JK CB Antenna Mounts - JeepForum.com
post #1 of 7 Old 08-06-2008, 12:21 AM Thread Starter
DiscoBayJoe
Beer is Food!
DiscoBayJoe's Avatar
Hey All,
Last Fall I installed a all-band IC-7000 Ham Radio in my Jeep:
http://www.jeepforum.com/forum/f96/electronics-cabinet-radio-install-481336/
I decided it was finally time to put the HF antenna on. I found the following two products:
http://tmrce.stores.yahoo.net/jeep-w...amp-cable.html
http://www.teraflex.biz/installsheet...BM_install.pdf
And since one mounted on the left and the other on the right, I figured i'd get them both.
Here's a pic of them both on the Jeep:
Here's the Teraflex:
and here's the CFE Products:
Here is my Diamond Trunk Mount w/dual band from the previous install:
The dual bander has worked out really well for the last year. Notice how the black bar lined up perfect! (no, I didn't paint it, it was built like that!)
Here's a close up of the outbacker in the CFE mount. It presses just slightly against the spare tire (it's a thick antenna)
I still need to pick up some coax and build out the teraflex mount. I also plan to run a dedicated ground to both mounts. The teraflex mount is very well built. If they made the teraflex mount for both sides I woud definitly run them on both sides. I think long term I''ll have the outbacker on the Teraflex and a FireStick CB antenna on the CFE.
Here's the final shot:
This weekend I should be able to tune up the antenna. Stay Tuned!
2008 JKUR 3.5" Frankenlift - RK/Artec/Synergy/Reid/Currie - PSC Armor - 35" MTR/K's
DiscoBayJoe is offline
post #2 of 7 Old 08-06-2008, 01:09 AM
nwm52
nwm52's Avatar
I like the reflection on your rear window.
nwm52 is offline
post #3 of 7 Old 08-06-2008, 09:06 AM
XCELER8
looks clean!
2008 Jeep Green Metallic X 2 door
Firefighters Jeep Club
XCELER8 is offline
post #4 of 7 Old 08-06-2008, 09:35 AM
BRICKTOP2
Unhingd PigFeedng Gangstr
BRICKTOP2's Avatar
I have the Teraflex too. It's perfect for mounting an offroad flag on in addition to the antenna. Looks good man!
"Tightening the nut behind the wheel is the most cost effective way to improve the performance of any vehicle."
JK Build Thread
TJ Tub Trailer
BRICKTOP2 is offline
post #5 of 7 Old 02-09-2011, 05:57 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Drudging this back up...
I picked up a firestick 3' fiberglass antenna, 18' coax, teraflex mount, and the adapter piece for the antenna to coax. Do I need to run a dedicated ground from the adapter piece or will I be alright without (shouldnt the mount itself technically be grounded)? Also...where can I go to tune the antenna if I don't have a SWR meter (or is a meter inexpensive)??
Thanks, guys. Mike
Mol is offline
post #6 of 7 Old 02-09-2011, 07:16 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Yes, ground the antenna to the mount and the door to the chassis (I used some flex copper cable near the hinge) and most CB shops will help you tune it, esp if you buy the antenna from them. Rocky, also
W6TMV
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #7 of 7 Old 02-09-2011, 08:46 PM
Mol
Mol's Avatar
W6TMV
Thanks again, man Mike
Mol is offline
cb antenna mounts...n2rock wrestlerobx JK Wrangler Technical Forum 17 03-02-2009 01:34 PM
Antenna Mounts for 2008 Rubicon MikeSD Wrangler General Discussion 2 02-18-2009 10:09 PM
CB and antenna mounts Marauderk JK Wrangler Technical Forum 11 07-25-2007 06:22 PM
Antenna Mounts JFiorentino TJ Wrangler Technical Forum 4 05-14-2004 01:59 PM
