Jeep pulling/ smell - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Jeep pulling/ smell
OPTIC ARMOR WINDOWS all sale now !!!!!!!!Spartan Locker Special Forum Prices Dana 30 44 60 Ford 8.850" LED Light Bar with Overhead Mounting Brackets $69
Unread 02-23-2014, 07:51 AM   #1
Seanbmc
2009 JK Wrangler
Jeep pulling/ smell
As I was finishing up a road trip yesterday and nearing home we began to smell a burning smell in the jeep. My buddy described it as electrical or rubbing. Shortly after when I braked for a stop light the jeep loosely pulled to the right. It happened again at the next light. I thought it was a flat. I was close to home so I rolled home slowly.
No flat tire, I could not find/see anything wrong. Strong burning smell from front right side around the tire. Stronger underneath than in the engine compartment.
Any ideas what's going on or what I can look for?
Sean
2009 Black Unlimited.
2.5" RC Lift, Rugged Ridge Side Armor.
315/75/16 BFG ATs on Cragar 16x8 Soft 8s.
Mastercraft Grab Handles, Mopar Slush Mats, Hitch.
Seanbmc is offline   Reply With Quote
Unread 02-23-2014, 07:58 AM   #2
billybooster2
1983 CJ8
Sounds like a sticking caliper?
billybooster2 is offline   Reply With Quote
Unread 02-23-2014, 08:02 AM   #3
Seanbmc
2009 JK Wrangler
Should I replace them? Or is there an easier fix?
Unread 02-23-2014, 08:09 AM   #4
billybooster2
1983 CJ8
Id recommend investigating the caliper b4 rplacing! Could be anything...
Unread 02-23-2014, 08:13 AM   #5
billybooster2
1983 CJ8
Check pads are there, check wheel bearings, check caliper acton. Then see if u can see rubbing areas...
Unread 02-23-2014, 08:43 AM   #6
TheWheelDeal
That happened on my fiancee's camry once, a strut broke and was rubbing against the tire. It could literally be anything... just look around, if you don't see anything do a short drive then feel around with your hand for heat, or use a small misting bottle (like water sprayer) to hit probable areas and see where the water insta-boils.
TheWheelDeal is offline   Reply With Quote
Unread 02-23-2014, 08:52 AM   #7
Seanbmc
2009 JK Wrangler
Thanks for all the input everyone. I'll get out there and see if I can figure it out today!
