Jeep JK roof rack - JeepForum.com
post #1 of 14 Old 12-19-2008, 03:33 PM Thread Starter
chris79
JK Wrangler
Jeep JK roof rack
Has anyone figured out how to carry a canoe on the JK? Is there any roof rack systems available for the hard top?
chris79 is offline
post #2 of 14 Old 12-19-2008, 05:43 PM
08BlueSahara
Chris, Do a search on this Jeep forum, many threads on this subject.
08BlueSahara is offline
post #3 of 14 Old 12-20-2008, 05:47 AM
Hilldweller
2014 JK Wrangler
The Congo Cage is the easiest and safest.
A receiver at both end with uprights would work for a long enough boat but would cost more than a cage; it's a good alternative if you don't want a cage...
Safety fast,
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing.- Helen Keller
Hilldweller is offline
post #4 of 14 Old 12-20-2008, 07:41 AM
redrockin7
Here you go, tons of info, pics, etc. But if you search "kayak" in titles only you get like 20 more posts also:
http://www.jeepforum.com/forum/f96/yakima-overhead-rack-wrangler-freedom-top-647518/
redrockin7 is offline
post #5 of 14 Old 12-20-2008, 12:56 PM
VegasJeep
VegasJeep's Avatar
Warrior products also makes a nice rack
2001 XJ... 3.5" RE Lift, 31" BFGs, Bilsteins, Defender roof rack, Dana 30 HP front True Trac and 4.10s, Dana 44 Rear True Trac 4.10s, SYE, tom woods D/S, SUPER CLEAN LOW MILES
VegasJeep is offline
post #6 of 14 Old 12-22-2008, 12:28 AM
tricked919
there's a gabillion threads on this... In brief.. having owned a jeep with a Safari (congo style) rack and a JK now with a Thule artificial rain gutter system. I will NEVER go back to a cage rack. They're noisy, they do flex a bit, forget taking your top off (it can be done, but the PITA factor goes up by 10) and they are INSANELY more expensive. 2 or 4 door, you can have a solid rain gutter system for under $300 that is more than adequate for a kayak. Some guys are running them on factory gutters for light stuff (ski & snowboards), but you will never convince me that the FT panels will support the wind load of a kayak.
Here's my set up (2-dr) I use 4 artificial brackets and 4 extended towers with long bars. I run 2 bikes and 2 creek/play boats from FL to NC all the time.
If you have a 4-dr, I suggest using 2 brackets and 2 xtended towers in the back, and then 2 standard tower on the factory gutters above the rear doors.
tricked919 is offline
post #7 of 14 Old 12-22-2008, 12:56 PM
JrTjK
1978 FSJ Wagoneer
this coming spring, I intend to buy this:
Kargo Master Congo Cage...you can add add-ons, or run it as is...and it's cheap ~$330
I wish I had realized this sooner last season...my kayaks just sat.
JrTjK is offline
post #8 of 14 Old 12-22-2008, 05:01 PM
Silver_Hilton
2009 JK Wrangler
Does this rack require any drilling to install?
John
Silver_Hilton is offline
post #9 of 14 Old 12-22-2008, 08:12 PM
JrTjK
1978 FSJ Wagoneer
if it does, only the rear bumper. not in the tub like other ones.
JrTjK is offline
post #10 of 14 Old 12-23-2008, 12:27 AM
08BlueSahara
http://www.kargomaster.com/item.asp?id=62
post #11 of 14 Old 12-23-2008, 07:48 AM
Silver_Hilton
2009 JK Wrangler
Originally Posted by 08BlueSahara View Post
Thanks for the link -- If I understand these installation descriptions correctly, once you install the brackets that hold the rack in place, you can remove the rack whenever you want simply by removing 4 bolts. That sounds pretty attractive, and I like the fact that no special drilling is req'd.
post #12 of 14 Old 12-23-2008, 08:49 AM
Hilldweller
2014 JK Wrangler
There will also be a rack out shortly from Body Armor that requires no drilling at all; it will have a basket and light tabs included though. Price will be about $250 more than the Kongo.
http://www.jeepforum.com/forum/f96/new-roofrack-wranglers-644101/
Safety fast,
post #13 of 14 Old 12-23-2008, 10:28 PM
tricked919
Chris - with a soft-top, that congo cage is just about your only option, but with a hard top, I wouldn't touch one with a 10' pole. I owned a rack from Top5 that was almost identical to the cage shown above (only stainless) and the wind noise was BRUTAL and I think I took my top off about 5% of the time that I actually wanted to - it was a huge chore. ...and having to dril into the body; you go right ahead.
You get what you pay for. Cheap cage racks WILL rust, they're flimsy, they make lowering the top so tough that you'll hardly ever do it, they are noisy...
I'm telling you, with the hard top, go with a bolt-on rain gutter rack - those cages look tough, but that's about it. I'll never own another one.
post #14 of 14 Old 12-23-2008, 10:57 PM
08BlueSahara
Well, that may be your setup...
But, make sure to always take your hard top with you when you want to take your bikes out!
All setups have pros and cons. tricked 919 obviously likes his, he had a bad experience with a cage.
All users are different and their needs/wants/opinions are all different.
Hi, Conga Cage is NO DRILL. Not cheap/flimsy, bad paint rusty, Etc. NOT PERFECT - It is noisy!
Definitely don't want it on all the time, I take it off.
"Chores" can be automated (see winch in ceiling): Hoist to take cage and top on/off:
Tell me, should this kayak setup have been mounted on a drill into the hard top solution?
There's only the ability to make a 3Ft crossbar spread MAX on the hard top.
Imagine the stresses put on such a small area going down the freeway at 70!, FOR 500 MILES.
All of our experiences are different, no one solution is perfect. Good luck, get what suits your needs/wants/situation/opinion.
Then, GET OUT AND JEEP!
Finally ordered my Jeep Roof Rack and Safari Cage Sia Bani TJ Wrangler Technical Forum 60 08-01-2010 09:31 PM
ski rack options spare tire or roof rack Therou TJ Wrangler Technical Forum 17 01-04-2010 12:02 PM
Jeep Height Measurement Needed - Lift, 33", Roof Rack. jtice Wrangler General Discussion 0 06-03-2008 09:50 AM
Will this roof rack fit my jeep Guitarhead09 TJ Wrangler Technical Forum 4 05-22-2008 03:45 PM
Jeep Roof Rack dot Com? MissileTM YJ Wrangler Technical Forum 13 02-01-2006 09:54 PM
