Jim's Jeep; THE OBSESSION LIVES ON! - Page 6 - JeepForum.com
post #76 of 122 Old 05-19-2011, 03:35 AM
jeeperjk
2009 JK Wrangler
Jim, being that you said there are only 6 bolts holding together, would this be something that could be shipped easily or is that too much to ask? I might be interested in one myself later on down the road.
jeeperjk is offline
post #77 of 122 Old 05-19-2011, 10:17 AM Thread Starter
JLC08JK
What was I thinking?
JLC08JK's Avatar
Thanks' jeeperjk;
You made me look into the size constraints for UPS and it looks like I would need to add one connection point on each side to be able to break it down enough to reasonably ship.
The way it is, it could be fit into a large flat box about 4'x8'x8" though this is too big! I need to get it down to about 3'x6'x8" to avoid freight shipping.
Jim
JLC08JK is offline
post #78 of 122 Old 05-19-2011, 11:23 AM
jeeperjk
2009 JK Wrangler
I'll bet it'd cost a bit, too, huh...
jeeperjk is offline
post #79 of 122 Old 05-19-2011, 11:54 AM
UncieB
Looks great jeeperjk
UncieB is offline
post #80 of 122 Old 05-19-2011, 12:14 PM
jeeperjk
2009 JK Wrangler
Eh, that's Jim's rack, but thanks!
jeeperjk is offline
post #81 of 122 Old 06-13-2011, 11:56 PM Thread Starter
JLC08JK
JLC08JK's Avatar
I thought I was done building the rear end until I decided that it needed the Poly Performance shock relocation brackets with L.C.A. reinforcement and skids.
These raise the shock mounts 1-3/8" and provide 1-1/2" of extra clearance under the C/A's
I finally got all of the electrical parts to build 2 "source" type panels.
One for under the hood and one for the rear to power the O.B.A. and a few other things.
I also got a 1/8" BSP tap to make the adaptor for the ARB locker fittings.
With this I can finish the OBA install
Jim
JLC08JK is offline
post #82 of 122 Old 06-14-2011, 04:01 PM
wannahdawg
Looking good dude... as with everybody else, I applaud you on the rack. I'm also going to steal your exhaust idea and use it on mine....
Just Empty Every Pocket then Just Experience Extreme Performance
wannahdawg is offline
post #83 of 122 Old 06-15-2011, 02:28 PM
labgeek
2010 JK Wrangler
I love the rack too... IF you do decide to start offering them, think about a shortened version to fit the fastback style (ORH Whisper & BesTop NX) tops. If you do and want a website, hit me up. I'd be happy to do the site, and provide hosting for you.
Past: 2010 JK Unl. Islander, ORH Whisper Top (for now)
70-something DJ-5 RHD (years ago - never got over the thief who tried to steal it burning it)
labgeek is offline
post #84 of 122 Old 07-19-2011, 09:39 PM Thread Starter
JLC08JK
JLC08JK's Avatar
Finished my Viair compressor install last week and hooked up the ARB locker
I did a semi permanent install of the gauges, one for the 200 psi compressor and the other for regulated pressure to the air locker and a master switch for the comp/locker switches.
Then we went up to the High Seirras above Bishop CA. for some fishing and wheeling.
The locker and compressor work great with no leaks.
Came very close to sliding off a shelf trail in the second pic. The dark spot is where the tire was crawling itself over the edge and the rocks were placed to wedge the tire onto the trail
2011-07-16 09.37.11 bishop buttermilk trail.jpg   Snapshot 2011-07-18 19-55-40 close call arrow.jpg
Jim
JLC08JK is offline
post #85 of 122 Old 07-20-2011, 07:53 PM Thread Starter
JLC08JK
JLC08JK's Avatar
Here are a few more detailed pics of the ViAir System.
The small regulator in the tub is of high quality and dedicated to the air locker.
The air intake for the compressor is routed into the body behind the taillight next to the fuel filler.
I installed a distribution block at the battery with a 100 amp fuse then ran #4 cables back along the top of the frame to a fuse panel and a brass ground bolt in the tub.
0720111833-00 distribution block.jpg   0720111835-01 fuse panel.jpg   0720111835-00 locker regulator.jpg   0720111834-00 regulator.jpg   0720111835-02 air pump.jpg
Jim
JLC08JK is offline
post #86 of 122 Old 07-20-2011, 09:11 PM
jeepbronco1
Looking good Jim! Very Clean!
GREENERNSHlT - Homebuilds- tube fenders, infloor storage, bumpers, cage, sliders...etc
My TRUCK/SUT Build
http://www.jeepforum.com/forum/f96/jeepbronco1-sut-build-my-mini-truck-build-aka-bobbed-top-1178064/
jeepbronco1 is offline
post #87 of 122 Old 07-23-2011, 01:14 AM Thread Starter
JLC08JK
JLC08JK's Avatar
Here are a few more pic's of the project leading up to the compressor install.
All that is required to install this size tub/trunk in the back is to relocate the exhaust and the sway-bar, cut a giant hole in the back of your Jeep, then build a box that is large enough to hold the compressor yet small enough to clear the frame, shocks, AntiRock sway bar, and everything else that can't be moved.
0411111842-00 trunk insert.jpg   0411111845-00 trunk insert oba.jpg   0417111140-00 cut out tub.jpg   0417111225-00 new storage tub.jpg   0508111124-00 exhaust after 1.jpg
Jim
JLC08JK is offline
post #88 of 122 Old 08-15-2011, 12:57 AM Thread Starter
JLC08JK
JLC08JK's Avatar
Started work on a front bumper/winch mount.
Made a 1/4" winch plate that fits between the frame rails with 3/16" plate for the rest of the skin.
I'm using 1/2" round bar to frame a border for everything so I can put a nice radius on all the corners.
0814111731-01 bumper1.jpg   0814111731-00 bumper2.jpg   0814111731-02 bumper3.jpg
Jim
JLC08JK is offline
post #89 of 122 Old 09-14-2011, 10:45 PM
jeepbronco1
Damn it Jim !!!!! I missed the box build ! It's to pretty and I'm jealous!
Can't wait to see this bumper your building with the fab skills you throw down I wouldn't expect anything less than bada$$!
Also did you remove your rear sway bars?? I've heard there not a crucial part unlike the fronts ... Either way man the jeep is looking slick!
My TRUCK/SUT Build
post #90 of 122 Old 09-14-2011, 11:15 PM Thread Starter
JLC08JK
JLC08JK's Avatar
Thanks Brian
I put an AntiRock in the back that gets the bar out of the way up against the jack tub. I did this during the rear axle build.
The bumper is going slow as I'm getting ready to go to Colorado to pick up all the stuff to make my JK 4X4
Brent_f70 was nice enough to put a bunch of new stuff on his Jeep so I am getting a Rubi transfer-case and front axle along with a bunch of other needed parts for my build
Jim
JLC08JK is offline
Jim's new hybrid Scrambler build- tons of questions coming! jeepsterjc Jeep CJ Forum 1971 10-02-2016 07:38 PM
Obsession: "HEY! Use the search button" Baggot Wrangler General Discussion 17 02-05-2009 02:28 PM
Jeep Lives Again!!!!!!!!!!!!!!!!!! rebelone50 YJ Wrangler Technical Forum 0 10-06-2008 05:49 PM
Jeep lives...then dies, over and over again. dcvance87 YJ Wrangler Technical Forum 1 10-28-2007 09:15 PM
Jeep died, and then lives again? BLAINE TJ Wrangler Technical Forum 5 12-29-2005 06:58 AM
