JK Bumper/winch weight problem - JeepForum.com
post #1 of 29 Old 03-07-2011, 06:59 PM Thread Starter
noah2626
1987 YJ Wrangler
Guys, I need a little help... My wife was rear ended a few months ago in her JK and pushed into the truck in front of her. Well I took the chance and replaced the plastic bumpers with ARB bumpers front and back. With the front ARB Deluxe bumper and winch, I added roughly 200lb to the frontend. Now it handles like **** and it looks like it's squatting in the front. Is there a good solution for this? Has anyone had this problem? Would replacing the shocks do it?
Thanks
noah2626 is offline
post #2 of 29 Old 03-07-2011, 07:17 PM
animated_robot
2010 JK Wrangler
I'm running into a similar problem but in the back. I just ordered some spacers to make up the difference. Not sure how much your sagging but they make different size spacers to adjust for sag height.
animated_robot is offline
post #3 of 29 Old 03-07-2011, 07:24 PM
DAYJ
hmmm.... havent heard of ppl having problem with sagging, see if you can get some rubicon towing springs.... i want to say their stiffer
New- 2013 Commando Green Rubicon
Old-2010 Flame Red Rubicon Unlimited
Utah Jeep Crew Member #47
Cheyenne Trail Junkie
ROADS!? Where we're going, we don't need roads... (Doc)
DAYJ is offline
post #4 of 29 Old 03-07-2011, 07:25 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
new coil springs - old man emu mediums front, lights rear would probably level it back out without lifting, if you're not interested in lifting - someone correct me here if my choice of spring is incorrect
Edit: better yet, call dave at northridge 4x4 (northridge4x4DOTcom). I'm sure he will have a good solution for you
Mol is offline
post #5 of 29 Old 03-07-2011, 07:26 PM
jrmars07
2010 JK Wrangler
Synthetic Line should help lighten up the winch weight quite a bit too!
jrmars07 is offline
post #6 of 29 Old 03-07-2011, 07:29 PM
plrbear
Did you happen to have the alignment checked afterwards?
ITS ALL FUN AND GAMES TILL SOMEONE GETS HURT..... THEN ITS HILARIOUS!!!
2008 2dr JK Mostly stock...
Utah Jeep Crew #09
plrbear is offline
post #7 of 29 Old 03-07-2011, 07:30 PM
DAYJ
Synthetic rope FTW!!!!!!
DAYJ is offline
post #8 of 29 Old 03-07-2011, 07:32 PM
guarnibl
2009 JK Wrangler
Teraflex leveling kit.
I have the arb bumper and that fixed my problem.
Less than $200 on quadratec. Gotta drop suspension, but isn't too hard.
2009 Jeep Wrangler Rubicon (6mt) (in progress)
- 42x14.50 MTR's, Custom Cage, FF D60's F/R w/ ARB's and 5.38's, 4 Link Rear, 3 Link Front, 14" RR King 2.5's, 18" RR Fox 2.5's, Fox Air Bumps
- 108" wheel base
guarnibl is offline
post #9 of 29 Old 03-07-2011, 07:47 PM
joe002
My stock springs didn't like my winch and metal bumper either (lost 3/4" in the front).
New springs will fix it. I got a TF 2.5" spring lift.
2008 Rubicon - 2 Door - Flame Red - Automatic - MyGIG - Power Group - Deep Tint.
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Stubby Bump, Currie F/R Adj Trac Bars, Daystar Upper Dash, FireStik FireFly antenna, Kilby Rear Shock Skids, LoD Sig Stubby Bump, Midland 75-822 CB, Mopar Filler Door & Locking Gas Cap, Rancho LCA Skids, Rancho Oil Pan Armor, Riddler Diff Covers, custom Rubi Sliders, Sylvania X-treme Headlights, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relo, Woods SS Relo, Yukon 5.38s
joe002 is offline
post #10 of 29 Old 03-07-2011, 08:15 PM
Charles
2017 WK
Don't forget air-bags...You'll get rid of a A LOT of weight if you get a synthetic line like a member sated earlier.
2017 TrailHawk Hemi, Everything but the TV's.
Charles is offline
post #11 of 29 Old 03-08-2011, 09:02 AM Thread Starter
noah2626
1987 YJ Wrangler
I can see it's got the top of the tires turned in when driving down the road.
noah2626 is offline
post #12 of 29 Old 03-08-2011, 09:11 AM Thread Starter
noah2626
1987 YJ Wrangler
I went with this bumper because they said it was one of the few that were compatable with the airbags. But I never saw any signs of a sensor for the bag while putting on the bumper.
On the lift... I'm not ready to spend money on new tires yet, so if I add 2.5in I'm not sure if it will look right.
But I brought this to my wife for the first time last night and she says that it feels dangerous around hard turn. I know I have to make a change in the setup, thank you for everyone's help. I'm going to look into the leveling kit.
noah2626 is offline
post #13 of 29 Old 03-08-2011, 09:35 AM
Caribic-TJ
Nice bumper, put 1" spacers on top of the front springs.
08 JKU Rubicon
98 TJ Sahara fully locked
Caribic-TJ is offline
post #14 of 29 Old 03-08-2011, 10:11 AM
ncb
The crush cans make it "airbag compatible". On a lighter forward impact the crush cans absorb the energy and hopefully the airbags wont deploy unless needed. Most aftermarket bumpers don't have crush cans. With out crush cans the airbag might deploy on a lighter impact. The airbags will work regardless of the bumper installed.
The sensor isn't in the bumper. IIRC the sensor is below the center console and each seat has a sensor.
ncb is offline
post #15 of 29 Old 03-08-2011, 05:07 PM
Max-Q
1983 CJ7
Airbags don't use pressure sensors they use a computer installed inside the vehicle. The computer will deploy the airbag when the delta V (change in velocity) meets a specified level. The computer actually predicts an accident based on it's measured perimeters and deploys the airbags upon impact. Second generation airbags have two charge loads and will deploy one or both depending on the delta V reading and whether or not the occupant is wearing a seatbelt. If the occupant is not wearing a seatbelt the delta V levels necessary to trigger a deployment are lowered and both charges will fire in order to get the airbag deployed faster.
The delta V required to deploy the airbag can not be obtained by locking up the brakes. The G forces required are far greater than the capabilities of a standard production braking system.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
Spring Rates V. Travel (weight of bumper & winch) Running925 TJ Wrangler Technical Forum 17 08-12-2010 01:03 PM
avg bumper/winch weight? rballman JK Wrangler Technical Forum 2 09-15-2009 01:35 PM
Rugged Ridge XHD Non Winch Bumper Stronger than Bumper w/ Winch Plate??? mlupacchino JK Wrangler Technical Forum 7 04-21-2009 06:01 PM
winch weight bigV TJ Wrangler Technical Forum 20 11-07-2006 08:00 PM
Extra weight on Rear Springs compared to front springs (winch compared to bumper) Sparty TJ Wrangler Technical Forum 3 12-17-2005 07:03 PM
