Jeep won't move in gear - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Jeep won't move in gear
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 04-25-2013, 03:04 PM   #1
nodicesteven
Had a new clutch put in a few months ago and have had absolutely no problems with it but today it just does not want to move. I can shift into gear, 1st, reverse goes into gear as smooth as always but it will not move an inch. Any advice on what this could be would be greatly appreciated, thanks!
07 Unlimited Sahara
nodicesteven is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 03:28 PM   #2
jpin321
What broke this time?
jpin321's Avatar
Transfer case is in neutral?
"Anyone who has never made a mistake has never tried anything new." ~Albert Einstein
My Jeep History -- 1980 CJ5 > 2005 TJ > 2013 JK > ?
jpin321 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 03:58 PM   #3
nodicesteven
Yep, checked, definately in neutral
Unread 04-25-2013, 04:21 PM   #4
toxicwaste29
Ohh, had to be a rough day i guess
toxicwaste29 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 04:27 PM   #5
sjones26573
That would be your problem
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 04:30 PM   #6
ncb
**** happens. I learned a long time ago working on aircraft to check the simple things first. Switchology is often the fix for squawks.
ncb is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 04:33 PM   #7
nodicesteven
I meant NOT in neutral... I wish that was just the problem.
Unread 04-25-2013, 04:35 PM   #8
sjones26573
I had a feeling that wasn't the answer. Your post didn't sound like you had solved it.
Jeep-Owner.com
Unread 04-25-2013, 04:35 PM   #9
nodicesteven
It is NOT in neutral, it is in 2wd, I did try shifting to 4wd to see if it did anything. It did not. I can put it in gear and let the clutch out but it does not move. If I try to push the Jeep by hand it does not move so it's not neutral. Any addl suggestions would be great, thanks!
Unread 04-25-2013, 04:36 PM   #10
sjones26573
Does the engine change tone or struggle when letting the clutch out?
Jeep-Owner.com
Unread 04-25-2013, 04:44 PM   #11
nodicesteven
No, there is no difference in the engine at all, I can let the clutch pedal all the way out and nothing changes in the engine where as before of course it would stall if I did not apply gas.
Unread 04-25-2013, 04:58 PM   #12
ki4cye
with the engine running and the clutch NOT pressed will it go in gear? Have you looked at the t-case to make sure the shifter is connected?
ki4cye is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 05:02 PM   #13
sjones26573
Sounds to me that you got a botched clutch.
Jeep-Owner.com
Unread 04-25-2013, 05:07 PM   #14
CrawlingForward
Ok, so on JKs, is the T-case shifter electronic or manual? Manual, correct?
Could something be wrong with the shifter that despite the lever being in 2wd, the actual transfer case is in neutral?
Although, you said you pushed it and it would not move, correct? Did it move and then stop after like 1" like it was in gear?
My Other Jeep Is A Jeep - Crawlingforward's Jeep-Related Adventures
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
- North Shore Jeep Club -
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 05:38 PM   #15
nodicesteven
Yes, it moved and stopped like it was in gear.
