Jim's Jeep; THE OBSESSION LIVES ON! - Page 5 - JeepForum.com
post #61 of 122 Old 03-01-2011, 11:03 AM Thread Starter
JLC08JK
What was I thinking?
JLC08JK's Avatar
Thanks' Dronac
I'm still working on a way to produce them affordably.
I also need to work out a different mounting bracket for the back.
When I installed the Antirock there was some interference that I had to modify for and I would rather the rack mount to the body rather than the frame in such a way that has no visible holes drilled in the tub.
I hope to build ten racks in the near future and see what the labor cost will be.
Jim
JLC08JK is offline
post #62 of 122 Old 03-01-2011, 03:12 PM
Dronac
I'll be watching this thread then. If you can produce a 2 door variant and I can afford it, I will be all over it
2008 Jeep JK X: auto trans, 3.73 gears, D44 rear, D30 front
Mods: 2'' Rusty's coil lift, Superchips 93 octane tune, Cobra 75 CB radio, 33'' Duratrac's, onboard air compressor
My Build Thread! ---> http://www.jeepforum.com/forum/f96/dronacs-build-thread-1104134/
Dronac is offline
post #63 of 122 Old 03-02-2011, 06:06 AM
MikeyN
I'm with Dronac, I'd be interested in a 2dr as well pending on the price. Your rack there looks awesome and much better to what else is on the market.
MikeyN is offline
post #64 of 122 Old 03-02-2011, 02:09 PM
michaelmjc
If you make a 2dr version, I will scoop it up in a second. Beautiful work.
michaelmjc is offline
post #65 of 122 Old 03-28-2011, 01:08 PM
NappiNunn
2010 JK Wrangler
Did your 35's rub with your rc 2.5in bb?
NappiNunn is offline
post #66 of 122 Old 03-28-2011, 01:28 PM Thread Starter
JLC08JK
JLC08JK's Avatar
Yes they rubbed the back of the front bumper while going around bends and the flares at times.
My JK being a 2wd came with some very low rated coil springs and when compared to other X models was allot lower to start with. You probably won't have the same rubbing issues that I did. Look at my first picture and compare to your stock height, yours should be higher!
Jim
JLC08JK is offline
post #67 of 122 Old 03-28-2011, 01:34 PM Thread Starter
JLC08JK
JLC08JK's Avatar
I've been promising a sound-clip of the exhaust for some time now!
I tried to make one though my video camera wont link with my computer, the camera is to old to get the proper drivers installed. Time for a new camera.
So, Here are a couple that I found, Not mine but the same set-up!
The second one has the same muffler re-location as I did.
Neither really does it justice but they are pretty close.
In real life it sounds a little deeper and has some popping at throttle down.
Jim
JLC08JK is offline
post #68 of 122 Old 03-28-2011, 03:36 PM
Sandlapper3396
Sandlapper3396's Avatar
2009 JK Wrangler
Dude, I applaud all the work and effort you have done to your jeep so far. There can't be many people that bothered with doing a 2WD to 4WD conversion.
Sandlapper3396 is offline
post #69 of 122 Old 04-16-2011, 09:00 PM
viperbluelx
have you got a parts list of the 2wd to 4x4 conversion yet?
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline
post #70 of 122 Old 04-16-2011, 09:16 PM Thread Starter
JLC08JK
JLC08JK's Avatar
Only a list in my head right now
I'm sure that once it's started it will need some little parts but the main list should only be a transfer-case and cross-member, front axle assembly, drive-shafts, and this should do it. The outer knuckles, unit bearings, brakes, and suspension are all the same.
If you get the transfer-case from Advanced Adaptors they have a list of options and required parts for a JK installation. If you use a stock T/C you will need all the linkage and wiring that goes with it.
Jim
JLC08JK is offline
post #71 of 122 Old 05-05-2011, 05:10 PM
usmc20c
I agree with Dronac. If you can get this set up for a 2dr and at a reasonable price I will all over it!!! Have you done a load test on it yet? I have been seeing online where some racks are rated at 300-400 lbs... If you ever need a "test vehicle" to use for a 2dr version i'm more than willing - I located down the road from you in San Diego...
usmc20c is offline
post #72 of 122 Old 05-05-2011, 05:34 PM Thread Starter
JLC08JK
JLC08JK's Avatar
I've had over 600lb on it with no problems.
10 sheets of 5/8" drywall, it was only for a few miles but all was stable.
I'll keep you in mind for the 2 door version
I'm getting very close to being ready to market.
Welcome to the Club
Are you stationed at Camp Pendleton?
Jim
JLC08JK is offline
post #73 of 122 Old 05-06-2011, 12:52 PM
usmc20c
600 lbs!!!! SWEEET... Much better than those other ones I have been seeing online!
I'm stationed down here at MCAS Miramar.
Sgt Carlile, Craig
USMC - Active
San Diego, CA
usmc20c is offline
post #74 of 122 Old 05-19-2011, 12:39 AM
jrmandryck
looks great
truth is so precious that she should always be attended by a bodyguard of lies...
jrmandryck is offline
post #75 of 122 Old 05-19-2011, 01:15 AM Thread Starter
JLC08JK
JLC08JK's Avatar
Thanks!
I recently had to re-re-do the back part of the exhaust.
In putting in my replacement storage tub there were some clearance issues with the tail pipe. It worked out for the better because the end result looks much better than the original install
More on the storage tub and OBA install coming soon!
Here are the before and afters.
0417111226-00 exhaust before.jpg   0508111124-00 exhaust after 1.jpg   0508111125-00 exhaust after 2.jpg
Jim
JLC08JK is offline
Jim's new hybrid Scrambler build- tons of questions coming! jeepsterjc Jeep CJ Forum 1971 10-02-2016 07:38 PM
Obsession: "HEY! Use the search button" Baggot Wrangler General Discussion 17 02-05-2009 02:28 PM
Jeep Lives Again!!!!!!!!!!!!!!!!!! rebelone50 YJ Wrangler Technical Forum 0 10-06-2008 05:49 PM
Jeep lives...then dies, over and over again. dcvance87 YJ Wrangler Technical Forum 1 10-28-2007 09:15 PM
Jeep died, and then lives again? BLAINE TJ Wrangler Technical Forum 5 12-29-2005 06:58 AM
