-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   JK F.A.Q. - Frequently Asked Questions / Will It Rub and Links to Popular Threads! (http://www.jeepforum.com/forum/f96/jk-f-q-frequently-asked-questions-will-rub-links-popular-threads-1074059/)
JLC08JK 07-21-2010 10:25 PM
WELCOME
to the
JK TECHNICAL FORUM
FREQUENTLY ASKED QUESTIONS
and
POPULAR THREADS
Standard acronyms used on the forum:
BB - Budget Boost (Spacer Lift)
BL - Body Lift
CV Joint - Constant Velocity Joint
LA - Long Control Arm
LCA - Lower Control Arm
MA - Mid length Control arm
MML - Motor Mount Lift
RTI - Ramp Travel Index
SA - Short or Standard Control Arm
SYE - Slip Yoke Eliminator
UCA - Upper Control Arm
I4 - Inline engine, 4 cylinder, 2.5L
I6 - Inline engine, 6 cylinder, 4.2L or 4.0L
V6 - Engine used in (JK - 3.8 liter) and (Liberty - 3.7 liter)
V8 or (hemi) - Engine used in Grand Cherokees
FAQ: Will it rub? By (NaeKid) http://www.jeepforum.com/forum/f96/faq-will-rub-610856/
The JK with stock wheels, no wheel spacer, no lift
32" tires: no rubbing
33" tires: minimal rubbing unless extended bumpstops used
35" tires: don't try unless extended bumpstops used
The JK with stock wheels, 1 1/4" wheel spacer, no lift
33" tires: some rubbing on full turn which can be controlled by extended bumpstops
The JK with stock wheels, 1 1/2" wheel spacer, no lift, Bushwhacker flat-top flares
33" tires: no rubbing
35" tires: rubbing that can be cured with trimming pinch-seam
37" tires: don't try
The JK with stock wheels, 1 1/4" wheel spacer, 2" lift
35" tires: some rubbing
The JK with stock wheels, no wheel spacer, 2 1/2" lift
34" tires: some rubbing on street, sway bars connected
35" tires: significant rubbing
The JK with stock wheels, 1 1/4" wheel spacer, 4" lift
35" tires: no rubbing
37" tires: some rubbing - trim flares and pinch-seam
38" tires: be careful
39" tires: don't try
What the above chart shows is that there are many different combinations that will allow for different tire sizes. By changing the stock rims out for aftermarket rims you can run all kinds of different tires. By trimming fender-flares, adding bumpstop-extensions, changing to long-arms, adding body-lifts, etc, you will be able to fit virtually any tire that you want to fit on your JK. It has been reported that a 3 1/2" lift with minor trimming of the body / flares allows fitment of 37" tires on non-stock rims with very minimal rubbing on extreme articulation, perfectly fine for street or light-trail use.
Originally Posted by OH9JK (Post 12300510)
If you install a wider tire and don't compensate with either a different wheel or a wheel spacer to push the tire away then your tire could end up rubbing some of the suspension components.
The other type of rubbing occurs when your Jeep flexes its suspension without a lift and it typically rubs the fenders, bumper or body.
:cheers2:
Originally Posted by cbloyer81 (Post 12300517)
We need something on the sticky along the lines of what he just said. It should also say: If it rubs the suspension a little, you'll need wheel spacers and if touches the fenders a little you'll need extra bump-stop or flat fenders.
Done :thumbsup:
What kinds of wheels can I run on my JK?
Of course, any stock wheel that comes with the JK will be able to be used. If you are looking through the junk-yard and you find some rims that you really like, make sure that they are a 5-bolt pattern on 5" diameter. Chevy 1/2-ton pick-up trucks in the 2wd variety use this bolt-pattern. YJ and TJ rims are 5-bolt on 4 1/2" diameter, not directly compatable with JK axles. Using wheel adapters (like made by SpiderTrax) will allow you to put 15" or 16" YJ or TJ rims onto your JK.
You will be able to fit some 15" rims and all 16" and bigger rims on your Jeep. The only problem that you might run into is the brake-caliper rubbing on the inside of the 15" rim, depending on off-set. If you find the rims you choose rub - a set of wheel-spacers can be installed to move the rim further from the caliper.
Check the tire-manufacturer's recommended rim-width prior to running the tires on the rims that you choose yourself.
Note: This chart will be updated as people report back on different lift / wheel / spacer combinations. If you try a combination that works that isn't listed here yet, please send a PM with the details of the lift and we will update as soon as possible
JLC08JK 07-21-2010 10:28 PM
Link's To The Original JK-F.A.Q.
