Jeep Enthusiast Forums banner
Jenny Craig's Regret (or how I made more cushion for the pushin')
62K views 457 replies 31 participants last post by  NYGLT56
#1 ·
Current build sheet (as of 26 Jan 16):
Suspension
  • 4" Currie Suspension
  • Upper and Lower Johnny Joint adjustable control arms
  • Progressively wound coil springs
  • Front urethane bump stop kit
  • Rear bump stop spacers
  • Rear coil spring retaining kit
  • Stainless braided extended brake line kit
  • TeraFlex tuned Fox Racing 2.0 Long Travel Shocks w/ Remote Resivoirs
  • TeraFlex Front and Rear Speedbumps (4"-6" Lift)
  • Synergy Rear Long Travel Upper Shock Mounts w/ Synergy bar pin eliminators
  • ANTIROCK® Front Sway Bar
  • ANTIROCK® Rear Sway Bar
Wheels and Tires
  • 37x12.50R17 Cooper Discoverer STTs
  • 17x9.5 Raceline Monster Beadlocks w/ Steel outer ring
Armor
  • MetalCloak's Frame-Built Jeep Bumper w/ fairlead and light bar
  • Superwinch EPi 9.0 w/ synthetic line and Factor 55 ProLink Loaded Thimble
  • PSC BFH rear bumper w/ shackle tabs
  • PSC Rear Crusher Corners w/ TruckLite clear LED tail lights and reverse lights
  • Rock Hard 4x4 Parts Oil Pan, Transmission & Catalytic Converter Skid Plate
  • Rock Hard 4x4 Parts Fuel Tank Skid
  • SJKS Prerunner Rock Sliders
  • RROR Evap Canister Skid
Drivetrain
  • Adams 1310 Front and Rear Driveshafts
Front Axle
  • Dana 44
  • 5.13 Superior gears
  • RCV Shafts
  • Reid Racing High Steer Knuckles
  • Synergy Suspension Ball Joints
  • Synergy Suspension HD tie rod
  • Synergy Suspension HD flipped drag link
  • Synergy Suspension Track Bar Relocation Mount
  • E-Locker
  • JW Fabrication front axle truss
  • Ballistic Fabrication Diff Cover
  • TeraFlex Sleeves
  • Gusseted
  • TeraFlex Monster HD Track Bar
  • Lower Control Arm Skids
  • Frontend Housing Johnny Joint Kit
Rear Axle
  • Dana 44
  • 5.13 G2 gears
  • Superior Shafts
  • E-Locker
  • Artec Truss
  • TeraFlex Monster HD rear track bar
  • Rock Krawler Track Bar Relocation Bracket
  • EVO Rockstar Skids
Accessories
  • 430N Navigation Head Unit
  • Offroad Heroes Fastback Top
  • TruckLite LED Replacement Headlights
  • SWS Wiring harness
  • LED lights w/ KC light mounts
  • LightForce Lancer Lights w/ yellow combo light covers
  • TeraFlex HD Hinged Carrier and Adjustable Spare Tire Mounting Kit w/ Hinged Carrier Accessory Mount and Hi-Lift RotopaX Mount
  • 48" Hi-Lift jack
  • aFe CAI
  • aFe throttle body spacer
  • aFe y-pipe
  • aFe hi-tuck exhaust
  • ARB Recovery Kit
  • Cobra 75 WX ST CB w/ Firestick
  • sPOD
  • Trek Armor seat covers
  • SpiderTrax 1.5" wheel spacers
  • 37" Tire Chains
I started a build thread about 8 or 9 months ago, but I got busy with school and life. I am starting a new one.
Here she is off the lot and then again going up Left Hand Canyon in Boulder, CO.
See less See more
2
#366 ·
Love the build brother. More black Jeeps :2thumbsup:
ACE is a pretty good company to be a "sponsored" Jeep. I am only acouple parts away from being a "unsponsored" Jeep/moving catalog for JCR (ahem hint hint JCR)
Sucks your had such bad experience with OR-FAB, so far so good there for me but I really haven't had to have them fix any actual problems.
Im jealous of your beadlocks but like Spyder not the style lol. How do the Racelines balance?
#384 ·
Walle said:
Looks like I am going to have to replace a rear axle shaft. Thanks Superior for standing behind your product...oh wait, you aren't even in business any more?! :rantscream:
Man, that blows. What did you do to it!? Ol Blue is doing great, pretty much been maintenance free! Nothing new
#385 ·
That is good. I am not sure. One of my outings? I have had a squeak in the right rear for some time. It would come and go, but it has gotten worse. We looked at it this weekend and took the rotor off. There was a lot of debris inside, and some fresh metal shavings. We cleaned it and was inspecting when I discovered there is a lot of play. I can pull the axle out about 1/2-3/4 of an inch. It isn't leaking, so the seal is still good. It could be just the bearing, but it is doubtful at this point. I want to pull it tomorrow, but we will see what is going on this weekend. I have spare bearings and seals.
Also, I found the reason my ABS light is on - ANOTHER broken wheel speed sensor. The dealership didn't ensure that my wheel studs were threaded in when they rotated my wheels. One of the studs clipped and broke the sensor. I told them to ensure that before putting the wheel back on. I will be going to talk with them about this. The guy even wrote it on the worksheet.
Top
