JK Battery Group Size? - JeepForum.com
post #1 of 6 Old 07-17-2007, 02:21 PM Thread Starter
79bigmack
79bigmack's Avatar
Anyone know what the group size is on the JK's battery?
Will a Group 31 battery fit?
thanks,
Mack
-Mack
Current Ride: '08 Grand Cherokee 4x4
Past trucks:
2000 Cherokee Sport 4x4 :(
2004 Discovery :(
2003 F-150 4x4
79bigmack is offline
post #2 of 6 Old 07-17-2007, 06:39 PM Thread Starter
79bigmack
79bigmack's Avatar
Anybody??
I know some of yall are running winches...hopefully you upgraded the battery!!
-Mack
Past trucks:
2004 Discovery :(
2003 F-150 4x4
post #3 of 6 Old 07-18-2007, 08:41 AM
Volley
I have a deep cycle in mine but don"t recall the size. Will look when I go out to the garage.
Volley is offline
post #4 of 6 Old 07-18-2007, 10:13 AM
MichaelW
MichaelW's Avatar
Yeah I got a Red Top but when I went to Summit Racing I just said I need a Red Top for my new JK and they gave me a box. I didn't pay attention to size either. I'll go check.
Michael W
Welcome to the Free World!
MichaelW is offline
post #5 of 6 Old 08-14-2007, 09:10 PM
IndyJpr
I had an Optima (group size 34) in my old Jeep and was also wondering what size the JK had...couldn't find an answer so I just tried it - it fit!
FYI for anyone considering an Optima - the Optima's posts are closer together than the stock battery so the connectors work better if they are adjusted to an 90 angle verus straight.
Regarding OP question:
It looks like W and H would be OK, L might be a problem. The 31 looks like it is about 2 3/4" longer than the 34. There only about 3/4 to 1" space and each side of the 34 BUT the plastic has some give so you might be able to squeeze it in there.... The JK uses clamps at the base of the battery for retention so the new battery would need to be compatible (have the little ridges).
Hope this helps...
IndyJpr is offline
post #6 of 6 Old 08-14-2007, 09:44 PM Thread Starter
79bigmack
79bigmack's Avatar
Hope this helps...
Thanks!
-Mack
Past trucks:
2004 Discovery :(
2003 F-150 4x4
battery size with winch ? larjeep TJ Wrangler Technical Forum 2 12-11-2009 04:38 PM
Battery size Janfri YJ Wrangler Technical Forum 1 01-12-2009 01:05 PM
Battery type or group? Sunvista TJ Wrangler Technical Forum 2 02-01-2007 04:54 PM
What size Battery? Woodyhfd TJ Wrangler Technical Forum 13 01-17-2007 02:04 PM
Group 27 battery tray KC2OTE YJ Wrangler Technical Forum 2 07-23-2006 10:40 PM
