Jeep Dealer HAS to be WRONG!! - Page 2 - JeepForum.com
post #16 of 31 Old 07-25-2010, 04:28 PM
fernjack
Originally Posted by OKBryan View Post
fernjack just posted that I could get a local shop to install the cooler and I could tell the dealership that I installed it myself and it should not effect my warranty. Why would I not tell the dealership that I had another local shop to install it instead of telling them I installed it? Thanks, Bryan
My reason behind this is it just ends the stealership from saying "the other shop caused this or that and THEY should warranty your trans." . In my opinon it just cuts off any stupidity they WILL try and pull if their trans on warranty fails . Either way an aux. cooler will do nothing but HELP an auto in towing mode or just hard driving in hot weather . You are correct though it should not matter WHO installs the cooler as long as it has been done correctly & the trans fluid has been topped up the the proper level .
07' Rubi Unlimited 6spd. , Rescue green #64 CDN , 35x12.5 mudders
Rick .
fernjack is offline
post #17 of 31 Old 07-25-2010, 06:53 PM
scottman
2010 JK Wrangler
Any reputable local transmission shop should be able to do this for ~$200 and Chrysler has to prove that the installed piece caused the failure in order for it to affect your warranty. That said the transmission cooler is a $50 part and takes 1 hr to install yourself with a knife to cut the lines and a screwdriver to tighten the hose clamps...
scottman is offline
post #18 of 31 Old 07-25-2010, 07:35 PM
Snowbird01
Another 2 cents for shop install, any shop that specialize in hitch install regularly upgrade auto trannys !
Snowbird01 is offline
post #19 of 31 Old 07-26-2010, 05:49 AM
Jiblet
Originally Posted by JLC08JK View Post
The only time an added cooler would be an issue is if it was the cause of related failure. ...An aftermarket part can and will be used as the potential cause of any related issue. If this comes up then we simply have to prove that the problem would have occurred regardless of the installation of said part....
JLC is correct on all counts except one: "we" have nothing to prove. The burden of proof is on Chrysler/dealer. The Moss-Magnusen Act requires the dealer prove (not simply suggest) that the aftermarket part directly caused the failure for which the warranty claim is being denied.
Originally Posted by tkob1060 View Post
IMHO ANYONE with a JK and auto should be adding a cooler...
Absolutely true.
Jiblet is offline
post #20 of 31 Old 07-26-2010, 06:01 AM
Dronac
I don't even tow and I am adding a cooler next month. Everywhere I read, it seems that heat kills transmissions. Unless there is a defect in mine, I don't see it failing under warranty, but the heat these things make will kill it eventually. I'd rather protect my transmission long term and risk fighting with a dealer than skip the aux cooler and potentially reduce my transmission's life.
2008 Jeep JK X: auto trans, 3.73 gears, D44 rear, D30 front
Mods: 2'' Rusty's coil lift, Superchips 93 octane tune, Cobra 75 CB radio, 33'' Duratrac's, onboard air compressor
My Build Thread! ---> http://www.jeepforum.com/forum/f96/dronacs-build-thread-1104134/
Dronac is offline
post #21 of 31 Old 07-26-2010, 06:33 AM
CptSnoopy
2010 JK Wrangler
OK -- I am going to ask a really dumb question here. I am about to get a Jeep Rubicon 2DR with a manual 6-speed. I don't intent to tow anything, but I do want to off-road. Do I need to look at installing one of these too?
CptSnoopy is offline
post #22 of 31 Old 07-26-2010, 06:35 AM
Warlord2
nope, we dont have transmission fluid with a manual...
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #23 of 31 Old 07-26-2010, 06:46 AM
CptSnoopy
2010 JK Wrangler
Thanks -- I thought that was it, but I just wanted to be sure. I really need to read and read to get caught up on all the stuff I can do and need. This is opening up just a whole new world to me!
post #24 of 31 Old 07-26-2010, 06:47 AM
tjkj2002
2002 KJ Liberty
Absolutely true.
Actually how warranty's are written now it is the customer that has to prove they still have a warranty.The lawyers have bypassed the MM act long ago via wording.Why do you think all those extended powertrain warranty's came around,because you the owner must prove that you took care of your vehicle.
tjkj2002 is offline
post #25 of 31 Old 07-26-2010, 07:11 AM
JIMBOX
I'm afraid thats so true-
If your transmission fails, the dealer can just say OK, it'll cost you, $2800 bucks to fix !!
Yea, you're under warranty, but YOU'VE gotta write the letters, make the phone calls, sometimes get a lawyer to PROVE THAT IT'S THE MFG DEFECT !!
They don't GOTTA DO NOTHING !!
Now having said that, not all dealers are like that, hopefully if you have that trouble, you'll (anybody) be OK
Minor warranty items are usually taken care of EASY---this ain't minor !!
Good luck !
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #26 of 31 Old 07-26-2010, 02:34 PM
Kastiron
I thought the 2 doors all came with 1,000lb towing rating? Is it 2,000 now?
You might already be over the limit with an empty trailer.
08 JK 4 Unlimited in Jeep Green. 6 speed manual, soft top. Miles to date: 15,472 since Jan 18, 2008.
Kastiron is offline
post #27 of 31 Old 07-26-2010, 02:38 PM
ronjenx
ronjenx's Avatar
According to your owner's manual:
3.21 = 1,000 lbs.
3.73 and 4.10 = 2,000 lbs.
ronjenx is offline
post #28 of 31 Old 07-26-2010, 02:41 PM
Kastiron
Thanks! I was just about to run home and check that. My mistake!
I really need to re-gear..
Kastiron is offline
post #29 of 31 Old 07-26-2010, 07:23 PM
tjkj2002
2002 KJ Liberty
Good luck !
JIMBO
Yes there are many dealers that are not a-holes.In this day and age you need to follow the maintenance schedule and have proof that it was preformed.Not saying you need every receipt or even take it to a shop,you can do it yourself but keep the receipt stating what kind of fluid was used and the date.The receipts show a trend that proves you have been making a effort to properly maintain your vehicle.
Being lifted with bigger then stock tires will throw up some flags on major drivetrain claims,as will using the wrong fluids.
Oh and yes I have seen warranty(bumper to bumper warranty) denied right from Chrysler on a JK that had less then 10,000 miles when the trans took a dump,it had Amsoil ATF in it and is not speced for the trans so no warranty.Amsoil told him to pound sand also,so much for there warranty.
tjkj2002 is offline
post #30 of 31 Old 07-26-2010, 08:07 PM
Charles
2017 WK
Originally Posted by 2005X View Post
the trailer weighs 1500lbs empty, so unless he is towing around an empty trailer for ****s and grins then it is gonna weigh more. considering the wrangler towing ability sucks anyways i would want to be safe than sorry
An EMPTY 5x8 trailer that weighs 1500 pounds? Wow.
Charles is offline
automatic transmission , cooler , JK Wrangler , towing , trans cooler , wrangler
So the dealer installed my soft top wrong!! Jordon83 JK Wrangler Technical Forum 2 03-09-2010 02:31 PM
Jeep went in to Dealer mouse TJ Wrangler Technical Forum 6 02-01-2007 03:32 PM
My Jeep dealer has a JK!! newguy66 JK Wrangler Technical Forum 1 09-17-2006 09:30 AM
Got the Jeep back from the dealer today, here's what what wrong with it... JeepinYahoo TJ Wrangler Technical Forum 5 07-18-2006 02:39 PM
Water Pump: Dealer New or Dealer Rebuilt? RckyMtnTJ TJ Wrangler Technical Forum 6 07-05-2006 11:24 AM
