-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   JK Custom Cowl Snorkel? (http://www.jeepforum.com/forum/f96/jk-custom-cowl-snorkel-958737/)
warCryr 01-28-2010 11:46 AM
I've been looking for a snorkel I like for a while and although I like the ones that River Raider and AEV make, I want something different. I've decided to pursue the creation of my own custom snorkel.
After thinking through a few designs of my own, instead of coming out the side of the hood or the fender, I've decided that a good place would be the left side of the cowl. (I'm not sure if its called a cowl) Its the strip of metal that the wipers come up through between the wind sheild and the hood.
Here is a photo of hummerstyle cowl snorkel on someone elses jeep.
http://home.comcast.net/~tharmon24/4...er_Snorkel.jpg
Here is an under-hood photo as an example:
http://i50.photobucket.com/albums/f3...9/DSC00104.jpg
Installing something like this would require cutting a hole through the fire wall and again up through the cowl.
Is this a good, bad, or crazy idea? Any ideas or thoughts that would be helpful to me making my decision on how to create my snorkel?
Thanks in advance. Any input is of interest.:cheers:
mattman8706 01-28-2010 12:02 PM
I did that on my TJ... a long time ago.
I will find the thread..
krutj 01-28-2010 12:30 PM
This is also my next mod. I wonder if the cowl idea might be a little low?
could a big splash get sucked in from the hood area? Just curious. Keep posting if you proceed, I'll be subscribed:thumbsup:
Grant211 01-28-2010 12:33 PM
Not my jeep, but this write up will probably help you guys out.
Fresh Air Intake / Adjustable Snorkel - JkOwners.com - The Community for Jeep JK 4x4 Owners
http://i976.photobucket.com/albums/a...sCamera348.jpg
Evil_Trolloc 01-28-2010 12:35 PM
This is pretty much the same type of setup I'm planning. My main reason is I'd end up ripping or crushing the tube right off.. Seeing as how I've already smashed in my windshield frame once and have been REALLY close enough times...
It's something I won't be starting till spring rolls back around.
Evil_Trolloc 01-28-2010 12:38 PM
Just keep a 2 or 3 foot section of pipe in the jeep.. When your about to cross some deep water, throw it on.. And keep it off for every day use
McKBrew 01-28-2010 12:46 PM
I know a guy running the Rive Raider full length snorkel. He's whacked it pretty hard on the trail with no issues.
krutj 01-28-2010 02:23 PM
DUH...I kinda feel stupid, great suggestion, I really shoulda seen that though:thumbsup:
GRANT211-thanks for the link, that was a good write up!
warCryr 01-28-2010 03:33 PM
thanks for the replies everyone, its really convincing me to do this. and awesome find on the writeup!
warCryr 02-14-2010 08:50 AM
Ok, some progress.
One step at a time, I have a good start.
Battery Relocation:
Removed battery
http://harterc2.webs.com/photos/airbox1/br1.JPG
Filed down tabs to make room. This was a slow process using a hand file.
http://harterc2.webs.com/photos/airbox1/br2.JPG
Got a plastic battery tray from Autozone and cut it to size.
http://harterc2.webs.com/photos/airbox1/br3.JPG
Battery relocated:
http://harterc2.webs.com/photos/airbox1/br4.JPG
The autozone battery tray is bolted down using the same hole that held the battery in place previously.
Its ok for now, but I'll have to find a better way to hold it in place sooner or later.
warCryr 02-14-2010 09:05 AM
airbox mod
I have a good start on my airbox mod.
Factory "snorkel" removed.
http://harterc2.webs.com/photos/airbox1/a1.JPG
Sawed off and filed down factory snorkel mount.
http://harterc2.webs.com/photos/airbox1/a2.JPG
Filed down tabs on side of airbox to make room for the new mount.
http://harterc2.webs.com/photos/airbox1/a3.JPG
Filed down the new mount so that it would fit on the side nicely.
http://harterc2.webs.com/photos/airbox1/a4.JPG
To cover the hole where the old mount had been, I cut out a piece of PVC and filed it into a shape that would fit nicely over the hole.
http://harterc2.webs.com/photos/airbox1/a5.JPG
http://harterc2.webs.com/photos/airbox1/a6.JPG
Drilled screw holes in the new mount and in the pvc cover.
http://harterc2.webs.com/photos/airbox1/a7.JPG
http://harterc2.webs.com/photos/airbox1/a8.JPG
Drilled/sawed/filed out a hole where the new mount will be attached.
http://harterc2.webs.com/photos/airbox1/a9.JPG
http://harterc2.webs.com/photos/airbox1/a10.JPG
One side at a time:
Started the screws through the mount screw holes to make life easier once I had it in place. Applied Permatex black silicone adhesive sealant on the entire mounting area. Placed the mount on the area and screwed the screws in the rest of the way in.
http://harterc2.webs.com/photos/airbox1/a11.JPG
http://harterc2.webs.com/photos/airbox1/a12.JPG
I have yet to plug the drain holes in the bottom of the airbox.
1222 02-14-2010 10:26 AM
Wow, very interesting. Nice work with the hand tools. Did you smooth out the inside of the tube where all the silicone is?
warCryr 02-14-2010 12:20 PM
I tried but the silicone was getting everywhere so I did what I could to make it look clean and then left it. I may have used too much on that end.
That side didn't go on as nicely as the larger piece, screws wouldn't line up and stay in the holes, things were slipping...etc
Maybe i can cut off the access silicone after it drys with a knife.
krutj 02-14-2010 12:38 PM
Great job...I'll bet you can fool around with the dried silicone later. I'm following you all the way. I prefer self-mods. Gave you the thumbs up for the post!
Summit Jeep 02-15-2010 10:19 PM
:thumbdown:
The time now is 09:45 PM.
