-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Jeep won't move (http://www.jeepforum.com/forum/f96/jeep-wont-move-1560011/)
Selkirk 08-09-2013 11:55 AM
Jeep won't move
Okay in need of some opinions.
I was driving down the road (2007 wrangler x 6 speed)
I kicked her a lil in first gear, and I shifted to third and I had no power like it was in neutral. I pulled over. Did basic trouble shooting. I do not think its the clutch because I can put it in all gears while running or not running, no grinding or forcing. But I can push it while in gear. Ideas?? I was thinking the t case. But not sure where to start
brianjw 08-09-2013 12:13 PM
Probably could be a handful of things. Did you try shifting the transfer case? Does it go anywhere in 4x4? Is the shifter cable broken?
Cooneys08JK 08-09-2013 12:31 PM
Really sounds like your tcase is in neurtral. When you say kicked it in 1st gear, what do you mean by kicked?
duneslider 08-09-2013 12:54 PM
What does the clutch feel like?
I would also check the t-case.
ncb 08-09-2013 12:59 PM
Broken pinion in rear diff? Try 4wd to see if front engages.
Selkirk 08-09-2013 01:28 PM
I put it in 4x4 and it goes in but it still will not move, and by kicked it I meant gave it some gas.
Selkirk 08-09-2013 01:29 PM
And the clutch feels good. It is still firm
RockyClymer 08-09-2013 02:57 PM
1. Broken linkage for T case? 2. Broken shifter fork?
The time now is 08:38 PM.
