Jeep won't move - JeepForum.com
post #1 of 8 Old 08-09-2013, 11:55 AM Thread Starter
Selkirk
Jeep won't move
Okay in need of some opinions.
I was driving down the road (2007 wrangler x 6 speed)
I kicked her a lil in first gear, and I shifted to third and I had no power like it was in neutral. I pulled over. Did basic trouble shooting. I do not think its the clutch because I can put it in all gears while running or not running, no grinding or forcing. But I can push it while in gear. Ideas?? I was thinking the t case. But not sure where to start
Selkirk is offline
post #2 of 8 Old 08-09-2013, 12:13 PM
brianjw
Probably could be a handful of things. Did you try shifting the transfer case? Does it go anywhere in 4x4? Is the shifter cable broken?
brianjw is offline
post #3 of 8 Old 08-09-2013, 12:31 PM
Cooneys08JK
Cooneys08JK's Avatar
Really sounds like your tcase is in neurtral. When you say kicked it in 1st gear, what do you mean by kicked?
'08 Black 2door JK- DD
'99 Chilli Pepper XJ- Wheeler- BFG ATs, 2 " BB + bolt on stuff
Cooneys08JK is offline
post #4 of 8 Old 08-09-2013, 12:54 PM
duneslider
What does the clutch feel like?
I would also check the t-case.
duneslider is offline
post #5 of 8 Old 08-09-2013, 12:59 PM
ncb
Broken pinion in rear diff? Try 4wd to see if front engages.
ncb is offline
post #6 of 8 Old 08-09-2013, 01:28 PM Thread Starter
Selkirk
I put it in 4x4 and it goes in but it still will not move, and by kicked it I meant gave it some gas.
Selkirk is offline
post #7 of 8 Old 08-09-2013, 01:29 PM Thread Starter
Selkirk
And the clutch feels good. It is still firm
Selkirk is offline
post #8 of 8 Old 08-09-2013, 02:57 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
1. Broken linkage for T case? 2. Broken shifter fork?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
drivetrain , jk , transfer case
