JK Caster - Page 2 - JeepForum.com
post #16 of 24 Old 06-17-2013, 02:48 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Generally balance issues, but yes crappy joints a few times and a couple seized up slips, though I have had the seized slip issue with Coast, as well...coast replaced it for me at no cost well outside of a year, while Tom Woods did nothing to help. We don't call them anymore.
Mol is offline
post #17 of 24 Old 06-20-2013, 08:41 AM Thread Starter
razor1115
AEV brackets arrive today. Will follow up after install. Also to note, I understand the clearance comments. I also looked at the rear, stock lower control arm bracket and it appears to hang lower than the front bracket lower control arm bracket. I didn't measure it yet, just my observation, which makes my bracket decision easier for me (along with realigning the control arms to minimize load input through the frame = better ride, and the pinion angle issue), compered to adjustable control arms.
razor1115 is offline
post #18 of 24 Old 06-20-2013, 09:10 AM
Mol
Mol's Avatar
Keep drinking that kool-aid
Seriously though, the brackets aren't a bad choice for what most of the aev followers build (something that looks good and seldom sees a gravel or dirt road). I'll never argue that, and there's nothing wrong with going for the look and driving it like any other car. Frankly, I wish I had a second JK with the look that I could drive daily
Mol is offline
post #19 of 24 Old 06-20-2013, 12:23 PM
aristobrat
2010 JK Wrangler
My experience from the last 4 years of dragging them over medium-sized rocks (like below) and bigger is that they haven't been a bad choice either.
aristobrat is offline
post #20 of 24 Old 06-20-2013, 12:42 PM
Mol
Mol's Avatar
They just won't let your axle do this
I'm not saying they don't work...just that what works and what is best are two different things, and also relevant to what you're using it for.
Mol is offline
post #21 of 24 Old 06-20-2013, 08:51 PM
aristobrat
2010 JK Wrangler
My fenders/bumpstops won't let my axle do that.
I understand that in theory, but after having wheeled for so long with these brackets, I'm not sure how that actually works.
Your pic shows some awesome flex that I know I can't match, but in the four years of following JK's with adj. control arms across rocks like (and bigger than) the one you're on, I haven't run into a situation where "lack of flex" has either stopped me, or made things harder. So I'm not sure what moving from "what works" to "what is best" actually gains me, if that makes sense.
post #22 of 24 Old 06-20-2013, 08:57 PM
Mol
Mol's Avatar
Traction
The less you're carrying tires, the better.
Mol is offline
post #23 of 24 Old 06-20-2013, 10:09 PM
DrHolliday
2011 JK Wrangler
One thing I've found is driving skill goes way further than rig capabilities. Stick someone who knows what they are doing in just about any rig and they will impress. Then you also have to account for the JK owners who are scared to scratch or dent their rig yet want it to be as capable as a buggy for their gravel road treks.
2011 JK Rubicon 2 door 6-speed manual, 3.5" Rock Krawler Suspension lift, 1.25" Daystar body lift, 40x13.50R17 Nitto Mud Grapplers
DrHolliday is offline
post #24 of 24 Old 06-21-2013, 07:37 AM Thread Starter
razor1115
Ok - parts received last night and installed last night update. The Jeep steers pretty close to stock again. I can now one-hand drive 70mph down the interstate, so caster is back. The ride is darn near back to factory, but going from 29" to 35x12.50" M/T, adding in a 4" suspension lift, you can't expect exact same OEM results. The ride is also less jarring, as the control arm geometry is now close to parallel to the ground, effectively minimizing the Y-axis input of force into the control arm up into the Jeep frame. Front drive shaft angle looks awesome. Those last two items wouldn't be resolved by adjustable control arms, so that's a benefit to me. Others would prefer to not lose the ~1-1.5" of ground clearance.
My measurements from the lower spring perch to the bottom of the frame was 7.25", as outlined by AEV in the install instructions. That called for hole #2 on the upper control arm AEV bracket. I elected to go to the bottom hole, adding a touch more caster, as I didn't want to mess with it again. My lift is a true 4", which states I should be in the bottom hole, per AEV. My MEASUREMENTS indicate I should be in hole #2. My decision was driven by not wanting to find I didn't have enough caster and mess with it again. All-in-all, pleased with the results, especially for $99 and 1 1/2 of my time.
My experiences with the AEV correction brackets:
  • The kit was easy to install, but had to take the drivers side upper control arm off the axle to get it out of the frame side bracket (clearance). No big deal, just retorque when installed
  • The passenger upper control arm frame bolt JUST cleared the exhaust hanger with no prying. Driver's side bolt was put in from Jeep in the correct direction to allow the bolt to slide out to the outside of the Jeep, not interferring with the exhaust to the inside (ie no need to cut any bolts)
  • Dont know what older JKUs have for heat shields, but my 2013 has one around the upper control arm, frame side to protect the bushing from catalytic converter heat. The shields need to be formed by hand back around this area after AEV bracket install. No provision in bracket to reinstall the lower heat shield bolt. No big deal, but will need to center punch, drill and tap a hole if you want it held by 2 fasteners. Should be room to do this, even after install
  • Ratchet straps make life VERY easy when shifting axle around to align bolt holes
  • Would be nice if all the supplied hardware has the same socket size as the OEM (no biggie)
My $.02, pleased with the results.