Something popped, now my steering is loose to the left. http://www.jeepforum.com/forum/f96/j...8/#post2754158
How do I make the auto door-locks not "automagically" lock the doors? http://www.jeepforum.com/forum/f96/j...8/#post2754158
How to Check Your New JEEP "Order Status" http://www.jeepforum.com/forum/f96/j...8/#post2874426
More About Tires and Wheels. http://www.jeepforum.com/forum/f96/j...8/#post4342379
Trouble Codes part-1 http://www.jeepforum.com/forum/f96/j...8/#post4710891
Trouble Codes part-2 http://www.jeepforum.com/forum/f96/j...8/#post4710895
Trouble Codes Up-date
C1239 - Steering Angle Sensor Erratic Performance
C123A - Steering Angle Sensor Not Initialized
C123F - Steering Angle Sensor Comparative Performance
C1240 - Steering Angle Sensor Overtravel Performance
C2205 - Steering Angle Sensor Internal
Cause and effect here > http://www.jeepforum.com/forum/f96/s...codes-1192269/
How to; Install A Remote Start in My JK Wrangler. http://www.jeepforum.com/forum/f96/j...8/#post7026707
JLC08JK 07-23-2010 10:29 AM
Popular Threads
About Fire Extingushers!
Media and Navigation
Mygig Anyone
Mygig Database Thread
OEM Stereo Wiring Diagram
How to Upgrade your sound system while retaining factory head unit (Infinity)
OEM Radio Removal
2011 Dash removal, lockpick-camera install
2012 Dash removal, lockpick-camera install (with pictures)
Write-up Video monitor install stock dvd player
General Maintenance and Trouble-Shooting
JK_3.6 oil filter change
Here is some info related to diagnosing axle noise
Programing a third key
Daystar JK hood-wranglers install
JK 3.8 Oil filter list
Tools to keep close
Differential fluid service 1
Differential fluid service 2
How to perform a 6000 mile service
Brake Pad Replacement Using Hawk Brake Pads
OEM Rubicon Locker Study:
OEM Fuel Pump Module Study:
OEM PCV Valve Study:
OEM TIPM Study:
OEM e-disco Smartbar study:
OEM Parking brake study:
OEM Ball Joint Study:
OEM Front Wheel Unit Bearing Study:
Write-up rear door panel removal
JK grill removal
Front end alignment and diagram
Clunk fixed-Steering Knock
Steering knock, another cause!
Parking Brake Is Self Adjusting
Tru-Lok Inner Workings
Driveshaft Boot Clamp ripped off!
No 4-low ...fixed!
Misfiring 2010 JKU 3.8
Mopar Speed Control Install / troubleshoot
How To get your keys and/or other stuff that you lost inside the dash!
JK Facts and Specs
Weight of a Stock JK Rubicon Unlimited
Differences between 07-10 rubicons?
JK model year differences?
Is it a 07,08,09, or 2010 Wrangler?
Difference between 2008 and 2007 JK's
Lighting and Electrical
Rigid Dually and Dually D2 Light Patterns
Custom homebuilt aux. lights under $200
Dash LED Color Change
Selectable Battery/Accessory Power Source
Easy Switched Power Source
Headlight Shootout
Rallylight/Hella headlight upgrade install
LED Auxiliary Lighting
Daytime Running Lights
Lets see your lights!
Home built power distribution panel and Air horn
Aux. Back-up Lights on Factory bumper
Great Idea for Backup Lights
Recessed rear bumper light install
Custom Build: JK Electrical Panel
Daniel Stern Lighting for my JK
Installing Mopar 7-pin trailer adapter and brake controller on the JK
Walmart tools don't Work! (basic trailer wiring install)
Footwell glow lights (l.e.d.)
CB Radios and Antennas
CB Options
Mount options 1
Mount options 2
Antenna options 1
Antenna options 2
Suspension and Steering
Max flex vs. useful flex (Currie Anti-Rock)
Diagnosing Death Wobble and Fixing Non-DW Shimmies and Wobbles
Another Possible Cause Of Death Wobble and Steering Problems
How to change (and upgrade) your Drag Link End
Rubicon Take off Suspension vs Teraflex Leveling kit
Rubicon JKU spring info / link to teraflex 2.5" bb writeup
Rock Krawler 3.5" Mid-Arm Flex and RRD Shocks Installed!
Thing's to check after you lift (cutting the pinch seam)
Cutting the pinch seam with a Dremel
Armor and Skid Plates
Installed some ACE Rock Sliders
ARB front bumper install/mini write up
Evap skid plate
Trans/oil pan skid plate
JK Top Options
Bestop Trektop
Bestop Supertop problems
Power and Performance
OEM Mechanical Fan Retrofit
Superchips installed today-review
Superchips Error
Ripp gen II stage II supercharger
Gears, Axles, Wheels, and Tires
CHALK TEST
DEFINITIVE WHAT SIZE TIRE/Wheel/SPACER/BACKSPACE THREAD
Nitro axle sleeves installed
Want to know your gear ratio for sure?
Gear/tire for Auto VS Standard
Power Loss from 35s-Ideal gear setup/ tire size
Chop Chop, stock bumper mod, spare tire clearance
Gear Calculator
Deflation and Inflation tool
Spidertrax Wheel Spacer Install
Definitive list of 15" wheels that will fit JK
Jim's Jeep; JK rear axle build with Super 44s, ARB, and 4.88 gears.
