Jeep at Dealership all day. Litterally got nowhere - Page 2 - JeepForum.com
post #16 of 30 Old 12-04-2012, 06:33 AM
BadTrainDriver
Originally Posted by Godholio View Post
What does the linkage look like? Does the shifter physically go into the transmission from above? Everything I've had (even RWD) has been linkage down the side of the housing, not directly into it.
Originally Posted by MudDuck99 View Post
pressing in the clutch stops the noise also. Could it still be a linkage problem?
Sorry, that was actually just me being curious, my JK is an auto.
I can't think of anything in common between the clutch system and the shifter that could cause this. Maybe there's a vibration in the input shaft/pressure plate/bearings that's making the linkage squeak...I'm really reaching here. But if the shifter doesn't go directly into the transmission case I really can't explain how pushing on it does anything.
FYI, there is no shifter linkage for the transmission.
The physical shifter goes straight down into the transmission.
2012 Jeep Wrangler Unlimited Rubicon
Stock, for now...
BadTrainDriver is offline
post #17 of 30 Old 12-04-2012, 08:49 AM Thread Starter
MudDuck99
2014 JK Wrangler
Originally Posted by BadTrainDriver View Post
If you think about a manual transmission mechanically, different things are happening when clutch is in versus released, so therefore it's obviously going to sound different.
My 2012 6 speed sounds the same, and I believe it to be normal.
The 2012 6 speed that I test drove before I bought mine sounded the same as well.
The previous TJ's I've had also sounded this way.
So did my YJ.
Start the engine, tranny in neutral, clutch out, and turn your AC on(so the compressor runs).
That noise get's louder, doesn't it?
Normal.
Start the engine, tranny in neutral, clutch out, push up on shifter and it stops(yes, I know you covered this already...just follow me). Normal.
Start the engine, tranny in neutral, clutch out, BE IN LOW RANGE, push up on shifter and your Jeep will creep forward. Normal.
It's normal. Every one does it.
If you say yours doesn't, come to Columbus Ohio and let me listen.
If it doesn't do it, I'll pay your Jeep off.
I understand it is normal for it to rattle. However, my concern is how loud it gets at times. It's is a quite rattle most of the time. Then I stop and it sounds like a power stroke diesel is under me
MudDuck99 is offline
post #18 of 30 Old 12-04-2012, 09:02 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
Sounds normal to me. Mine sounds the same way, so did my 06 TJ
My builds:
and
or follow us on
spyder6 is offline
post #19 of 30 Old 12-04-2012, 09:08 AM
Godholio
Ok, thanks. It seems like that should make this easier to figure out, if he can push down and there's a change.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #20 of 30 Old 12-04-2012, 09:20 AM
Matt The Hammer
There is a shift fork within the transmission - is that technically a linkage?
After destroying several Jeep manuals in my past, a noise like that - even if it's normal - would bother me.
2013 JKU
1995 YJ
Matt The Hammer is offline
post #21 of 30 Old 12-04-2012, 10:50 AM
Godholio
The linkage I was talking about would be for the shifter itself, not the clutch.
This is what the linkage looks like on my Muncie:
Well, that's what it looks like under 10 lbs of grime and crud.
Utah Jeep Crew #148
Godholio is offline
post #22 of 30 Old 12-04-2012, 03:07 PM
spyder6
spyder6's Avatar
2010
the 6 speed is a top loader, it doesnt have linkage like that. the shifter connects directly to the rails on the inside of the gearbox
i'll reiterate what i said before. the noise is completely normal.
My builds:
and
or follow us on
spyder6 is offline
post #23 of 30 Old 12-04-2012, 03:45 PM
1222
RIP John
1222's Avatar
If I were you I would take it to a transmission shop other than a dealer and let them have a listen. It wonít cost you a dime and youíll have a second opinion from someone other than a sometimes less than par dealership.
Listening from a YouTube on the computer is not really the best way to convey how you trans actually sounds. There very well could be something wrong. Get that second opinion.
(2011-2016)
1222 is offline
post #24 of 30 Old 12-04-2012, 08:50 PM Thread Starter
MudDuck99
2014 JK Wrangler
didnt think about that. Totally going to do. My buddies dad owns one in town.When I finally get another day off of work i'll have to swing it by there
post #25 of 30 Old 12-05-2012, 02:34 AM
1222
RIP John
1222's Avatar
^^^Thatís even better when you know the person who owns the shop, good luck.
(2011-2016)
1222 is offline
post #26 of 30 Old 12-05-2012, 03:28 PM
GPV
Just a guess but I think they are going to replace the throw out bearing.
Here is a Youtube video of the typical noise observed:
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #27 of 30 Old 12-05-2012, 03:34 PM
revmaynard
1988 MJ Comanche
A friend of mine bought a '12 2door Rubicon on pre-order before they were released last year and his had an AC problem. I'm not sure of the specifics, but it ended up spending it's first few days at the local dealership getting fixed. I'll ask what his problem was to see if it was the same issue.
revmaynard is offline
post #28 of 30 Old 12-05-2012, 08:53 PM
1222
RIP John
1222's Avatar
Originally Posted by GPV View Post
Just a guess but I think they are going to replace the throw out bearing...
They did that with the NV3550 on my TJ and it doesnít help, the problem is with the Trans.
(2011-2016)
1222 is offline
post #29 of 30 Old 12-06-2012, 06:30 AM
paul84043
The question is: Is it a problem, or just a normal noise.... ?
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #30 of 30 Old 12-06-2012, 02:41 PM
1222
RIP John
1222's Avatar
Itís a normal noise (from what Iíve read) for that transmission (NV3550) which by the way is very stout but as far as Iím concerned itís not normal to me. It never had that noise when it was new and it was embarrassing whenever I would pull into a gas station or 7/11 store after a long day of wheeling. The rattling was very loud.
(2011-2016)
1222 is offline
