JK 2" lift? - JeepForum.com
post #1 of 7 Old 04-25-2007, 08:34 PM Thread Starter
rondawg
JK 2" lift?
I just bought an X. I'm thinking of a 2" Teraflex lift and putting 285/70/17 BFG Muds. Is that enough lift? I was told adding more lift will void the warranty? Does anyone have a photo of this set up?
rondawg is offline
post #2 of 7 Old 04-25-2007, 08:38 PM
Squint
Squint's Avatar
I have a 1 3/4" Daystar Budget Boost with 305/70R17 Summit Mud Dawgs and only a very small amount of rubbing at fully cranked. The lift will only void your warranty if it causes a malfunction. The dealer has to prove it. Check this out: http://www.sema.org/main/semaorghome.aspx?ID=50096
Squint is offline
post #3 of 7 Old 04-25-2007, 08:43 PM
donkie
Warranties are never "voided" just put on restriction requiring the regional rep to personally inspect the vehicle before repair is authorized.
Recovering Jeepaholic
2007 Wrangler Sahara - SOLD
Geaux Tigers!!!
donkie is offline
post #4 of 7 Old 04-27-2007, 05:15 PM
rbrough1010
Quick Question
2" BB. Do I need the new shocks or will the lift be good without them. Do the new ones make that much of a difference. Extra money would go to better tires and/or air intake or rims, don't know which one yet.
rbrough1010 is offline
post #5 of 7 Old 04-27-2007, 07:35 PM
Matthew Davis
Hello,
I installed a Teraflex 2.5BB last weekend. The instructions were a total crapfest. The Xerox'ed quality instruction sheet had unintelligible photos and the 'one page document' had a second page stapled to it that told you how to install the 'substitute' front bump-stops because the normal (non crappy) ones were out of stock. The replacements required drilling. The normal ones would be drill-less pop-ins. The instructions also assume you already know what is going on. While the process is more or less self-explanatory, it would be nice if they did not assume you have taken apart a suspension before.
The parts seemed nice and stout otherwise and 2.5" looks higher than I expected.
-Matt
Matthew Davis is offline
post #6 of 7 Old 04-27-2007, 11:19 PM
Diesel0312
Originally Posted by Matthew Davis
Hello,
-Matt
I installed the Teraflex BB tonight. I didn't even look at the instructions they sent until I was finished. I took my laptop into the garage and went through this:
http://project-jk.com/jeep-jk-write-...ation-write-up
They should by the rights from the guy wrote and took the pictures, then include them with the kit.
2007 Jeep Wrangler Sahara Unlimited
Factory: Silver w/ black soft top, 18" wheels, auto
Mods: Windshield mounted Hella FF1000 driving lights, Rugged Ridge front grab handles, CLC rear grab handles, Teraflex 2.5" BB, Quadratec boor handle covers, Bestop spare cover, Custom front bumper, 17X9 Pro Comp 1079's, 305/17/R17 Buckshot Mudders.
In the works: Custom rear bumper.
Diesel0312 is offline
post #7 of 7 Old 04-27-2007, 11:39 PM
jeepers3
I disagree. Dealer only has to claim it. They can claim whatever they want. If you don't like their claim, then you have to take them to court and fight about it - which can be a long, grueling, and expensive process - even if you do eventually win some years later.
jeepers3 is offline
Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares planman JK Wrangler Technical Forum 44 01-31-2016 09:44 PM
Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift jondotcom TJ Wrangler Technical Forum 10 03-06-2010 02:43 PM
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