Other Usefull Ideas
Make Your Own Cargo Net Tutorial
Inexpensive mod list
I made a DIY video for fender cutting
Show us how you trimmed your flairs!
Easy Modification But Effective, drill the mirrors
Mesh Grill Mod
Mopar Fuel Filler door install
OX locker installed
JK exhaust Magnaflow D.I.Y. less than $100
transmission cooler-shrockworks-midwidth bumper install
wasted $ what mods are not worth it
Pinch seam cut-off
JK Custome cowl snorkel
I want a snorkel
Axle vent relocation
Homemade lightbar/rack writeup part 1 (picture happy)
Home made trunk cover for JK?
Woods Viair OBA Install
Rear Floormat Securement for door-less driving
Video Installs and How-to's
JLC08JK 08-03-2010 01:12 AM
JK Build Threads
(planman)Info for going to 35" tires on a JK
(planman)Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares
(planman) 40s on a 3" OME LT lift, 1" BL, & flat flares
CRWL:TH!S-JK Buggy by Carolina Truggies(KRIPPLE)
30 day Unlimited Rubicon build...(BRICKTOP2)
blackanwhiteriot JK build thread
rballman JK build - da hoopty
MudHound Build Thread
Mattman8706 build thread
WVUJeeper's Build Thread
Total build with pics!(MilitaryJK4455)
Blood, sweat and beers... a.k.a. voodooJK build.
My 2010 Rubicon(MoparToYou)
Steve's 2009 2 Door JK Build(1398653)
08 Silver Unlimited BUILD W/ unexpected law suit(jamie_s_72)
KBeran's JK Build
blood,sweat and TEXAS beer... tube fenders(jeepbronco1)
b_c's build thread
Jim's Jeep; THE OBSESSION LIVES ON! (JLC08JK)
Deerassassin22's build thread
molshove's build thread
aznjeep's build thread
Dronac's build thread
11RUBICON's build thread
Jeep 7 - Ultimate Off Roader
Surviving the Frozen Northern Yankee Wasteland: ArticRubi's Build Thread
Avenger Supercharger Half Top Install (dvdsjk's build thread)
Ok, Its Official, I'm Back Sahara Tan Sahara Build (Another one from dvdsjk)
SickBoy357 JK build
Coping with the Urban Coyote - Jezzalachis' JKU Build Thread
Tanimal's 2008 2D JK Build Thread
Ricks 2012 DD/Weekend Warrior Build (maniacal rick)
Wanderlust, TheBoss's JKU build
Sand Scorpion - Mark's Tonka Truck Build (cyberpyrot)
JLC08JK 08-15-2010 03:25 AM
JK Wrangler Fastener Torque Specifications
28 Attachment(s)
Bolt And Fastener Torque Specifications
KPJ 10-05-2010 09:28 PM
Why Should I Buy A Rubicon (or not)
edit; This post came from this thread>To Rubicon or Not?
I would definitely go Rubicon. Auto or manual? If auto, then the Rubicon if for no other reason than the 4.10's.
For sand the 4:1 transfer case is not needed but it is no disadvantage either. Bogging in soft sand and needing to downshift can lead to being stuck, the 4:1 transfer case will keep the revs up, but so can selecting and staying in a lower gear with the 2.72:1 case. The front D44 isn't needed, but again it isn't a disadvantage either. The lockers can definitely save the day in loose sand, especially with good aggressive tires. The Rubicon tires are actually quite good in the sand despite common "wisdom" that aggressive tires don't do well in the sand.
For mud, the lockers will save your hide and become a favorite feature. The D44 becomes more requirement since spinning in the slop and then catching is what often breaks axles. It isn't fool proof, but it is substantially stronger than a D30. Bogging down and needing to downshift is a leading cause of becoming stuck in the mud, the 4:1 case is by far the better choice for mud. The 3.8 like the revs and the 4:1 will deliver while providing plenty of wheel spin to keep the treads clear. The Rubicon tires are mudders, and good ones until you decide you want bigger.
The only Rubicon feature you won't use and rely on for the off roading you describe is the e-disco.
Now if you plan to (soon) moddify your Jeep to the point that you're swapping in D60 axles and dropping in an Atlas X-case and air lockers front and rear... no reason for the Rubicon.
As far as paying intrest on stock Rubicon features that would be mods on an X, Sport, Sahara, when you find yourself with a pocket full of money that you would have spent on, say, a front locker or gears, make an extra pmt. Your interest accrual will drop since the extra pmt will drop your principle amount... Then you aren't paying interest on the "mods."
BTW, all of those X, Sport, Sahara mods like gears and lockers or D44 front axles that kill your warranty but come stock on the Rubicon are covered by the factory warranty.
And if you price out the mods and include the labor to instal them, you are WAY ahead with the Rubicon. (But if you can instal them yourself... Go X or Sport or Sahara...)
JPK
JLC08JK 05-26-2012 02:27 PM
We Are Always Looking For More Stuff To Add The F.A.Q.
Suggestion Box Here
The time now is 09:16 PM.
