JK Custom Cowl Snorkel? - Page 5 - JeepForum.com
post #61 of 112 Old 05-08-2010, 02:33 PM
jpgrl07
warcryr, I have a p/n for a bonnet that looks good and works well for use all the time.
jpgrl07 is offline
post #62 of 112 Old 05-09-2010, 07:12 PM
wilywillie
Originally Posted by warCryr View Post
Now I can either put a hummer style snokel on the end of that or create a snorkel that goes up the side of the windshield (I've already started planning for this.)
My problem is I have KC's mounted to the front of the windshield brackets (150W would melt any intake, even aluminum) and mirror remounts on the side brackets. Im'a see if there's any room further in (medial, amidships, et al) to put the tube without totally blocking my view
wilywillie is offline
post #63 of 112 Old 07-19-2010, 03:33 PM
gummby
Has anyone heard any feedback, I'd like to run this setup if it was successful.
Thanks
gummby is offline
post #64 of 112 Old 07-21-2010, 11:23 AM Thread Starter
warCryr
hey sorry I haven't posted anything in forever. I was in the processes of creating a windsheild bracket for the snorkel but ran into complications that prevent me from finishing. I created a plastic mold that didn't turn out so well.
My goal is to have a snorkel that runs up the side of the windshield but I might settle for a hummer style snorkel soon.
2008 JK
4.88, 6spd, RK 2.5", 17x8 Cragar Soft 8s, 33" BFG KM2s, JKS trackbars, RR breather kit, K&N, cowl snorkel, Benchmark bumpers, Tuffy interior, Riddler diffs
warCryr is offline
post #65 of 112 Old 07-29-2010, 09:32 PM Thread Starter
warCryr
plaster???
So I decided to try to make a snorkel piece that runs up the windshield like most Jeep snorkels out there. I'll spoil this post by telling you right away that this didn't work out... or hasn't, yet..
Here is what my design looked like.
Basically I'm using PVC pipe for the tubing and I need to find some what to mount the tube to the jeep using the windshield bracket.
Making a solid block of plaster.
Getting ready for some sculpting
the result almost ready for step 2.
I figured the piece I had come up with simply wasn't good enough and wouldn't do so I started over with a slightly different technique..
More plaster...
Masking off any holes and cracks that plaster might get into.
Here is a tube in place held up with cardboard walls to serve as a container for pouring the plaster into. Notice that I have the tubing positioned in front of the windshield as opposed to most snorkels that run up the side, I think this could help avoid collisions and breaking off.. that sort of thing..
Plaster pouring..
Windshield aftermath..
The plaster took only about a minute before I could grab the thing and carefully peel the mold off away from the jeep.
Again more sculpting. Looking better than before!
Here's a shot of both molds in their final form. Definately an improvment the second time around.
Step 2. My plan is to cover the piece in something that I can later remove and have a mold created that I can then pour a harder more permanent material into. Caulk probably works...
This plan is in FAIL mode. The caulk pretty much never dried, and by never I mean 2 weeks at least. I must've caked in on too thick.
When I finally got to peeling it off I had to destroy the plaster piece because it apparently too complex of a shape to simply "peel" the silicone off.
I didn't throw away anything and I still have this part of my project but for right now I'm giving it a rest. I might have to try a different approach
2008 JK
warCryr is offline
post #66 of 112 Old 07-29-2010, 09:41 PM Thread Starter
warCryr
Snorkel 1 :D
So after disappointing myself with the whole plaster thing, I decided to go the "hummer-style" route.
I found a "hood inlet" online that would probably be good. It actually turned out higher quality than I expected. I think it was $30 - $40.
Getting ready hoping the fit is good...
I shortened one of the pipe caps I use to cover the cowl hole (for when I don't have a snorkel on it) to plug the "alternate/primary intake".
Perfect fit!?!
The fit is very tight and probably even tighter due to the painting I did on the piping. I think it looks very decent.
Wadya think?
2008 JK
warCryr is offline
post #67 of 112 Old 07-29-2010, 09:51 PM
jeepwrangler97
I think it looks great
I'm eventually going to do some type of snorkel on my TJ
jeepwrangler97 is offline
post #68 of 112 Old 07-29-2010, 11:32 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
You did an exceptional job on this project!
I added the link to our new F.A.Q. for all to see!
When you make a silicone mold you need to use a catalyzed silicone.
There is a plastics co. here in L.A. that makes it http://www.hastingsplastics.com/
If you want me to ship some out to you, just let me know.
Jim
JLC08JK is offline
post #69 of 112 Old 07-30-2010, 07:17 AM
MilitaryJK4455
2010 JK Wrangler
Wadya think?
WOW!!! That is all that I have to say!
Great job man!
MilitaryJK4455 is offline
post #70 of 112 Old 09-27-2010, 05:37 AM Thread Starter
warCryr
There is a plastics co. here in L.A. that makes it Hastings Plastics sells a full line of plastics, including acrylic and resins
Thanks! man that would've been good to know before. oh well lesson learned, I'll have to come up with something again at some point and I'll remember that if I go that route again.
And thanks for putting me in the FAQ! That's awesome , good to contribute to the community
i like the color of ur jeep btw
2008 JK
warCryr is offline
post #71 of 112 Old 09-27-2010, 05:38 AM Thread Starter
warCryr
did some wheeling the other day, didn't find any water high enough to fully test the snorkel but I sure did have more confidence splashing around in any puddles i found.
here's a video
YouTube - Jeep JK and Ford F250 allegan, MI 9/25/10
2008 JK
warCryr is offline
post #72 of 112 Old 09-28-2010, 08:06 PM
Scooter_Trash
That is exactly what I've been looking for, where did you find it? I've been looking everywhere.
Scooter_Trash is offline
post #73 of 112 Old 09-29-2010, 06:42 AM
Dronac
FYI, Rugged Ridge has said they are releasing a cowl intake sometime late this year.
Warcry, you are the man!
2008 Jeep JK X: auto trans, 3.73 gears, D44 rear, D30 front
Mods: 2'' Rusty's coil lift, Superchips 93 octane tune, Cobra 75 CB radio, 33'' Duratrac's, onboard air compressor
My Build Thread! ---> http://www.jeepforum.com/forum/f96/dronacs-build-thread-1104134/
Dronac is offline
post #74 of 112 Old 10-03-2010, 02:22 PM Thread Starter
warCryr
Yeah, the site I got mine off of is hard to find. Here's a link. Mines the 3" steel one (meaning it fits inside a 3"ID pipe).
Inlet Hoods
2008 JK
warCryr is offline
post #75 of 112 Old 10-03-2010, 02:28 PM Thread Starter
warCryr
thanks
yeah i saw a jk forum thread about that. I'm waiting to see what that setup looks like, might steal some parts and end up with a rugged ridge river raider hybrid thing going on. (mine's basically River Raider under the hood)
2008 JK
warCryr is offline
airbox , cowl , custom , intake , snorkel
question on cowl snorkel write up... majkowskid TJ Wrangler Technical Forum 11 07-23-2009 06:23 AM
Snorkel into cowl vent? RODKNOCKER YJ Wrangler Technical Forum 4 02-27-2005 10:01 PM
cowl snorkel Dome TJ Wrangler Technical Forum 2 11-08-2003 10:21 PM
YJ cowl intake (snorkel). BamaJeeper YJ Wrangler Technical Forum 8 03-13-2003 12:46 AM
