Jeep won't move in gear - Page 2 - JeepForum.com
post #16 of 17 Old 04-25-2013, 06:00 PM
Godholio
Originally Posted by ki4cye View Post
with the engine running and the clutch NOT pressed will it go in gear? Have you looked at the t-case to make sure the shifter is connected?
I think these are the questions that'll narrow it down.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #17 of 17 Old 04-25-2013, 06:01 PM
CrawlingForward
If you try to shift the transmission while the engine is running without using the clutch, what happens?
Does it grind? If so, it mean the engine is transferring power through the clutch to the transmission.
If it is not grinding, it mean that there is some disconnect between the flywheel and clutch.
Normally, it is the engine that creates that stopping for the wheels. Because the engine is freely turning, we have to look for another spot where it may be binding.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
