and axle shaft runout... mudb8 TJ Wrangler Technical Forum 32 01-02-2011 12:49 PM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
Superior Axle & Gear EVOLUTION SERIES Front Axle Tube Seals 95wrangler4life YJ Wrangler Technical Forum 3 02-17-2009 02:00 PM
