Jeep won't move in gear - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Jeep won't move in gear
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 04-25-2013, 06:00 PM   #16
Godholio
Originally Posted by ki4cye View Post
with the engine running and the clutch NOT pressed will it go in gear? Have you looked at the t-case to make sure the shifter is connected?
I think these are the questions that'll narrow it down.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 06:01 PM   #17
CrawlingForward
CrawlingForward's Avatar
If you try to shift the transmission while the engine is running without using the clutch, what happens?
Does it grind? If so, it mean the engine is transferring power through the clutch to the transmission.
If it is not grinding, it mean that there is some disconnect between the flywheel and clutch.
Normally, it is the engine that creates that stopping for the wheels. Because the engine is freely turning, we have to look for another spot where it may be binding.
My Other Jeep Is A Jeep - Crawlingforward's Jeep-Related Adventures
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
- North Shore Jeep Club -
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline   Reply With Quote Quick reply to this message
