JK Custom Cowl Snorkel? - Page 3 - JeepForum.com
post #31 of 112 Old 02-28-2010, 05:38 PM Thread Starter
warCryr
Thanks for the replies!
I decided to get a 2ft section of hose and extend the breather more. Instead of wrapping the hose over top of the engine, I pushed it back toward the firewall and wrapped it around the back.
Also, I removed the melted electrical tape from the hose and there is absolutely no harm done to the hose. good news.
Everything is good now
2008 JK
4.88, 6spd, RK 2.5", 17x8 Cragar Soft 8s, 33" BFG KM2s, JKS trackbars, RR breather kit, K&N, cowl snorkel, Benchmark bumpers, Tuffy interior, Riddler diffs
warCryr is offline
post #32 of 112 Old 03-01-2010, 11:10 AM
krutj
2009 JK Wrangler
Glad that it worked out for you!!!
-- Joel --
krutj is offline
post #33 of 112 Old 03-13-2010, 09:43 AM Thread Starter
warCryr
intake pipe 1
a start on the intake pipe that connects the airbox to the snorkel.
Made entirely from Spectre intake parts.
2008 JK
warCryr is offline
post #34 of 112 Old 03-14-2010, 03:21 AM
richnev
2014 JK Wrangler
looking good
05 Jeep Wrangler X .... RIP
07 Jeep Wrangler Unlimited X ...... let the build begin
ARMY TEAM MEMBER #4
Originally Posted by ge2 View Post
I just make a BOOP BEEP sound with my mouth (really loud) as I walk away from the jeep, and point the key at it.
Originally Posted by her94yj View Post
lets put it a way a kids will relate......its like a hooker.......... SURE a 15 dollar handy from a detroit toothless 60 year old can get it done....... but NO where is it as nice as the $5000 an hour goddess from vegas or hollywood
....... dont be that fat guy on the beach in the speedo you dont want to be "that guy"
richnev is offline
post #35 of 112 Old 03-14-2010, 09:25 AM
Sgalway
This is a fantastic thread. However, I can't understand the point of the breather tube replacement? Is there a problem with the factory setup? About the only problem I have is that the rear one always falls off at full extension.
S Galway -- Sugar Land, TX -- KB5ODA
07JK Sahara 4dr -- 6sp 4.88gears -- ARB Lockers F/R
dual tops -- Kenwood DNX7100 indash nav
Banks Monster exhaust -- K&N 77 CAI -- 3" Black Diamond Lift
17" Pro Comp Extremes with 35" BFG A/T's
AEV front bumper w/ Warn Powerplant -- Custom safari roof rack
Sgalway is offline
post #36 of 112 Old 03-14-2010, 11:04 AM Thread Starter
warCryr
The factory breather hoses only extend up to mid-engine height. If you happen to go in water deep enough that the breathers are under water, you could get water in your differentials, transfer case and/or transmission. and thats no good.
So I tied all the breathers into a main line that goes to the airbox. This way I only need to worry about making the airbox "waterproof".
The River Raider (www.riverraider.com) kit is only $50, so why not i guess. just to be clear, I didn't replace them, the kit uses the factory breather hoses.
2008 JK
warCryr is offline
post #37 of 112 Old 03-14-2010, 12:42 PM
Sgalway
This makes perfect sense! Keep the updates coming, I think there are quite a few of us following along... Have you had a test voyage yet???
Sgalway is offline
post #38 of 112 Old 03-14-2010, 02:44 PM
DeepSky
Awesome project warCryr. I can't wait to see the finished result!
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #39 of 112 Old 03-14-2010, 04:49 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
I was just thinking
By running everything to the air box it's possible that it will apply vacuum pressure to the vents!!! These vents are in place to equalize pressure within the systems to that of the outside atmosphere to protect the seals. By adding vacuum to these vents any fluid that reaches the tubes [splashed or otherwise] could be inhaled by the engine. Fumes and vapors could also become a problem and have an effect on the various sensors in the intake/fuel system.
