Jeep buy back - Page 4 - JeepForum.com
post #46 of 51 Old 01-10-2014, 10:25 AM
kittenmittens
kittenmittens's Avatar
My hard top leaks almost every time it rains. it holds about 1/2 inch of water in the passenger floor board. pulled the carpet now i just pull the drain plugs. but it is annoying when you pay 30k for a jeep and it leaks.
05 Rubicon 6" lift 35x12.5 BFG KM2
15 Rubicon Unlimited Hard Rock 2.5" lift 35x12.5 BFG KM2
kittenmittens is offline
post #47 of 51 Old 01-15-2014, 12:52 PM
4x4Reaper
2011 JK Wrangler
This is what I deal with every time now when it rains or even when snow melts on top of my jeep.
4x4Reaper is offline
post #48 of 51 Old 01-19-2014, 12:20 PM
Reelworks
I had a similar problem with leaks. Heres the link to my saga. http://www.jeepforum.com/forum/f176/...ir-jk-1290357/
Happy ending- I got it replaced with a 2012. No 'real' leaks except "maybe" twice a year with the hardtop I get a little spritz over the dash. I only use the hard top in winter and found that since its a 3 piece top, things shift a bit over time. After researching here on the forum I use 'Syl Glyde' brake lube on all the rubber around the two pieces of the hard top up front. If I get a leak first thing I do is un-latch it make sure the two sides are well seated and re latch it in the Owners manuel order= right front, left front, Center front. then Back right, back left, back center and then tighten down the two screws through the sound bar. that usually does it. IF not I pull the two tops, clean the rubber really good and reapply the Syl Glyde. That always seems to solve it.
Reelworks is offline
post #49 of 51 Old 01-19-2014, 02:14 PM
tartangirl
Glad to hear it Reelworks. Sent you a PM a month ago and wanted to know how you made out and to thank you for sharing your saga, which provided me with the info I needed to get a replacement Jeep. Thanks and glad to hear that your new Jeep doesn't have issues.
tartangirl is offline
post #50 of 51 Old 01-20-2014, 08:06 PM
Reelworks
Tartangirl
Glad I was able to help. Just making sure- you got my reply to your PM? I hope you are enjoying your jeep.
post #51 of 51 Old 02-17-2014, 03:02 PM
tartangirl
Tartangirl
I never did get your PM. I am enjoying the new Jeep!
Back in Jeep! 77 renegade TJ Wrangler Technical Forum 28 10-29-2009 08:03 AM
Sold my Jeep now selling my truck back for a jeep! jeeps4life TJ Wrangler Technical Forum 16 01-28-2008 06:13 PM
I'm Back and with a new Jeep! 91yjeeper TJ Wrangler Technical Forum 11 12-17-2007 04:34 PM
Jeep is Back!!! 92wrangler YJ Wrangler Technical Forum 2 10-31-2007 12:42 PM
Got my jeep back from the stealership, update on repairs,fix on jeep rattle>> franco802 TJ Wrangler Technical Forum 5 01-07-2004 06:29 PM
