Jeep buy back - JeepForum.com
post #1 of 51 Old 04-08-2010, 04:28 AM Thread Starter
VaRaven
2010 JK Wrangler
Jeep buy back
I just picked up my new jeep yesterday! Chrysler bought it back due to water leaks, It was in the shop 11 times for a total of 72 days.
Has anyone else had a hartop leaking problem?My dealer said this was uncommon in a hard top and that softtops were the ones that leaked.
VaRaven is offline
post #2 of 51 Old 04-08-2010, 05:34 AM
rentalguy1
What kind of deal did you get on it? I have a soft top, and it doesn't leak...much...yet. I'm sure it will get worse with age, but that's just part of it. I would think that even a hard top would leak to some degree, but yours sounds like it may have been excessive. Then again, the owner could have just been a whiner. Hope it's fixed and it serves you well.
rentalguy1 is offline
post #3 of 51 Old 04-08-2010, 06:16 AM
08rubinewb
My hardtop leaks up front. If there is a good amount fo rain it comes right in over the radio and pools under the e-brake. I've tried parking on different angles and also taking off and putting the top back on just to make sure it's correct. That being said it's never enough watere that it's really going to hurt anything. On a side note my soft top is 100% leak free so far .... go figure :-)
08rubinewb is offline
post #4 of 51 Old 04-08-2010, 02:43 PM
Ravik
2010 JK Wrangler
2010 soft top here, no leaks (yet)... But, the way I figure it, the carpet comes out in 5 minutes and they put those pan plugs in there for a reason.
My previous jeep had just enough body to keep most of the mud off, so the fact I don't get wet in the Rubi when it rains is still sort of mystifying to me.
2010 2dr Rubicon
Ravik is offline
post #5 of 51 Old 04-08-2010, 02:49 PM
redrockin7
Neither my hard nor soft top leak... guess I'm lucky.
redrockin7 is offline
post #6 of 51 Old 04-09-2010, 06:01 AM
jake_blue
My soft top leaked when I first got it, but technically the leak was over the top front corner of the driver door so I don't know if that's really the top's fault. The dealer replaced the rubber seal under warranty the first time, but the second time wanted to charge me a fortune for it. I just bought some of that adhesive rubber stripping and filled the area in question. It's cheap enough that when I have to peel it off and discard it, I can apply more later.
jake_blue is offline
post #7 of 51 Old 04-09-2010, 06:55 AM
20181c
2009 JK Wrangler
09 hard top no leaks.
09 Rubi Unlimited Stone White
ORH liner, Cooltech, CB, Weathertech, Thule Track system.
20181c is offline
post #8 of 51 Old 04-09-2010, 07:59 AM
Grizzly1
2010 JK Wrangler
2010 Hard top (freedomtop) No leaks. A little wind noise at highway speed but thats normal.
Semper Fi
Grizzly
Grizzly1 is offline
post #9 of 51 Old 04-09-2010, 08:07 AM
1222
RIP John
1222's Avatar
Iíve had no leaks so far and mines an '08.
(2011-2016)
1222 is offline
post #10 of 51 Old 04-09-2010, 08:11 AM
stuckmehere
2009 JK Wrangler
09 Soft-top no leaks yet. Only had it up and down about three times. Rough winter.
stuckmehere is offline
post #11 of 51 Old 04-09-2010, 08:20 AM
OregonVette
2008 dual top. I bought it new with 1.1 mile on it.
Both tops are leak free. I take the jeep through high pressure car washes. No leaks.
Although, there have been two times in the last two years where I had a little dribble in the center dash because the hard top leaked during massive rain storms with high winds. In my case I am sure that it was simply operator error and I just didn't install them correctly.
All things considered, mine have been problem free and fun for over (edit: 5) years. Knock on wood!!!
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline
post #12 of 51 Old 04-09-2010, 08:56 AM
riptide
07 hard top, no leaks.
2012 JKU Rubicon, Auto, Trail-Skins
riptide is offline
post #13 of 51 Old 04-09-2010, 10:04 AM
jd_goldcombat
2010 JK Wrangler
Mine's weird. I follow the torque-down pattern in the manual...and I can go through a high-pressure car wash, sit out in torrential rains, and no leaks. Then...just a little sprinkle sprinkle...and I'll get some drips on the dash....even though the freedom tops never came off since the carwash or downpour.
Very strange.
Never confuse effort with results......
jd_goldcombat is offline
post #14 of 51 Old 04-09-2010, 10:11 AM
krutj
2009 JK Wrangler
My rear curtain looks like it's shrinking, really. looks too small now and is very difficult to zip/unzip, and the fit at the tailgate is poor. Been back once to dealer, didn't help.(big surprise)
-- Joel --
krutj is offline
post #15 of 51 Old 04-10-2010, 04:58 AM Thread Starter
VaRaven
2010 JK Wrangler
Rentalguy1
If you spend 29000 -30000 on a jeep you dont expect it to leak. Yes you may get a drop or two on some rain storms. By=ut standing water in the floor is not good.
I wouls suggest you not talk **** if you dont know all the facts!
VaRaven is offline
Back in Jeep! 77 renegade TJ Wrangler Technical Forum 28 10-29-2009 08:03 AM
Sold my Jeep now selling my truck back for a jeep! jeeps4life TJ Wrangler Technical Forum 16 01-28-2008 06:13 PM
I'm Back and with a new Jeep! 91yjeeper TJ Wrangler Technical Forum 11 12-17-2007 04:34 PM
Jeep is Back!!! 92wrangler YJ Wrangler Technical Forum 2 10-31-2007 12:42 PM
Got my jeep back from the stealership, update on repairs,fix on jeep rattle>> franco802 TJ Wrangler Technical Forum 5 01-07-2004 06:29 PM