Just something to keep in mind.
Your work looks very good, Keep it up
Jim
JLC08JK is offline
post #40 of 112 Old 03-20-2010, 04:12 PM Thread Starter
warCryr
Today I drilled a couple of 3.5" holes in my jeep .
First I pulled down and cut away some of the material covering the area to be drilled. The following image shows the bare firewall with an oval hole already in it and 2 other things sticking out of it, all three of these will be included in the hole to be drilled an will no longer exist.
tada.
This was a pain. If you do this, make sure you have a long enough drill in the center of your hole saw so that it reaches through the oval hole and hits the wall behind, this will keep your drill steady as you go through. (I figured this out the hard way .
Also, notice how I chopped off part of that dented-outward part of the firewall, I recommend avoiding that and drilling higher than I did. I wanted to avoid it but it didn't turn out that way. In the next photo you can see that because I didn't drill higher than I did, the hole drilled in the back wall (being curved) isn't quite circular.
I ordered some rubber grommets from Minor Rubber (I actually had to order 34 of them because of a "minimum order". But I couldn't find these the size I wanted anywhere so I went with it.) The following image shows the rubber grommet placed around the edge of the back hole. I added some silicone sealant to the inside of the grommet groove.
Then I placed another grommet on the front hole.
This image actually does the result justice. Because the edge of the hole is 1-3 sheets of metal in different places, the grommet doesn't fit nicely.
I'll have to do some forcing to get the pipe through...but at least it'll be really snug.
This part of the project is less than perfect, I didn't expect the walls I was drilling through to be thicker in some places than others.
2008 JK
warCryr is offline
post #41 of 112 Old 03-20-2010, 04:14 PM Thread Starter
warCryr
btw, the holes I drilled were 3.5" in diameter, but with the grommets, the diameter of the intake pipe will be 3".
2008 JK
warCryr is offline
post #42 of 112 Old 03-20-2010, 06:12 PM
WindMeUp
2010 JK Wrangler
Looking great so far, can't wait to see more!
2010 Jeep Wrangler Rubicon - Stone White
| TeraFlex 2.5" Performance BB w/ Shock Adaptors | AEV Pintler 17" in Argent | BFG KM2 35x12.50r17 | Rough Country 1.25" Body Lift | OR-Fab Tire Carrier w/ Can Mount | TeraFlex 3rd Brake Light Relocation Bracket |
WindMeUp is offline
post #43 of 112 Old 03-20-2010, 07:20 PM Thread Starter
warCryr
thanks for the enthusiasm, it motivates me.
congrats on the new jk btw
edit: didn't see you were already a jk owner ha, congrats anyway
2008 JK
warCryr is offline
post #44 of 112 Old 03-21-2010, 09:18 AM
nate320
2009 JK Wrangler
I am addicted to this thread! I soooo wish I had the technical know how to do this myself! Be that as it may, great project and write up!
2009 Black JK Wrangler 2 Dr
Mods: None yet...
nate320 is offline
post #45 of 112 Old 03-21-2010, 01:09 PM Thread Starter
warCryr
ha. i dont know what i'm doing, im just making it up as i go. just hoping i dont screw up too bad.
and hoping that people learn from my mistakes or get ideas from what I do for there own project(s).
2008 JK
warCryr is offline
airbox , cowl , custom , intake , snorkel
question on cowl snorkel write up... majkowskid TJ Wrangler Technical Forum 11 07-23-2009 06:23 AM
Snorkel into cowl vent? RODKNOCKER YJ Wrangler Technical Forum 4 02-27-2005 10:01 PM
cowl snorkel Dome TJ Wrangler Technical Forum 2 11-08-2003 10:21 PM
YJ cowl intake (snorkel). BamaJeeper YJ Wrangler Technical Forum 8 03-13-2003 12:46 AM
