JK Bumper/Winch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > JK Bumper/Winch
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 03-05-2012, 09:41 AM   #1
jokerswild2k
JK Bumper/Winch
I've got an '08 Rubicon that is pretty much stock (hard to get parts when stationed overseas). Now that I'm back stateside I'm looking to start the upgrade process. I've been looking at a lot of bumpers and winches and scrubbing this forum. I'm leaning heavily towards the Wild Boar front bumper. I love the look, I was wondering if anyone knew anything about it's functionality, tire clearance (eventually I'm planning on going up to 35's), etc. Also torn between the Warn VR8000 and the M8000. I'm trying to decide if saving a couple hundred bucks is worth it since the M8000 is such a proven winch. This rig is my DD, and I try to get into the sand/trails every weekend with a couple of long-range trips (Georgia/Alabama) per year. Any advice, input, or personal experience/opinions are greatly appreciated.
jokerswild2k is offline   Reply With Quote
Unread 05-04-2012, 10:06 AM   #2
bjdean16
2009 JK Wrangler
I went with the M8000 for a cheaper price than the VR8000. Double the line spend and American made! Streetside auto has the M8000 for $459 after rebate. Use coupon AFQ21230. I also picked up a body armor high clearance front bumper about a month ago.
2009 JKU Auto, 33" BFG KM2, 1.5" Spidertrax, Teraflex Leveling & Disco's, Body Armor Front Bumper & Skid, Warn M8000S
bjdean16 is offline   Reply With Quote
Unread 05-04-2012, 01:42 PM   #3
SubAtomicGenius
Sarcastic Fantastic
SubAtomicGenius's Avatar
2011 JK Wrangler
Warn M-Series and XD-Series are the "premium" series winch. Warn VR-Series is the "entry" level winch. You get what you pay for. Read all about them at www.warn.com
--/ 2011 Jeep Wrangler JKU - The White Coyote /--
Support our Jeep community and actively participate in our threads! Use thumbs up for good & helpful posts!
My Build: http://www.jeepforum.com/forum/f96/c...hread-1339466/
Teraflex - General Tire - Poison Spyder - AEV - Warn - Yukon - ARB - Aussie - Motive Gear - Rigid LED - Procomp - Synergy - EVO - Viair
Poison Spyder and AEV had a baby: the only JKU with a Poison Spyder bumper and an AEV Tire Carrier!
SubAtomicGenius is offline   Reply With Quote
Unread 05-04-2012, 03:55 PM   #4
Brian_in_MT
Edit, nevermind. I misread.
Both are made in America though.
Brian_in_MT is offline   Reply With Quote
Unread 05-05-2012, 05:49 AM   #5
Orange1
Another chioice is aluminum bumpers. I purchased the RR XHD series aluminum front bumper and saved much weight. They are really not that more expensive than steel bumpers with the same features. Save that weight!
Orange1 is offline   Reply With Quote
Unread 05-05-2012, 07:47 AM   #6
Coppage
2009 JK Wrangler
How tough are the aluminum bumpers should you say... Bump into something or get bumped? Will they bend or dent easy?
Thanks.
Coppage is offline   Reply With Quote
Unread 05-05-2012, 10:29 AM   #7
zjilla
as for winches....you get what you pay for so be careful. just remember that the winch could be put to a lot of workload so i wouldn't skimp. Some people have had great experiences with cheaper winches and some have had horror stories. ask molshove
2007 Unlimited Sahara
zjilla is offline   Reply With Quote
Unread 05-05-2012, 11:21 AM   #8
PhatJK
2009 JK Wrangler
Thanks.
A common misconception of aluminum is weaker than steel. If you have enough thickness of aluminum to handle the mechanical stress, then aluminum behaves just like steel or better than steel and is lighter too.
Sheet steel is used in automobile, Jeep included, because it is many times more cost efficient comparing to aluminum. If aluminum is cheaper, we are all driving in aluminum cars.
[URL="http://www.flickr.com/photos/14945982@N08/"]My Flickr Page[/URL]
[SIZE="3"][COLOR="White"][B]09 Unlimited Rubicon [/B][/COLOR][/SIZE]
Teraflex 2.5" spring lift kit
ORFAB tire carrier
PhatJK is offline   Reply With Quote
Unread 05-05-2012, 11:33 AM   #9
taoshum
For a beam, (bumpers) the deflection is usually proportional to the EI product. E for Aluminum is 1/3 that of Steel, so the Aluminum needs to be 3X's thicker for the same geometry to have the same deflection. It weighs about 1/3 as much as steel so it kinda balances out. Aluminum is usually much softer though so impact damage on the "surface" will be much easier... gouges, scraps, etc. For the same geometry (thickness), Aluminum will weigh far less.
Geezer from NM
"Wisdom isn't cheap; we pay for it with pain
taoshum is offline   Reply With Quote
Unread 05-05-2012, 11:59 AM   #10
PhatJK
2009 JK Wrangler
Originally Posted by taoshum View Post
For a beam, (bumbers) the deflection is usually proportional to the EI product. E for Aluminum is 1/3 that of Steel, so the Aluminum needs to be 3X's thicker for the same geometry to have the same deflection. It weighs about 1/3 as much as steel so it kinda balances out. Aluminum is usually much softer though so impact damage on the "surface" will be much easier... gouges, scraps, etc. For the same geometry (thickness), Aluminum will weigh far less.
I think you are correct for the proportional load in axial. Beam deflection I believe is less for aluminum for an equivalent stress due to the MC/I. And when you design for the "I" term carefully, you get a stiffer alum structure for equivalent strength. You see high end car like Corvette ZR6 using deep section aluminum channels because they want to get the high "I" to maximize the stiffness to weight. The same thing for other monocoque race cars.
But for the run of the mill bumper plate, 3x the thickness should suffice.
ORFAB tire carrier
Unread 05-07-2012, 12:07 PM   #11
bjdean16
2009 JK Wrangler
Not exactly true...M8000 winch is 100% made in America. The VR is assembled in American with the use of foreign manufactured parts. This is how they keep the cost down and compete with the Chinese winches.
I'm not saying it's a bad winch and if I were to go with a foreign winch I would prefer Warn to stand behind it! But at less than $100 difference and double the line speed...I'll choose the M8000 everytime.
Unread 05-07-2012, 12:37 PM   #12
wardo
2011 JK Wrangler
I've got the warn m8000 on my rig. the way I see it, a poor man can't afford to buy cheap.
plus if I ever need to bust out the winch, I want to know darn well that its gonna get the job done, not just hope.
2011 Flame Red 2dr Wrangler Rubicon, Poison Spyder Evap Skid, Extended Breatherlines, 4' Firefly Antenna, Uniden Pro520xl, Rock Krawler 2.5 Stock Mod Lift, Bilstein 5100's, Rugged Ridge XHD Front Bumper, Warn M8000, Rugged Ridge XHD Snorkel
wardo is offline   Reply With Quote
advice , bumpers , winch
