Jeep won't move - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Jeep won't move
ORS Recovery RopePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 08-09-2013, 11:55 AM   #1
Selkirk
Jeep won't move
Okay in need of some opinions.
I was driving down the road (2007 wrangler x 6 speed)
I kicked her a lil in first gear, and I shifted to third and I had no power like it was in neutral. I pulled over. Did basic trouble shooting. I do not think its the clutch because I can put it in all gears while running or not running, no grinding or forcing. But I can push it while in gear. Ideas?? I was thinking the t case. But not sure where to start
Selkirk is offline   Reply With Quote Quick reply to this message
Unread 08-09-2013, 12:13 PM   #2
brianjw
Probably could be a handful of things. Did you try shifting the transfer case? Does it go anywhere in 4x4? Is the shifter cable broken?
brianjw is offline   Reply With Quote Quick reply to this message
Unread 08-09-2013, 12:31 PM   #3
Cooneys08JK
Cooneys08JK's Avatar
Really sounds like your tcase is in neurtral. When you say kicked it in 1st gear, what do you mean by kicked?
'08 Black 2door JK- DD
'99 Chilli Pepper XJ- Wheeler- BFG ATs, 2 " BB + bolt on stuff
Cooneys08JK is offline   Reply With Quote Quick reply to this message
Unread 08-09-2013, 12:54 PM   #4
duneslider
What does the clutch feel like?
I would also check the t-case.
duneslider is offline   Reply With Quote Quick reply to this message
Unread 08-09-2013, 12:59 PM   #5
ncb
Broken pinion in rear diff? Try 4wd to see if front engages.
ncb is online now   Reply With Quote Quick reply to this message
Unread 08-09-2013, 01:28 PM   #6
Selkirk
I put it in 4x4 and it goes in but it still will not move, and by kicked it I meant gave it some gas.
Unread 08-09-2013, 01:29 PM   #7
Selkirk
And the clutch feels good. It is still firm
Unread 08-09-2013, 02:57 PM   #8
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
1. Broken linkage for T case? 2. Broken shifter fork?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote Quick reply to this message
drivetrain , jk , transfer case
