JK brakes these are going to set the standard! - JeepForum.com
post #1 of 2 Old 06-08-2006, 02:43 PM Thread Starter
barry1me
barry1me's Avatar
I used to be an engineer at TRW and JK was one of the programs I worked on. I was in the development stages Pre SO and S1 builds. As we all know the CJ brakes sucked, YJ was better, and TJ was better yet. The JK is a whole new game. DCX is using the JK as a pilot build for other programs brake systems that I know of. These brakes (calipers specific) are going to be carryover to the new minivan RT which is coming out late 07. When We (TRW) developed the brakes they had to be strong enough for the RT which was about 1000lbs heavier then the JK. I know longer work for TRW but Im excited to see how well of a system the JK will have. TRW makes a great brake system, so I think we will all be pleased with the JK. Also the Rotors are almost all machined instead of Cast, so they should have a much better pedal feel, and 'should' last longer
barry1me is offline
post #2 of 2 Old 08-11-2006, 09:40 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Hey, that's a great news. I'm not happy with the TJ's 4-disc brakes. I would be buying one around 2008-2009. Would love to keep my 2004 TJ and have both.
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
Knocking: front brakes, rear brakes, drive shaft(?) Ujoints Or Drums? Help? VanBCguy TJ Wrangler Technical Forum 14 01-31-2013 07:34 AM
Replace Rear D44 Drum Brakes with Newer Factory D44 Disc Brakes? NIB-98TJ TJ Wrangler Technical Forum 18 12-30-2009 07:55 PM
95 Front brakes are dragging rear brakes lock up instantly 72RatCamaro YJ Wrangler Technical Forum 2 03-18-2009 06:25 AM
Converting rear drum brakes to disc brakes Urb4nTr0ll YJ Wrangler Technical Forum 4 05-15-2008 06:16 PM
Brakes brakes brakes....Whos got good brakes? Tacoma750 TJ Wrangler Technical Forum 20 12-17-2006 09:15 AM
